Is to much wax harmful.
Old Oct 30, 2003 | 07:08 PM
2Fishy4U's Avatar
2Fishy4U
Default Is to much wax harmful.
My son, who works at a GM Dealership, was told by one of the body guys that I should quit waxing my car so much. According to the body shop guy waxing the car every few weeks will eventually ruin the finish. The body shop guy recommended no more then 3-4 times per year.
Do his comments make sense to any of you.
Old Oct 30, 2003 | 07:39 PM
s9am_me's Avatar
s9am_me
unless you are using something harsh or an abrasive... i don't think waxing too much will ruin your paint. look at the Zaino freaks (no offense )... they zaino their car almost every week and it actually protects the car even better. Your son's co-workers are probably just jealous u guys have a Z
Old Oct 30, 2003 | 08:28 PM
BlueDragonZ's Avatar
BlueDragonZ
That makes no sense. You wax your car to maintain the finish on the vehicle. The more application that you used the better it protects. If that was the case you would definately see a warning on every wax on the market stating that using their product more than recomended use is harmful.
Old Oct 30, 2003 | 09:09 PM
mofoz's Avatar
mofoz
all i have to say is 52 coats and Dr. Bonz is my hero
Old Oct 31, 2003 | 05:36 AM
havabooz's Avatar
havabooz
i wax my car cause i enjoy it..plus i like the shine ...do i have to polish every time i wax??...im not sure the best way to do it
and how long does it take for a coat of wax to naturally wear off..im sure there are not really 52 coats of wax protecting DR BONZ's car at one time!
Old Oct 31, 2003 | 08:48 AM
Kevin Overall's Avatar
Kevin Overall
Totally depends on the products you are using, if the product has no abrasives like Zaino polishes, you could use it every day and never hurt or remove any paint.
Now if you choose to use a very aggresive and powerful cleaner type was such as NuFinish, if you use that too much it will thin the clear over time.
But again, his comment means nothing unless he knows what you are using and if he is shcooled in all the different kinds of waxes and polishes available today...
Old Oct 31, 2003 | 09:34 AM
wakaZ's Avatar
wakaZ
Someone once told me that stuff like "L. Glass" is not good because it seals, the paint can't "breathe".
I wonder how true that is
Old Oct 31, 2003 | 09:46 AM
2Fishy4U's Avatar
2Fishy4U
Wink
Kevin,
thanks for the explanation. It is probably time I switched to Zaino.
Old Oct 31, 2003 | 11:21 AM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
You are correct. I do not have 52 layers of wax on my car. In fact I don't have a SINGLE layer of WAX on my car.
Zaino is a POLYMER SEALANT and trust me, it doesn't "wear off" as you say. It is the most durable product on the planet and if using it often is harmful, than I am in SERIOUS trouble.......
Old Oct 31, 2003 | 11:32 AM
yobri's Avatar
yobri
famous last words... LOL
Old Oct 31, 2003 | 01:24 PM
HokieZ's Avatar
HokieZ
I think the guy was probably referring to the popular "cleaner waxes" people use. These do have mild abrasives designed to remove the old was while applying the new wax. Repeated and frequent use can and will, over time, remove layers of the clear-coat. Zaino, CG, blackfire, none of these have abrasives and can be used continuously without fear of damage.
havabooz's Avatar
havabooz
hmmm...i stand corrected
Old Oct 31, 2003 | 01:36 PM
havabooz's Avatar
havabooz
ok bonz....i think you might have me cnvinced...but ill only buy zainoafter i finish my meguiars gold class stuff....does the car have to be "DAWNED" before i start using zaino.....reason i dont wanna start usin it is because i know ill become addicted like you
Old Oct 31, 2003 | 01:38 PM
havabooz's Avatar
havabooz
http://www.zainoaddicts.com/founders...le/dr_bonz.htm
D
Old Nov 3, 2003 | 10:42 PM
ares's Avatar
ares
Veteran
I think even caranuba waxes would cause problems... over time I think youd get a buildup of it, and it will yellow eventually if not removed occasionally... or so I heard.
polymers dont do that tho, and they are meant to stack.
Old Nov 4, 2003 | 03:44 AM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Yes, you should definitely DAWN before you apply your Zaino. For the absolutely best results, you may want to clay the car as well.
Old Nov 4, 2003 | 05:18 PM
2Fishy4U's Avatar
2Fishy4U
Cool
Dr. Bonz,
now that I broke down and ordered the Zaino ($84.95) kit which comes first; the Clay Bar or Dawn.
Being new to Zaino any other advice you have would be appreciated.
So far the Z has about 6 coats of wax on it; one Mequiers (terrible) and five from the Vette Guys at the dealership my son works at. Total mileage on the car = 5,500 and I live in Wisconsin.
With the Zaino I assume I am starting over.
Old Nov 4, 2003 | 07:34 PM
z0ner's Avatar
z0ner
Wash with Dawn first, then Z-18 with a spray bottle mixture of 95% water and 5% Z-7. Follow that up with a Z-7 wash and dry. Now you're ready to start the polish treatment.
Old Nov 5, 2003 | 04:45 AM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Sounds good to me. BTW fishy, in case you didn't know, the Z-18 Z0ner is referring to is the Zaino Claybar.
Old Nov 5, 2003 | 08:15 AM
2Fishy4U's Avatar
2Fishy4U
Cool
Thanks for your help guys. I will let you know how everything turns out once I get the Zaino on.
dcains
Sep 21, 2015 09:28 AM
sean2168
Cleaning & Detailing
183
Mar 22, 2003 05:36 PM
Slexis200
Oct 9, 2002 02:40 PM
tranZition
Oct 5, 2002 06:48 PM
Brad4rdHay
Sep 2, 2002 06:56 PM
