potential brake dust solution!!!!
Old Sep 18, 2003 | 07:33 PM
steig's Avatar
steig
Default potential brake dust solution!!!!
I have absolutely hated dealing with the brake dust on the wheels. I've waxed the wheels with mothers premium wax and gotten no benefit. BUT, i found a product at Autozone from RainX. It some RainX wheel protectant. you clean your wheels first and then spray on this clear protectant. it is suppossed to help keep the brake dust off the wheels. I cleaned my wheels tuesday night. Then i drove my car to work wednesday and then to columbus from dayton. Normally, I would have dirty wheels when i arrive in columbus. However, the wheels still look clean. If I wipe my finger on the wheels i can pick up a slight layer of brake dust but it comes off very easy and it should just rinse off with a hose. No hard scrubbing or wiping needed. Just wanted to let you know about RainX protectant. I'll post more info as i see how easy the dust rinses off tomorrow.
Old Sep 18, 2003 | 07:39 PM
Z_Pride's Avatar
Z_Pride
Man thankgod. Thanks for the info, I'll have to stop off and get some tomorrow.
Old Sep 18, 2003 | 07:47 PM
MY350Z.COM's Avatar
EBC GReenstuff and Hawk HPS pads help a lot too.
Old Sep 22, 2003 | 08:23 AM
TriX's Avatar
TriX
this is what i was looking for.
Old Sep 26, 2003 | 04:11 PM
Messana's Avatar
Messana
Any suggestions on removing stains off the rims?
Old Sep 26, 2003 | 06:54 PM
danotto's Avatar
danotto
I am not overly impressed with this product. The aplication is simple enough, just spray it on the wheel and let dry, but I still have quite a bit of brake dust. Maybe not as much as before, but more than I would like.
Old Sep 26, 2003 | 07:17 PM
CelticPride2's Avatar
CelticPride2
Have you tried using Simple Green? It takes all the brake dust off my wheels like magic, so I don't see why it wouldn't do the same for stains.
--D.J.
Old Oct 13, 2003 | 08:25 AM
mberthia's Avatar
mberthia
I tried the Rain-X product after reading about it on this post.
I cleaned the car and waxed the rims first. I then sprayed the left side wheels and left the right side as is for comparision.
After two weeks, I never saw a difference. Same amount of dust on the rims. I cleaned it this weekend and the wheels with the Rain-x had some streak that stayed even after washing. I had to use wax to clean up the marks.
I'm sure I'll give it another try someday, but for now, this product is not worth using.
Old Oct 13, 2003 | 09:29 AM
zand02max's Avatar
zand02max
Just change the brake pads, Hawks or greenstuff. NO BRAKE dust, you will be amazed.
$70 at tirerack.com
GL
Old Oct 16, 2003 | 06:11 AM
FlaPhil's Avatar
FlaPhil
I've been using Wheel Wax. As far as break dust, I think you're going to get it (unless you switch the pads). The Wheel Wax will clean anything that may be stuck to the wheel, and leaves a great coating behind. The next washing just requires car soap and a brush. Seems to last a long time, and makes my wheels look great.
Old Oct 19, 2003 | 03:31 PM
Ghettorab's Avatar
Ghettorab
Default Which is better?
hey which is better EBC Greenstuff brake pads or Hawk HPS Street brake pads?
Old Oct 19, 2003 | 03:36 PM
KornerCarver's Avatar
KornerCarver
I also tried the Rain-X wheel proctectant. I was not impressed. If anything, the brake dust was more difficult to remove after the application of the Rain X. There were streaks and I had to wax the wheels to get rid of the streaks. After that I gave up and bought EBC Greenstuff pads. I have virtually no brake dust now. The wheels stay perfectly clean.
Rather than fighting the brake dust, I would just swap out the pads and then have your clean wheels.
Les
Old Oct 19, 2003 | 04:32 PM
zand02max's Avatar
zand02max
Default Re: Which is better?
I have the Hawks, they squeak a little, kinda annoying at times.
The greenstuffs squeak also, so I guess you have to decide.
I did a poll on the two, and most favored the Hawks. GL, their both great products.
Ensure you bed the brakes.
Old Oct 19, 2003 | 05:32 PM
SungNamZ's Avatar
SungNamZ
Installed Hawk HPS pads on Tuesday. Probably drove 400 miles since then. Washed tonight (Sunday), "No Dust"! Bought Hawk HPS pads at www.raceshopper.com ( $56 + $9 S&H) $65.
Old Oct 20, 2003 | 01:48 PM
350zluvr's Avatar
350zluvr
Question
DOES ANYONE KNOW WHERE TO GET THE RAIN-Z WHEEL PROTECTANT ONLINE?
I did a search and found only one place that sells it... but they're out. 1 place after searching three search engines (google, yahoo, ask). + I have'nt seen it anywhere in a store near me.
Thanks
Old Oct 22, 2003 | 10:03 PM
Jsn350Z's Avatar
Jsn350Z
"Simple Green?" That stuff rocks for any stains.
Old Oct 23, 2003 | 10:02 AM
VR3's Avatar
VR3
I use the ceramic pads offered at tirerack.com. No dust and it keeps the stock braking performance.
Old Nov 7, 2003 | 09:15 PM
___DJK___'s Avatar
___DJK___
Im sure this has been suggested in the past, but using Zaino on your wheels eliminates 50-70% of the brake dust build up. It also makes the dust that does accumulate VERY easy to wash off. I used an old claybar to clean my wheels then applied a coat of Z-5 on them. I probably should have used Z-2 but thats what next time is for
Uriyo_
Sep 8, 2021 08:46 AM
