CrystalGuard: Say Good-Bye to WAX TODAY!!
Old Dec 1, 2003 | 10:45 AM
  #341
Diamond Jim's Avatar
Diamond Jim
If anyone is interested, CrystalGuard is offering a Xmas special of 10% off all purchases for the month of December. This would be a good time to either try the products or give them as a gift, I suppose.
Use the coupon code XMASSPECIAL
srmd22-
The haze is a normal part of the process. You simply buff it out by hand with a micro fiber...
Old Dec 3, 2003 | 12:55 PM
  #342
SHINDIG1's Avatar
SHINDIG1
I've applied CG Quick and want to add body side moldings. Do I have to remove the CG Quick first before "sticking" on the moldings? If I don't, will the moldings not adhere as well as they should?
Old Dec 4, 2003 | 05:08 AM
  #343
BlueDragonZ's Avatar
BlueDragonZ
IMO I think if you just clean the surface area that you're applying the molding to like alcohol, I'm sure it would be just fine. Better get call Jim first to know for sure.
Old Jan 2, 2004 | 05:45 AM
  #344
srmd22's Avatar
srmd22
Originally posted by BlueDragonZ
Here is my results.
I washed the car with Dawn, clay bar then wash with Dawn again. I followed it with the primer to remove any paint contaminant. I then sprayed the Base and spread it with MF while it was wet. The directions said to leave it on the vehicle for 2-3 hours, I left it on there overnight. The following morning I rinsed it with MF and followed it with the Top coat spreading it with MF. Again, I left it on the vehicle overnight then rinsed it the following day.
REACTIONS:
After two days the paint is ABSOLUTELY AMAZING on gloss. My girlfriend described it best when she said that it looks like a fresh candy that you just want to lick. My car is a Daytona Blue Z and it just brings out the metalic blue color, it just shimmers.
It got rained on the next day and after it cleared up I rinsed it off with MF and it shimmered right up.
I usuallly worry about water spots the day after it gets washed but this takes care of it. The spot is easily removed with just a MF.
My car sat under a covered parking for at least four days, my concern usially at this point is dust. I usually need to dust her off even if it's just the day after. I didn't have to do it this time. Of course there are some dust on it but not as bad as it was before.
PERSONALLY, I like the results that I've gotten. It will soon be winter here and with winter comes snow and salted roads. I wanted a good product that will protect the paint finish just like what they are claiming to do. I guess the real test is there. I will see how it stands out when Spring comes next year.
This review was completed after the first week and a half of getting it done. Here are my thoughts on it now.
This is a good product and I like what I'm seeing. One thing that amazed me yesterday. I found a bird bomb on her yesterday. Usually regardless if you remove it imediately or not, there usually a spot on the paint of it's removed. Not the case here, as soon as I wiped it off with some detailing spray, GONE. Also, there has been some water spots thoughout the car due to the rain we had during the last couple of days. Usually, you would need to spray it with detailing spray to get them removed. I tried something, I ran my fingers accros one of the water spots and it came right off. I took a MF and can easilly remove them without trying. VERY COOL!!! Now here's the down fall.... The scratches on the car is now easily visible. I knew that it doesn't fill in the swirls but I didn't think that it would be HIGHLIGHTED once the product is applied. I wish that I would have known this prior to application. Actually, I could have sworn that I read in a CG thread somewhere that it fills SOME swirls. This is the only problem that I have at this point. I'm not really able to do anything to it until Spring. I would need to remove CG and try to hremove these scratches. At that point I'll decide if I will continue using it. I sent an e-mail to Jim at CG asking what I could do to take care of this but haven't recieved a response yet.
Excellent report, thanks. Sounds like it is worth trying, despite the potential problem you mentioned with swirls. I haven't yet definitively decided, but if I order I will keep everyone posted.
Old Jan 8, 2004 | 05:54 PM
  #345
radianz's Avatar
radianz
Default How Long does the quick last?
Does anyone have any idea how long did the quick last? I have read throuh but have yet to find anyone who would comment independently
Old Jan 9, 2004 | 10:21 AM
  #346
Diamond Jim
The Quick should last a few months, though if the weather is bad maybe less. It really all depends on your driving and environment. I would recommend you use the CG Wash along with CG Quick and you'll be quite happy with the results.
Quick note: There is a next generation formula being developed for the Quick that will fill in swirl marks. This should be available soon...
Old Jan 10, 2004 | 06:54 PM
  #347
350z_tako's Avatar
350z_tako
Know it all
I have been testing CGQ for few month here in Japan. It lasts over 3 months with most of the cars if you do the preparation right. Actually we just upgraded CGQ. CGQ for US market will be upgraded in spring season or so!
