Zaino
Old Mar 12, 2004 | 05:44 PM
Dustin4u's Avatar
Dustin4u
Default Zaino
So the ZFX is just a additive to add to the Z2 or Z5 to make it dry faster?
I thought it was the same as the Z1 but just had a faster trying time.
You still just use Z1 on its own.
Also do you only use Z1 once EVER, or is it more like a wax were you would use it every 6 months type thing?
Thanks a ton guys, i really appreciate it.
Old Mar 12, 2004 | 05:45 PM
Dustin4u's Avatar
Dustin4u
arggg meant to be a reply.
Old Mar 13, 2004 | 02:50 PM
Kevin Overall's Avatar
Kevin Overall
Default Re: Zaino
Z-1 and ZFX are not used together, you need either one or the other not both.
Z-1 and ZFX are both polish activators making the Z-2 or Z-5 bond to the finish. Z-1 is the two step method and what we used for 15 years before ZFX came out a couple years ago. ZFX is the one step activator.
You use Z-1 or ZFX at the very least once per 6 months for paint up keep.
ZFX has advantages over Z-1, in that it takes less time, it makes the Z-2 or Z-5 dry faster, and allows you do to three coats of other Z-2 or Z-5 in 24 hours period so the layers will stack.
mcduck
Cleaning & Detailing
Nov 9, 2002 11:30 PM
MacGuru
Oct 19, 2002 03:04 PM
Dr Bonz
Oct 11, 2002 01:32 PM
z461
Oct 6, 2002 07:33 PM
