Drag NHRA, IDRC, IHRA, NDRA
1/4 Mile times for tonight!
Old Jul 29, 2005 | 10:55 PM
Timmy_boy188's Avatar
Timmy_boy188
Default 1/4 Mile times for tonight!
My worst problem was my tire spin, im running on stock wheels so it was a reall big challenge to take off right, but here are my times
Old Jul 29, 2005 | 11:28 PM
dashboard's Avatar
dashboard
still u did a good job!
Old Jul 29, 2005 | 11:33 PM
Acree's Avatar
Acree
you definately need to work on the launches and quickening you shifts. that's not too bad but i pulled over a 2.2 60' on stock potenzas at 13.6. practice makes perfect man.
Old Jul 29, 2005 | 11:34 PM
Sensation350Z's Avatar
Sensation350Z
All I see is a small box with a red x
Old Jul 30, 2005 | 12:36 AM
Timmy_boy188
yea im running in phoenix heat dont forget, that takes a toll on your power, all i really need to work on is my launch, this is the first time ive 1/4 since my WRX so I really need to adjust to the Z, once I get my launch down ill be running much better
Old Jul 30, 2005 | 06:32 AM
A_16's Avatar
A_16
i take it ur stock then? decent times, ive seen much worse
and id give u advice, but my car is being more setup for autox/road racing, so im not a very good drag racer
Old Jul 30, 2005 | 06:35 AM
TK2005's Avatar
TK2005
How does an AWD turbo car get a 2.557 60' time?
Old Jul 30, 2005 | 08:41 AM
A_16's Avatar
A_16
kill it off the line lol?
Old Jul 30, 2005 | 10:54 AM
Badfish25's Avatar
Badfish25
I think WRX's are harder to launch as they will bog bad off the line if not done correctly.
Old Jul 30, 2005 | 11:33 AM
TK2005's Avatar
TK2005
Hell no. Those things take off like a bat out of hell. They'll beat you across any intersection.
Old Jul 30, 2005 | 01:07 PM
Timmy_boy188
its simple, 105 degrees out, heat sink sets in, turbo cars will run like ****, plus the kid was a little new to it
Old Jul 30, 2005 | 01:14 PM
TK2005's Avatar
TK2005
I don't like the temperature excuse too much. The operating temps of your car far exceed whatever temperature it maybe outside so any air is "cold air". It may run better in colder temps but it's not an excuse for that much error. If your engine gets heat soaked, that's one thing. If you get an hour between runs, there's no excuse.
supra crazy's Avatar
supra crazy
the kid in the wrx cant launch for **** and also you should learn how to launch I was doin 2.2 and 2.1 on stock tires. IDK when i was stock I was running 13.9 @101 and i know it all depends on the conditions but mine are preety bad i know im at sea level but it is humid and hot as hell here.
Old Jul 30, 2005 | 02:42 PM
Timmy_boy188
well id say my times arent bad for only running three times, I saw my error when I ran the 14.3, so next time I know I will do better, I will most likely have aftermarket wheels though, F running stock, its no fun, need more traction, and the heat here does take a huge toll on turbo cars, I couldnt break 15 seconds in july in my WRX, ran it in Jan. and I was running high 13s.
Tim
Old Aug 3, 2005 | 08:19 PM
Dave B's Avatar
Dave B
Clearly you haven't drag raced much. Hot air is far less dense that cold (ie it has less available oxygen). Have you ever heard of a thing called density altitude? With my cars, running in 90+ degree weather sucked out an easy .3-.4 seconds and 3mph vs running in 50 degree weather. Same 60 foots, same shift points, same mods.
Old Aug 4, 2005 | 09:34 AM
95snoozer's Avatar
95snoozer
less oxygen = less power
what is your elevation there too?
Old Aug 4, 2005 | 09:38 AM
DomZ's Avatar
DomZ
Keep on truckin buddy, good times. Was it extremely humid the day you ran?
Old Aug 24, 2005 | 05:19 PM
misfit's Avatar
misfit
Heat soak on turbo cars ruins performance, still no excuse for the lame 60 ft. for an AWD, He should of murdered you of the line, then start reeling him in!
Old Aug 26, 2005 | 08:32 PM
You ran better than every other 350Z driver who is sitting at home typing on the keyboard. Good show.
Old Aug 29, 2005 | 08:32 PM
JS04's Avatar
JS04
Good times, I've ran simliar times too. My fastest was a 14.3 with a 2.3 60ft at 99.7. It was hot and the humidity was killer on that day. Plus the track prep was horrible.
issyz
Jul 2, 2017 03:04 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
kyin
Oct 15, 2015 05:54 AM
SharX59
Sep 27, 2015 09:23 AM
samansharif
Sep 25, 2015 12:31 PM
