Question about buffer on clear bra
Old May 27, 2014 | 07:26 AM
SQuaLZ's Avatar
SQuaLZ
Default Question about buffer on clear bra
Hello all. Just bought a Griot's Garage random orbital from Detailed Image and plan on using it this weekend. This will be my first time waxing my car since my accident.
Prior to my accident, I had the clear bra on my front bumper and did that part by hand, as I was worried that my prior orbital would maybe ruin the bra.
Now that I have the entire front of the car wrapped in clear bra (bumper, hood, headlights and fenders) I am wondering if I should still do those sections by hand or if the orbital is safe on it.
Only reason I am asking is that it is literally 1/3 of the car that is wrapped now so of course the orbital makes things a lot easier, but I don't want to ruin anything either.
Thanks in advance!
Old May 30, 2014 | 02:40 AM
SQuaLZ's Avatar
SQuaLZ
Bump I know I am not the only one on this forum that has a clear bra on my car. Any input would be much appreciated.
Old May 30, 2014 | 03:55 AM
travlee's Avatar
travlee
Master
i am curious of this too, i am about to have my front bumper and hood repainted and going to have the clear bra put on. i have a buddy that i work with that details cars on the side, let me ask him
Old May 30, 2014 | 05:07 AM
KornerCarver's Avatar
KornerCarver
That Griot's buffer will not harm the clear bra. The only place you need to be careful and not use the buffer is on the seam where the bra ends. You can get polish or was pushed under the edge and that will be difficult to remove. I would suggest taping the edges of your clear bra before polishing or waxing.
Old Jun 2, 2014 | 10:18 AM
SQuaLZ's Avatar
SQuaLZ
Thanks! Any update from your buddy?
That sounds about right. If I decide to use it on my car I will be very careful on the edges. Most of the edges of the wrap go around the edges of the body so it would be in spots the buffer wouldn't even touch.
Old Jun 2, 2014 | 10:19 AM
travlee's Avatar
travlee
Master
crap, i forgot... let me IM him now
Old Jun 2, 2014 | 11:33 AM
travlee's Avatar
travlee
Master
so i talked to him, he said you can but it is not preferred. he said you have to use the right pads and the right speed or you will burn through it, said it is not worth the risk
Old Jun 2, 2014 | 01:22 PM
SQuaLZ's Avatar
SQuaLZ
Great thanks! I will do that part by hand. Doesn't really matter since I have no imperfections on the front anyways. I have tons of swirl marks on my hatch I need to take care of, but besides that the paint is pretty good on my car.
Old Jun 2, 2014 | 03:53 PM
Waiz's Avatar
Waiz
I would not use an orbital if you are just applying wax especially over your clear bra
I personally try to limit my impact whenever I am using my Porter Cable and if I was you I would just apply it gently by hand
Old Jul 10, 2014 | 05:59 AM
Detailed Image's Avatar
Detailed Image
Detailed Image
Thanks in advance!
The answer is unfortunately a bit more complex than yes or no, but the main thing is that the Griot's polisher is surely not dangerous for the film/clear bra. I could go as far as to say no polisher is dangerous on its own, but that's another topic . As long as you use slower speeds, very minor to no pressure and the appropriate pad/product (no heavy polishes and no heavy cutting pads) you will be fine both polishing the film and applying wax/sealant to it.
As for the edges, there's a pro/con to both taping and not taping. By taping, you will miss polishing or applying protection to say .5-1mm of the film. Also, you will leave the polish or wax residue at that edge of the film that you may have to scrub off and damage the film by scrubbing. On the other hand, you won't get product into the edge of the film. When polishing film, I like to avoid tape and simply polish away from the edge the first few passes, then wen the product is already spread and worked in a bit, go over the edge so as to polish/protect it completely but avoid leaving any or much residue.
Similarly, when polishing paint, I like to only tape the film edge when compounding, then remove it and lightly polish near the edge with a finishing polish so as not to leave any area unfinished. Also, I've noticed that unless you can perfectly tape the edge of film, which is practically impossible, you leave a line of residue that you need to sometimes scrub to remove, possibly swirling up the paint a bit.
Hope that helps.
Ivan @ DI
Old Aug 12, 2014 | 05:19 PM
nowayhighway's Avatar
nowayhighway
I would suggest that you just do it by hand. Orbital polisher may or might damage the bra. But if you are an experience detailer go ahead.
Old Aug 12, 2014 | 05:31 PM
travlee's Avatar
travlee
Master
you are over a month late, but great advice
issyz
Jul 2, 2017 03:04 PM
