Plasti-dip from previous owner a mess
Old Aug 26, 2013 | 02:44 PM
motocrosser's Avatar
motocrosser
Default Plasti-dip from previous owner a mess
ok guys im new to this site but I have been around cars since I was a teen and doing 95% of my own work . I just bought a 04 350z touring six speed with 20s from a younger guy . he sprayed the rims with this plastic dip crap whatever! he said it was easy to get off, think again my 2500 psi pressure washer will not blow it off. so today after a whole can off aircraft stripper, for one rim. I finally got it all off. the reason I had to do this is because the plastic dip started peeling off. think about it before you do it . its a mess to get off.
Old Aug 26, 2013 | 02:48 PM
KingBaby's Avatar
KingBaby
Hardest Setting
some kind of oil get it off....google it or youtube it
Old Aug 26, 2013 | 03:01 PM
driftsucky's Avatar
driftsucky
so, it started peeling and you couldn't peel it off.
It normally comes off fairly easy. It's a fun time to be had.
Old Aug 26, 2013 | 03:32 PM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
Maybe he used the wrong PlastiDip
Old Aug 26, 2013 | 04:26 PM
POS VETT's Avatar
POS VETT
It's harder to peel an orange than cured Plasti Dip.
Old Aug 26, 2013 | 04:40 PM
mr. sparco's Avatar
mr. sparco
Your fingers would work better at peeling PD than a power washer.
Old Aug 26, 2013 | 06:15 PM
essejd's Avatar
essejd
yeah plastidip is easy to get off man..
Old Aug 26, 2013 | 06:23 PM
ZMoneyPIT's Avatar
ZMoneyPIT
Plasti dip is really quite a pain if you don't peel it before it becomes thin. After that kiss your weekend goodbye...
The only solution to getting the stuff off is either buying more dip and recoating the rims to make the coat thicker or buying dip dissolver.
Everything else does not work, goo gone, wd-40, ect...
Old Aug 27, 2013 | 10:45 AM
motocrosser
well maybe I went about it the wrong way ! im not sure . I finally got it all off ! it did not peel on the spokes just on the outer rim ,I tried to touch it up and with the plastic dip and it just never looked right . but anyway time to paint and clear . thanks for the input guys I appreciate it .
liqalu04
Jan 2, 2022 12:58 PM
derekinthez
South East
Sep 28, 2015 06:35 PM
Tochigi_236
Sep 27, 2015 03:40 PM
