after using menzerna products, still having swirls help!!
Old Jan 11, 2009 | 07:23 PM
SK350z's Avatar
SK350z
Default after using menzerna products, still having swirls help!!
I have a black 05' 350z. I recently detailed my car with the following products:
1) Sonus Clay Bar
2) Porter Cable 7424 to apply:
A) Menzerna Intensive Polish
B) Menzerna Final Polish
3) Menzerna Full Molecular Jacket
4) P21S Carnauba Wax
I still see a lot of swirls and scratches in the sunlight. In the dark it looks nicer, of course. What should I do? What other products can I get to put into my list that is not too pricey?
its much worst, bad pictures taken pretty late of the day.
Old Jan 11, 2009 | 07:50 PM
1cleanz's Avatar
1cleanz
menzerna polishs take a while to break down. it could be you were not working the polsih long enough for it to work. it is a deminshing abrashive. witch means that it has to be broken down to work effective. also even if you did break it down right, you may need to hit each panel a couple of times to get rid of all the swirlls. or it could be that the porter cable is not effetive enough to cut threw the swirlls. you may need a rotary. but if i were you i would make sure that the polish is broke down enough and make sure you see it flash to clear, it should be clear when it is broken down right. also try hitting the areas more than once to see if that helps.
What speed were you using when doing this?
Old Jan 11, 2009 | 07:57 PM
SK350z's Avatar
SK350z
for the IP i used 4-5 and Final i used 3. So the products i have now should be able to do the job right? I'll try breaking it down more next time. thanks
Old Jan 11, 2009 | 08:00 PM
TheOtherRob's Avatar
TheOtherRob
I cant believe that no one asked, but what pads are you using, and it what order.
Old Jan 11, 2009 | 08:17 PM
1cleanz's Avatar
1cleanz
i knew i forgot to ask somthing. lol that is also a big question what were the pads you were using with what products.
Old Jan 11, 2009 | 08:18 PM
SK350z's Avatar
SK350z
i use the DAS foam pads http://www.autopia-carcare.com/ultim...hing-pads.html. i use the orange pad for the IP and the green pad for the Final.
Old Jan 11, 2009 | 08:22 PM
TheOtherRob
That could be your problem, pads. The clear on the Z is very soft, even a orange pad is sometimes to abrasive. Sounds like you need a finishing pad to get the hazing/ or buffer trials out. Do you have a blue light polishing pad? Maybe use that on a low setting with a finishing polish slowly moving it.
Old Jan 11, 2009 | 08:23 PM
1cleanz's Avatar
1cleanz
i have never used them pads but that seems like it would do the job. so i would just hit the panels again and see what happens since that is prolly the only pads you have. also make sure to remove the protection before you start the polishing again. do a ipa wipe down so the surface is free of any thing to keep the polish from working the right way.
Old Jan 11, 2009 | 08:24 PM
TheOtherRob
After looking over the pics again, it just looks to me like you didnt polish enough of the defects out. I cant notice any buffer trials or holograms. Looks like you should invest in a halogen lamp to work with to see if your getting the imperfections out, if you dont already have one.
Old Jan 11, 2009 | 08:25 PM
SK350z's Avatar
SK350z
okay. thanks a lot guys! I really really appreciate the help. where can i purchase a halogen lamp at a decent price?
Old Jan 11, 2009 | 08:32 PM
1cleanz's Avatar
1cleanz
just get some halogens at lowes or home depot. they will make a diffrance. you could look into the 3m sun gun but thats like 300$.
Old Jan 11, 2009 | 08:39 PM
SK350z's Avatar
SK350z
ooO okay I think I might have a old cheap one that will do the job. I also had a question how to avoid the dust of the polish on to the windows and stuff?/
Old Jan 11, 2009 | 08:41 PM
TheOtherRob
People usually tape up trim and windows accordingly with painters tape and paper. Or you can just wipe it off.
Old Jan 11, 2009 | 08:50 PM
1cleanz's Avatar
1cleanz
like said above jut tape up and use newspaper. or wipe off when done. You really should tape off your trim so you dont stain it with the polish.
Old Jan 11, 2009 | 08:57 PM
SK350z's Avatar
SK350z
my trim is stained is there anyway to fix it? return it back to a black color?
Old Jan 13, 2009 | 03:13 PM
1cleanz's Avatar
1cleanz
you could use some black wow to fix that. that is if you have some. you can by over the counter trim restores at auto zone and things. look for mothers or meguares there. also a secert way to get rid of it is to use some peanut butter and rub on it. it will resrtore the black, and pull out the white residue
sales@czp
Sep 23, 2019 03:30 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
Obeorangekenobi
Sep 11, 2015 07:17 AM
