Spring + Claybar + BlackFire + TXSTYLE =
Old Apr 28, 2004 | 07:22 AM
  #41
KShep's Avatar
KShep
Thanks for the info ...I figure any <damage> would mostly occur while drying, assuming debris removal during the rinse/eash process. Even a 100% cotton or microfiber towel can have hidden particles or pick some up from the ground as you dry.
I discovered that my compact vacuum can be utilized as a "blower", tried it last night and it has sufficient force to completely dry the wheel, will even blow the water from the lug nut holes. I will feel much better drying the wheels using this method.
(leaf blower would work I suppose, but the little nozzel on the vac is more manuverable)
Again...thanks for the tip...will use some detailing spray as additional protection. Had no idea the difference between "polished" & chrome.
Old Apr 28, 2004 | 08:05 AM
  #42
TXSTYLE's Avatar
TXSTYLE
No prob. And good luck!
Old Jun 16, 2004 | 10:55 AM
  #43
TXSTYLE's Avatar
TXSTYLE
Bump..... Just because.
Old Jun 18, 2004 | 08:03 AM
  #44
shaneotool's Avatar
shaneotool
Since you're bumpin' - I got a question about the claybar.
I was planning to claybar my car and then wax it. Does the claybar leave some kind of residue that I need to rewash my car after I use it? Or can I just start applying the wax right after I'm finished claybaring.
Old Jun 18, 2004 | 08:08 AM
  #45
TXSTYLE's Avatar
TXSTYLE
Great question! It sometimes leaves a slight residue that is harmless. I have wiped it off with a towel and water, or some of it, I just wax over.
Prepare to be "SLICKERY".
Old Jun 18, 2004 | 08:16 AM
  #46
shaneotool's Avatar
shaneotool
Cool - I don't want to have to wash it twice if I don't have to.
Time to get all lubed up!
Old Dec 3, 2008 | 11:01 PM
  #47
TXSTYLE's Avatar
TXSTYLE
For old times sake...!
Old Dec 4, 2008 | 01:37 AM
  #48
ZSpectrum's Avatar
ZSpectrum
Originally Posted by TXSTYLE
I found out the BlackFire can be ordered from www.properautocare.com
The Nanowax from Eagle 1 is pretty new, so I would check with your local Parts Store.
not to sound gay but you live in Dallas, come play with some of my detailing stuff. Fck the otc stuff.
Old Dec 4, 2008 | 01:40 AM
  #49
ZSpectrum's Avatar
ZSpectrum
You could quick detail it instead of washing it. Best bet is to just wipe down the panel the second your done with the panel. My process is
foam, 2 bucket wash, while wet start to clay bar, apply lube initially and as needed, once you have finished your first section wipe down with a dry mf towel and some qd if it streaks, repeat until you finish the car. I always go paint then glass. Then I have a seperate bar set aside for exhaust(just a used clay bar thats too dirty for paint)
Old Dec 4, 2008 | 01:41 AM
  #50
ZSpectrum's Avatar
ZSpectrum
HAHAHAH I didnt realize how old this thread was. My offer still stands thought txstyle and for anyone else who is interested.
Old Dec 4, 2008 | 08:37 AM
  #51
TXSTYLE's Avatar
TXSTYLE
^^^ Sounds like a plan! I'm all about puttin the shine on. Where abouts are you?
Old Dec 4, 2008 | 08:48 AM
  #52
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
You know what, Mackie? You should do a free demonstration on my car and do before/after shots. I know you've been doing this for a while and are pretty competent. Time to show My350Z what you can do to an almost 6 year old car with little detail attention received.
Old Dec 4, 2008 | 01:10 PM
  #53
ZSpectrum's Avatar
ZSpectrum
635 and hillcrest.
Old Dec 4, 2008 | 01:11 PM
  #54
ZSpectrum's Avatar
ZSpectrum
Im down. A demonstration would be fine with me.
Old Dec 16, 2008 | 04:55 PM
  #55
turismo's Avatar
turismo
Holy bump batman
Old Dec 24, 2008 | 02:06 PM
  #56
dkmura's Avatar
dkmura
General & DIY Moderator
OK, it's an old thread, but the message is still valid. After using several types of carnuba waxes and paint polish/protectants, I've settled on Blackfire having the best combination of shine, protection and overall durability!
Rowlett
Misc.
Oct 2, 2015 10:38 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
