Getting clay out of a crevice
Old Feb 5, 2008 | 01:55 PM
seasick's Avatar
seasick
Default Getting clay out of a crevice
I'm a new Z owner and finally had time to clay bar the car today.
I managed to get a small amount in the crevice on the lower panel (in front of the back tire). Any suggestions? My clay usually pulls any excess up but can't seem to get it in this case. Thanks (search didn't seem to answer my question).
Old Feb 5, 2008 | 02:16 PM
jcleary47's Avatar
jcleary47
This happened to me once, and I used a completely dry piece of clay and "blotted" the stuck piece out. Did you try spraying whatever you were using for lubricant inside the crevice to try to break the bond with the piece of clay and the body? After doing that I would imagine it should pop right out.
Toothpicks also work.
Old Feb 5, 2008 | 02:57 PM
Detailed Image's Avatar
Detailed Image
Detailed Image
Lots of different ways to approach this. I typically use a clean microfiber towel and jamb it in there and wipe. Sometimes a little quick detailer or 50/50 mix of water and rubbing alcohol will help. If that doesn't work you can wrap your microfiber towel with something long and skinny like a toothpick and work it in to the crevice. Be careful not to hit the paint and cause scratches. If those methods don't work let us know and we'll go over more tactics.
Greg @ Detailed Image
Old Feb 5, 2008 | 03:29 PM
seasick's Avatar
seasick
Good suggestions. I'll be trying these methods tomorrow.
I did try to break the bond with the clay lube I was using but to no avail. I was a little paranoid about putting some elbow grease into a microfiber cloth on that crevice so I appreciate the prompt replies.
Old Feb 5, 2008 | 06:45 PM
1cleanz's Avatar
1cleanz
even a toothbrush might help.
Old Feb 5, 2008 | 07:58 PM
ZSpectrum's Avatar
ZSpectrum
q tips work well, also good for removing wax in crevices
Old Feb 5, 2008 | 08:09 PM
genegoesfast's Avatar
genegoesfast
toothpick fools
Old Feb 6, 2008 | 03:49 PM
seasick's Avatar
seasick
Toothpick worked like a charm, thanks again.
However, I had my first real noob moment of having my first Z. The crevice was actually the protective film on the lower panel in front of the back tire. ^_^
From the angle I was clay bar'ing originall I thought is was a line cut in the body for detail. fa!l.
Old Feb 6, 2008 | 03:55 PM
genegoesfast
yeah right at the edge of the clear bra in front of the rear fenders. I've had the problem before. Glad it worked.
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
Prinny
Southern California
Sep 28, 2015 08:43 PM
nbdyfcnsqnc
Cleaning & Detailing
Nov 21, 2002 06:06 PM
Brad4rdHay
Sep 3, 2002 05:12 PM
Brad4rdHay
Aug 27, 2002 01:15 AM
