Drag NHRA, IDRC, IHRA, NDRA
What happens when i remove the brake fuse
Old Mar 20, 2006 | 10:36 PM
Fairlady_z33's Avatar
Fairlady_z33
Default What happens when i remove the brake fuse
Ok guys i did some research on this but really didnt find the answer to my question what would happen if i remove the brake fuse. Also were is it located.
Im asking this becouse i have a AT Z and im going to the track this friday and i want to use the full power of my z and maybe heat the tires just a bit to get a better launch.
Old Mar 21, 2006 | 03:00 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
when you press the gas and brake (powerbrake) our cars the computer tells the car to kill the power to the engine so it bogs down. when you remove the brake fuse, (located in the kick panel by your left foot) it does two things. IT MAKES YOUR BRAKE LIGHTS NOT WORK first of all, so make sure you only do this at the track and it lets your car powerbrake. now the problem i had in my Auto G35 sedan i had is when i pulled the brake fuse, it wouldnt let me take it out of park, the shifter would just stay in park no matter what i did. so to solve this problem you will need to put it on a switch that will allow you to turn it off after you have it in drive, rev etc
good luck
Old Mar 22, 2006 | 02:25 PM
Fairlady_z33
And were is it exactly located
Old Mar 22, 2006 | 02:29 PM
Alberto's Avatar
Alberto
Cranky FI Owner
C'mon man he told you where it was get off your a$$, pull that panel off and look inside for yourself-hint---->its red and the one labeled "BRAKE"
Old Mar 22, 2006 | 02:38 PM
plumpzz's Avatar
plumpzz
^LOl @ name change.
Old Mar 22, 2006 | 04:39 PM
Fairlady_z33
I read it but today i had forgotten that he told me where it was and i just asked were it was. My bad in a way.
Old Apr 5, 2006 | 07:15 PM
dlt1cy's Avatar
dlt1cy
Do a search on "brake fuse" for another option. I just gave a short review on pulling a plug in the engine bay near the master cylinder.
Old Apr 6, 2006 | 02:00 PM
MySunset350Z's Avatar
MySunset350Z
actually its labled "STOP LAMP", and this is what happens when you remove it.
http://videos.streetfire.net/player....D-0277A32CE195
07ZEKE
Aug 23, 2021 09:15 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