Old Jan 18, 2004 | 11:13 AM
  #348
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
I have a black 350z, and the biggest problem I have is the damn dust. Literally, after an hour of washing, I have a nice think layer of visible dust on the car. Does CG prevent dust from sticking to the surface of the paint, and the wheels? From those that have used the product....how effective is CG is reducing this problem?
Old Jan 25, 2004 | 03:44 PM
  #349
Sharif@Forged
Forged Performance
OK, I just recieved my CGQ and did my first application last night. Here is how the process went for me.
My car is only 1 month old, so I didn't bother doing any pre-work to the paint. I just washed it with normal car wash soap and a sheepskin washing mit. I rinsed the car, and then sprayed about 2-3 sprays per body panel, and also did the glass and wheels. I then took a dry microfiber cloth and gently rubbed the liquid around the car. By the time I completely circled the car, the water had miraculously dried to a brilliant shiney wet look! Per the instructions, I took my hose and rinsed the car, and then dried with a super absorbant synthetic towel.
The car looks absolutely stunning. Even with a black car, I didn't notice ANY swirl marks or streaks. I am really impressed with this product. In the sunlight, the car looks just dripping went and shiny. Thanks! And all of this took me less than 30 minutes including the WASH!
Old Feb 2, 2004 | 02:37 PM
  #350
Strife350z's Avatar
Strife350z
When's the ETA on the 2nd generation CG formula?
AND - when will the next coupon be available
Old Feb 19, 2004 | 10:44 PM
  #351
Strife350z's Avatar
Strife350z
anyone? i thought CG was the sponsor?
... i guess i should buy zaino
Old Feb 21, 2004 | 11:56 PM
  #352
z33saru's Avatar
z33saru
So after going thru some of the posts, I have a question.
All you have to do is wash with CGW, then apply the CGQ.
After this all you do is reapply the CGQ whenever and never use the wash again?
Thanks in advance for your help.
Old Feb 22, 2004 | 02:31 PM
  #353
zcombat's Avatar
zcombat
From what i recall, you use the CG wash everytime before applying CG quick for proper bonding. They work together well. any other crystal guard user should be able to confirm this.
Old Feb 23, 2004 | 07:20 PM
  #354
12SecZ's Avatar
12SecZ
I quit using the CQW about 4 coats ago, I don't think it has made any difference. A big bottle of McGuire's soft Gel soap works fine then CGQ.
Old Feb 25, 2004 | 09:58 AM
  #355
Diamond Jim
The CG Wash is a very good product to use. It has Top coat chemicals in the shampoo and it helps fill in microscopic scratches in the crystal coating. I recommend using CG Wash every time you wash the car and use the Quick every 1-2 months (or at your discretion). I persoanlly love the wash.
As for the next generation of CrystalGuard, we are looking at a spring time release. I think you guys will be quite impressed with the next version. It fills in swirls better and the formula looks different. More to come in the next few months.
If anyone wants a discount, please contact me directly at jim@crystalguard.com and I'll give you a 10% discount on orders for the next few weeks...just let me know you're a Z memeber...
Jim Campos
CrystalGuard Products
Old Feb 25, 2004 | 11:35 AM
  #356
zcombat's Avatar
zcombat
keep us updated Jim. I was really impressed by the shine with the crystal guard. But it tends to highlight the flaws of the paint after a wash. I do like the glassy look it gives on black paint. Very nice product.
Old Mar 16, 2004 | 08:35 PM
  #357
Strife350z's Avatar
Strife350z
any news on when the next gen will arrive? I ordered 2 bottles of the old gen stuff, haven't had a chance to try it (damn weather in Toronto!)... but i'll be heading to california in mid-April ----> if it's available by then, I plan on buying a case (literally)
Old Mar 18, 2004 | 04:25 AM
  #358
zcombat's Avatar
zcombat
email jim from crystal guard. I emailed him but haven't recieved any answers back. i am also excited about the new product. I've used the old version it really looks fantastic. Crystal guard looks better after a wash. It becomes more clear and reflective after it cures. Let us know, if you get any info on the new product.
Old Mar 19, 2004 | 11:34 AM
  #359
Rickmeister's Avatar
Rickmeister
Any more word on how this stuff is holding up...problems/strong points. I live in Phoenix so our summers are brutal. I am very **** retentive when it come to taking care of my ride so I am wondering if the product lives up to the hype...anyone?
Old Apr 14, 2004 | 09:49 AM
  #360
Diamond Jim
Just to let everyone know, we are having a spring special for CG Maintenance products. Use the discount code CGSPRINGSPECIAL and receive 20% discount on Maintenance kits, CG Quick, and CG Wash. Or you can call us and just mention the special. This runs through the end of April.
Happy Detailing!
