Drag NHRA, IDRC, IHRA, NDRA
Will these wheels fit?
Old Dec 29, 2006 | 03:03 PM
QuicksilverZ33's Avatar
QuicksilverZ33
Default Will these wheels fit?
http://store.summitracing.com/partde...5&autoview=sku
16 inch rims
8 inches wide
4.5 inch back spacing
4.5 lug pattern
0 offset
i have non brembos
Old Dec 29, 2006 | 05:21 PM
Kenk2's Avatar
Kenk2
Professional
Yea they should fit no probs
Old Dec 29, 2006 | 05:40 PM
Mazinger Z's Avatar
Mazinger Z
I'm guessing these are for daily driving right?
Old Dec 29, 2006 | 11:45 PM
QuicksilverZ33
Not for daily driving, I intend to mount drag radials on them. Just for the rear so Im just buying 2 of them...
Kenk2...Thanks
Old Dec 30, 2006 | 01:20 PM
QuicksilverZ33
I actually found a good deal on all four wheels but im debating whether to keep the 2 extra for the front or sell them...
Old Dec 30, 2006 | 01:29 PM
Ianmtx's Avatar
Ianmtx
lol if someone got those for daily driving it's be pretty stupid.
Old Dec 30, 2006 | 02:28 PM
I am assuming that this is a standard wheel with the major portion of the wheel tucked under the car. Backspace is an unusual measurement for the 350Z. It means inner edge of wheel to mounting surface.
Look at the 17x8 OEM wheel. Half the width is 101.6mm + 33mm offset = 134.6mm backspace.
16x8 inches with 114.3mm backspace. This wheel will be 20.3mm closer to the fender. That will be OK.
The question that I have is the center bore: 3.27inches. Is this OK for the 350Z?
Old Jan 1, 2007 | 01:19 PM
QuicksilverZ33
I hope so, i just bought them lol
Old Jan 1, 2007 | 01:53 PM
priscilla ls1's Avatar
priscilla ls1
Im sure you could go 15's in the rear if you wanted.
Old Jan 1, 2007 | 02:01 PM
QuicksilverZ33
Does the center bore really matter on our cars...they're centered by the lugs...right?
Old Jan 1, 2007 | 06:05 PM
For street wheels hub-centric rings are preferred. For drag racing no big deal. If the bore is perfect or a little to big you are OK. If the bore is too small, then you will not be able to mount them.
Old Jan 2, 2007 | 12:25 AM
QuicksilverZ33
I believe the center bore of 3.27 will be a little bigger than the stock 17's because ive measured them and the 17's are a little under 3 inches diameter on the center bore....so i guess i should ok with these wheels...thanks for all the input guys...
Old Jan 3, 2007 | 04:14 PM
QuicksilverZ33
Well...I bought these wheels..they fit just fine....I bought four of them like I said...and Im selling 2 of these new in the marketplace...if anyone is interested...
Obadabot
Jun 18, 2023 11:31 PM
350z82
Oct 1, 2015 06:25 PM
