Drag NHRA, IDRC, IHRA, NDRA
trap speed problem or question!
Old Mar 2, 2007 | 02:43 PM
keznevin's Avatar
keznevin
i shift from third to forth at appx. 6800 rpm. I'm running 295 35 r18 firestone fire hawks.
Old Mar 2, 2007 | 04:54 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
With a 2005 Touring 6sp, how are you shifting past the stock redline, which is 6600? Do you mean 5800?
Old Mar 2, 2007 | 06:03 PM
zluver's Avatar
zluver
I went to the track this weekend after finally getting all my ducks in a row. I have a new tire and rim setup so my first couple runs weren't up to par. About a month ago I went to the track and ran a 13.9 at 100. Since then I have added uo crank pulley, custom 10.5 trackrims with 295 35 r18 firehawk tires, spl differential bushings, and strup headers. I know that the car is not running as effecient as it can the utec is on the way. this weekend i ran 13.6 at 99. My trap speed has never been over 100 since i've had the car. Has anyone elses car been like this? It a 2005 touring 6sp with 34000 miles. the car weighed 3350 with 1/5 tank of gas and me in it. I'm wondering if maybe the clutch is starting to let go or maybe the car needs a tune very bad. Any imput will be appreciated. oh yeah my friend has a 2003 with same mods as me but no headers and he ran 14 something at 101. on the same night
Thanks
Every car is different man, and every car will trap different speeds, but I have an 03 touring and I never trapped 100 until adding test pipes (after i/h/e, pullies). Even then I only trapped 100.5, but once I got the UTEC going properly I have now hit 102, and it has room to grow with more tuning. Dont worry so much about the trap speed as long as your times keep getting better
Old Mar 2, 2007 | 06:46 PM
kleefton's Avatar
kleefton
shifting at 6800 rpms on an 05 touring, which is not a rev up model?
How? Did you change the redline?
Try to shift at 6000rpms, I guess.
I think the first time I ran my car I ran 14.1@97.8 or something like that and I also saw about 19mph gain in the backhalf.
Then I went back almost a year later and ran 14.0@100.1mph and saw like 22mph in the backhalf.
Both times the car was bone *** stock.
I can't explain it, but maybe the engine was pulling timing on one of those nights. Heat soak might have been a factor too.
Old Mar 2, 2007 | 06:59 PM
Mid117's Avatar
Mid117
Hey kleefton,
you going to e-town tomorrow? let's do some runs, I got the '06
/sorry for thread hijack, back to normal posting.
Old Mar 2, 2007 | 07:14 PM
keznevin's Avatar
keznevin
I mess up i meant 5800. I have the shift light set there but i probally shift closer to 6000 6100 I had just put on the headers and the car seemed strong before that but that night it just didn't feel like it was pulling. I'm wondering if the computer was doing something weird. The car is running fat I think I know that it is putting sut on the back bumper by the exhaust. In my experience with the internal combustion engine that means it running fat. Fat( too much fuel) Well i guess we will see in a couple of weeks when i have the utec put on and tuned at sgp. I'll try to post the video this weekend.
Old Mar 2, 2007 | 08:48 PM
trey.hutcheson's Avatar
trey.hutcheson
That may be your problem right there. Shifting that early will hurt you, particularly by shifting to 4th so early.
I'm surprised you're trapping almost 81mph in the 1/8 by short shifting 2nd and 3rd.
Old Mar 2, 2007 | 09:34 PM
3hree5ive0ero
Retired Admin
What is your reason for shifting before 6000?
Old Mar 3, 2007 | 08:19 AM
keznevin's Avatar
keznevin
so yall push it to redline
Old Mar 3, 2007 | 10:57 AM
3hree5ive0ero
Retired Admin
Old Mar 3, 2007 | 04:10 PM
keznevin's Avatar
keznevin
well my car will not shift from 1st to 2nd if the rpms are higher than 6000. Won't do it nissan says there is nothing wrong with the tranny it doesn't grind it just will not go. but it will in every gear guess that is what became a habit.
Old Mar 3, 2007 | 04:15 PM
3hree5ive0ero
Retired Admin
That's weird considering you have an 05. I've heard and seen an earlier model of 03's having difficulty shifting from 1st to 2nd.
Well, anyway, be sure to shift at the redline, as that will return the best results with our cars.
Old Mar 3, 2007 | 06:05 PM
kuah@splparts.com's Avatar
kuah@splparts.com
Vendor - Former Vendor
Again, this track, compared to others, spits out better ET with slower trap. Otherwise, there's no way that other member can only do 14.0 at best at the track I go to with lots of mods, but can do 13.8 at the houston track with couple of mods.
It is not uncommon to see NA 350Zs end up slower with more mods, tuning the NA is a little tricky...
Old Mar 5, 2007 | 09:06 AM
trey.hutcheson
I have the same problem 1>2. Every gear after that is fine.
Old Mar 5, 2007 | 06:17 PM
kleefton's Avatar
kleefton
Originally Posted by Mid117
Hey kleefton,
missed that post.
PM me next time. I went to Atco on the day you were at Etown.
Old Mar 5, 2007 | 10:30 PM
bacalhau16's Avatar
bacalhau16
So to the OP, sounds like you have a bit of a rpm shiftpoint problem. So do you shift into 2nd, 3rd and 4th at about 5800 rpm? That would explain a lot about your time-slip. You do have a really good 60', but then up to the 1/8 and especially the last 1/8, it seems as though you are down on power/speed. Let us know how you do next time out.
issyz
Jul 2, 2017 03:04 PM
Vigman
Nov 17, 2015 04:34 AM
Mattg350z
Oct 2, 2015 06:51 AM
TrboMike
North East
Sep 28, 2015 06:36 PM
sccarally
Meet-Ups / Events (Texas)
Sep 27, 2015 01:06 PM
