Drag NHRA, IDRC, IHRA, NDRA
My initial 07 track impression, video....
Old Mar 22, 2007 | 02:30 PM
  #41
kleefton's Avatar
kleefton
Originally Posted by bboypuertoroc
A Vette is a different story. They have something like 315's out back stock. The Z only has 245's (GT's with 265's I believe).
Thank you.
There are too many other guys out there who are getting 2.2-2.3 on average.
At my track you aren't getting sub 2.0 on stock street tires in a Z. Even Vettes struggle to get under that.
The 07 is faster than the 03 no doubt, but in the 60' department it's the same. You look at the dynos and the hr is very similar to a de in the low rpms, which you are using when launching. That, and the DE cars are lighter, which would only help them launch better.
Track prep needs to be optimal to get sub 2.0 on a street tire, and of course the driver needs to be really good too.
Veetec, I'll be tracking your progress of course, would love to see you run faster. I just don't think it's probable, especially now that the weather is going to get warmer.
Old Mar 22, 2007 | 03:19 PM
  #42
jackie chan's Avatar
jackie chan
Originally Posted by kleefton
Thank you.
i pull 1.8s on a lowered crap mustang susp. the tires are as narrow or narrower than a z's and are cheap as hell and have lasted forever. its all about the feel and threshold. once you figure it out, sub 2.0s are easy on pretty much any track and in any moderate power level rwd vehicle. people say orlando speedworld is the worst out there, but i pulled mid 1.8s with ease on many occasions.
Old Mar 22, 2007 | 06:49 PM
  #43
warmmilk's Avatar
warmmilk
well the other guy mentioned his cobra, so i figured he was talking about street tires in general, but i competely see your point
and the guy with the mustang, mustangs have a solid rear axle, making launching easier than on the irs of the 350z, not saying a kid could do it, but it is considerably easier
Old Mar 23, 2007 | 10:03 AM
  #44
kleefton's Avatar
kleefton
man mustangs are so easy to launch even a caveman could do it
Old Mar 23, 2007 | 10:44 AM
  #45
jackie chan
thats why when i tell mustang guys with a 100+ passes at the track what i pull they **** themselves.
i need to take in another z soon so i can go pull some 1.9s or better at the track my first trip out
Old Mar 26, 2007 | 08:32 PM
  #46
warmmilk's Avatar
warmmilk
well they just be ****ty drivers.
solid axle: drag racing suspension, no wheel hop
irs: road racing suspension, wheel hop out the ***
not saying u can't drive, u obviously can drive, pulling a 1.8 on street tires isn't easy even on a solid axle, but it easier than with an irs
Old Mar 27, 2007 | 05:52 PM
  #47
Maybe's Avatar
Maybe
Thumbs up
That and a Mustang makes more power and torque under the curve. A 350Z has a smaller powerband and makes peak torque at a higher RPM. Basically, not enough revs = bog; too much revs = spin.
In addition, a solid rear axle is not always an advantage, especially in a Mustang. A heavy V8 up front, and not enough weight over the rear tires. I think a 350Z definitely has the advantage in the weight transfer department.
Old Mar 27, 2007 | 06:00 PM
  #48
HDPDZO6's Avatar
HDPDZO6
The VQ motor is no prom queen. She is fairly heavy. More than an LS1, not sure about compared to the Mustang motor though.
Old Mar 27, 2007 | 06:04 PM
  #49
bacalhau16's Avatar
bacalhau16
Actually I thought a VQ weighed about 280lbs bare. Jeremey had weighed one a while back and found that it was around the same weight as a VG30. I thought that was pretty impressive!
Old Mar 27, 2007 | 06:22 PM
  #50
HDPDZO6's Avatar
HDPDZO6
Will see if i can find the weight for a longblock..
Total weight for LS1 is 497/457 MT/AT. That is for a completely dressed motor. The LS1 block by itself is 107 lbs.
Old Mar 27, 2007 | 06:38 PM
  #51
Maybe's Avatar
Maybe
LS1s are lighter than the 2 valve gt motors, and they're way lighter than the DOHC 4V motors.
Your right though, the 350Z has nearly the same weight distrubution as a stang. The VQ motor is heavier than I thought.
Old Mar 28, 2007 | 02:06 PM
  #52
ZLadie2000's Avatar
ZLadie2000
Originally Posted by VeeTec
On the next run I did two quick tire cleaning spins. I then launched the car at 4K rpms, and upon doing so the clutch pedal would not come off of the floor, so I had to let off quickly and abort the pass. This was VERY disappointing as the 04 had never done this. When I let up on the gas the clutch popped back out.
Wow, VeeTec, I have experienced the same clutch issue. Once, when lauching and reving prob a little too much (she revs soooo easy) my clutch pedal got stuck on the floor, then popped back up after I let off the gas. I was like where did my pedal go. LOL I wonder if this will be a recall or what is going on...
Well I plan on going to the track on Friday. I dont have a lot of experience in a 6MT yet and just broke her in so I'm getting used to the car, but we'll see how I can do.
Old Mar 28, 2007 | 09:18 PM
  #53
VeeTec's Avatar
VeeTec
Yeah, I am pretty sure this is a design flaw on the 07, as several other 07 owners have had the same thing happen.
Old Mar 29, 2007 | 06:25 AM
  #54
jdifolco's Avatar
jdifolco
I feel this happen more than once when going into 2nd gear only. This clutch is weak sauce compared to my 04. Its easy to drive but it feels all squishy. I feel like my shifts aren't as fast as they used to be also... strange
Old Mar 29, 2007 | 07:39 AM
  #55
ZLadie2000's Avatar
ZLadie2000
I feel like the shifts arent fast enough either. The clutch sticking worries me, I dont want that happening at the track. How do we get this to Nissan...so they can fix these clutches? Other than that I love the car. Would you guys recommend power shifting my 07 tomorrow at the track??
Think a short throw shifter will help improve times? It feels like a long throw from 1st to 2nd to 3rd...
Old Mar 29, 2007 | 08:17 AM
  #56
jdifolco's Avatar
jdifolco
If its your first time out then no. I would focus on your launch and smoothness of your shifting. If its not your first time then yea if you want to go ahead.
Old Mar 29, 2007 | 08:46 AM
  #57
350Zenophile's Avatar
350Zenophile
Great focus with that insane noise-maker next to you...that has to take some getting used to. Been to the track a few times and that **** always breaks my concentration.
Old Mar 29, 2007 | 09:02 PM
  #58
VeeTec's Avatar
VeeTec
The shifting feels fine to me, other than the clutch.
apex locator
Jul 23, 2021 02:27 AM
350z82
Oct 1, 2015 06:25 PM
