Drag NHRA, IDRC, IHRA, NDRA
First time - 06Z
Old Apr 23, 2006 | 10:43 PM
Ruff Z's Avatar
Ruff Z
Default First time - 06Z
Well, went to the drags for the first time last night. I am use to driving my awd Subaru, so this will be a learning curve for the Z.
I went to Portland Internation Raceway(PIR) which has a built in drag strip on the front stretch. Needless to say, traction sucked, and i had about 8% tread left on my stock tires. And over 300 participants meant things ran very slow.
Current mods-
Utec
Random Tech hi-flow cats
Nismo Catback
First run: (40psi in the tires as I was setup for autox)
60'........2.231
330'......5.996
1/8.......9.048
mph......81.07
1000'....11.650
1/4.......13.867
mph......101.72
Second run: (dropped to 30psi, missed the 3-4 shift,hence lower et and trap)
60'........2.172
330'......5.932
1/8.......8.998
mph......80.77
1000'....11.620
1/4.......13.929
mph......98.31
So basically, I am not very pleased. First, I need new tires, the 60's were not going to come down much on nearly bald tires, plus I didn't play with pressures well enough. Second, I don't know the shift points on the Z, and if I should even be shifting into 4th. But hey, first time out on a crappy course, not so bad.
Old Apr 24, 2006 | 08:00 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Not bad considering the 60ft's...
Old Apr 24, 2006 | 11:44 AM
Ruff Z's Avatar
Ruff Z
Thanks...what are the typical rpm shift points for a Z? Anyone know if I need to shift into 4th on an 06Z?
Old Apr 24, 2006 | 12:17 PM
Good ET. You can see that your 60 foot times can use improvement.
Old Apr 24, 2006 | 12:27 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Ive only ridden in Revups but I think the power falls off at high rpm enough to where I would shift early. If you can shift fast you may want to see if hitting 4th at say 6600tpm's helps your times-although for 90% of people leaving it in 3rd will be the better option. Id shift at redline for 1-2 and 6800 for 2-3....try diff shift points and see how it goes, look at how much mph th ecar is picking up 2nd 1/8 mile and compare runs next time.
Old Apr 24, 2006 | 12:35 PM
Ruff Z's Avatar
Ruff Z
Cool, thanks for the pointers. IIRC, I'd be banging the rev limiter in 3rd for the last 100ft or so if I don't shift to 4th. I can shift pretty quickly. My whole problem was launching that night as there was gravel on the track from the rally cars, and then the track cars from earlier that day. Crappy drag strip I tell you!
Old Apr 24, 2006 | 01:15 PM
first350's Avatar
first350
Do you mean that you don't get into 4th gear by the end of the 1/4 mi?
Old Apr 24, 2006 | 01:38 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Some NA Revups dont....I get past stock redline in 4th Ill be in 5th next time out but thats OT.
Old Apr 26, 2006 | 12:15 AM
JunJTan's Avatar
JunJTan
Current mods-
Utec
Nismo Catback
60'........2.231
330'......5.996
1/8.......9.048
mph......81.07
1000'....11.650
1/4.......13.867
mph......101.72
60'........2.172
330'......5.932
1/8.......8.998
mph......80.77
1000'....11.620
1/4.......13.929
mph......98.31
what rpm did you launch at? Off topic, I live in portland too, i thought pir closed until this summer, what's the drag schedule, is it still Saturday late night drag?
Old Apr 26, 2006 | 08:36 PM
Ruff Z's Avatar
Ruff Z
Over 2500 I bet with the rpms slowly raising prior to launce, I didn't focus enough. I was way too burned out from the huge wait.
Yes, fri/sat late night drags. www.portlandraceway.com
Obadabot
Jun 18, 2023 11:31 PM
SharX59
Sep 27, 2015 09:23 AM
