Waffle Weave towel
Old Mar 26, 2004 | 01:03 PM
Reggi914's Avatar
Reggi914
Default Waffle Weave towel
After using the waffle weave towel (from pakshak) how do i dry/store it? Can i just place it in its bag or hang it? Also, do i was it like all the other towels (with liquid detergent)?
Old Mar 26, 2004 | 01:21 PM
DavesZ#3's Avatar
DavesZ#3
You can either hang it up to dry or run it through the dryer on low temperature. Don't put it up wet or it will likely develope mildew.
Wash it with other microfiber towels, not cotton towels. Liquid detergent is the thing to use.
Old Mar 26, 2004 | 01:32 PM
SungNamZ's Avatar
SungNamZ
When i get finished, I usually have 2 wash mitts, 2 Pakshak Waffle Weave Towels and 2 DF towel I used with Z6. They all go in the washer with liquid detergent. They get a 2nd rinse and then are dried in the dryer and stored for when used again.
Old Mar 26, 2004 | 01:34 PM
Kevin Overall's Avatar
Kevin Overall
If you dry any of your car towels excessively in the electric dryer it can make them hold a static charge that transfers over to the paint that cause more dust build up..............
Old Mar 26, 2004 | 07:27 PM
Reggi914's Avatar
Reggi914
Thanks for the tips guys
Old Mar 26, 2004 | 10:33 PM
Grzldvt's Avatar
Grzldvt
Just a quick note on drying synthetic MF towels. Make sure you use low heat or air tumble.
I have had customers use high heat and run the dryer until the towels were hot. That melted the fabric, and rendered the towel useless for exterior use. Synthetic towels are sensitive to high heat.
And as Kevin stated they pick and hold a great static charge if dried with too much heat. Enough to transfer to the body and attract dust BIG TIME!!!
When you do dry them in a drier, pull them when they are still a touch moist or cold.
Then let them air dry.
Old Mar 28, 2004 | 02:49 PM
Reggi914's Avatar
Reggi914
A waffle weave can be cleaned like other towels, right? (with liquid detergent)
Old Mar 31, 2004 | 10:07 PM
s9am_me's Avatar
s9am_me
yup.. i wash all my MF towels (waffle and the regular kind) using liquid detergent. I let it soak for a bit and then rinse it off and hang dry it for about 2 days in my garage. no mildew growing, feels and looks like new.. BTW, i also have the same MF towels from pakshak
Old Apr 1, 2004 | 04:59 PM
Reggi914's Avatar
Reggi914
Thanks!
Old Mar 25, 2005 | 08:23 PM
BlkZed's Avatar
BlkZed
How do you guys clean the small wax applicators? I read somewhere that its a good idea to remove the sponge inside but there aren't any openings to remove this (the applicator was from DF towels, the one that you get free with orders over $25).
Old Mar 26, 2005 | 03:48 AM
SungNamZ's Avatar
SungNamZ
Have not seen that applicator from DF! I received that kind of applicator from Zaino. The DF applicator I have, which I ordered, are made of the same material as their towels, fits on your fingers and does have a removeable sponge.
Old Mar 27, 2005 | 10:36 PM
Jung918's Avatar
Jung918
you can use distilled vinegar in the rinse cycle to make the microfibers plusher.
Taya
Cleaning & Detailing
Jun 19, 2003 02:04 PM
BillR
May 31, 2003 02:50 AM
03 Z for ME
May 10, 2003 07:37 PM
issac
Mar 13, 2003 06:43 AM
flynnibus
Jan 10, 2003 07:56 AM
