Drag NHRA, IDRC, IHRA, NDRA
disapointed!!!
Old May 19, 2007 | 07:40 AM
ct350z's Avatar
ct350z
Default disapointed!!!
I finally got the chance to head out to moroso and try to get a few runs on my slicks. It seemed to be a beautiful day to race, temp was at around 70-80 and it was nice a windy and just a few clouds in the sky. I arrived at around 6:30pm and began to put on the slicks. I put the psi at 15 and head to tech area to get preped. Now this being my first time ever on slicks I wanted to take it easy the first run and work my way up on the launching, so I started my first run by lauching at 3k. The result being:
R/T: .259
60FT:2.020
330: 5.832
1/8: 8.979
MPH: 79.41
1000: 11.649
1/4: 13.898
MPH: 101.04
Now this being a weak a$$ run since im on slicks i figured it was do to the weak 3k launch. I've done these numbers on my 19's for god sake . So i decided to jump it up a notch and launch at 5k. The result being:
R/T: .340
60FT: 1.977
330: 5.737
1/8: 8.846
MPH: 80.24
1000: 11.486
1/4: 13.714
MPH: 101.82
OK, at this point i thought i had a great run until i got the timeslip. I just couldnt figure it out, wtf had happened that i didnt get a lower time? Yeah the 60ft was good but the e/t only dropped a notch and the mph stayed the same . Now i want you guys to know that i wasnt power shifting cause i really cant afford to blow my tranny, but i was shifting pretty dam fast imo. Maybe these slicks are to much for my set up? So i was so enraged in my own furry, i decided i was going to launch at 6k and take the car to hell with me, then god said no chris i dont want to see you go into a wall or something so he made it rain like hell for 3hrs straight and i had to change my slicks in the pooring rain and to add on top of that i stripped a stud and had to break the stud to get the lug nut off . I think im going to dump the z in a lake and call it a day......
Attached Thumbnails disapointed!!!-timeslip1.jpg   disapointed!!!-timeslip2.jpg
Old May 19, 2007 | 07:58 AM
R/T: .340
60FT: 1.977
330: 5.737
1/8: 8.846
MPH: 80.24
1000: 11.486
1/4: 13.714
MPH: 101.82
Bad air. The 350Z is picking up 21.6 MPH in the last 660 feet. You can perfect your technique with slicks, and do some great shifting, but you cannot overcome bad air.
BTW post that 13.71 second time slip here: https://my350z.com/forum/drag/233840-top-25-1-4-mile-times-for-tt-st-supercharger-nitrous-bolt-ons-stock.html
Old May 19, 2007 | 08:01 AM
STIFLL's Avatar
STIFLL
I went to Moroso last wensday and ran against a 350 with slicks and his times were:
60' 1.97
1/8 8.69 @81.23
1/4 13.52 @ 102.78
(just so you can compare your times with his) BTW don't know his mods it was a gray with black top.
Old May 19, 2007 | 08:13 AM
ct350z's Avatar
ct350z
by the way, i forgot to mention that its an 2hr drive for me to get there so by the time i got to race my car it had heat soak like a ****.
Old May 19, 2007 | 08:21 AM
ct350z's Avatar
ct350z
Originally Posted by davidv
R/T: .340
60FT: 1.977
330: 5.737
1/8: 8.846
MPH: 80.24
1000: 11.486
1/4: 13.714
MPH: 101.82
BTW post that 13.71 second time slip here: https://my350z.com/forum/showthread.php?t=233840
what do you mean by bad air david?
Old May 19, 2007 | 08:31 AM
The fancy term is density altitude and Air Density Index. Its a combination of Temperature, Absolute Barometric Pressure, Relative Humidity, Vapor Pressure, Dew Point, % Oxygen and Oxygen Altitude.
Old May 19, 2007 | 08:46 AM
ct350z's Avatar
ct350z
wow, you have this down to a science
Old May 19, 2007 | 09:53 PM
ct350z's Avatar
ct350z
here are some pics of the night:
Attached Thumbnails disapointed!!!-hpim4221.jpg   disapointed!!!-hpim4222.jpg   disapointed!!!-hpim4232.jpg   disapointed!!!-hpim4233.jpg   disapointed!!!-hpim4234.jpg
Old May 19, 2007 | 11:46 PM
bacalhau16's Avatar
bacalhau16
If Im not mistake, you posted up the pix of your new drag radials last week or so, and they were pretty large. Im not sure if this setup is all that ideal for the power your making and perhaps this could also contribute to your times.
I would say the same thing as Davidv as well. Only picking up 21mph in the last 1/8th isnt bad, but not going to gain you much. For some reason, your car was down a power a bit. I would agree that the DA probably wasnt that great. Hopefully you will have better times next time out.
Also with shifting, Im not entirely convinced that full throttle shifting in entirely necessary. I think the only time its truely noticeable is the 1-2 shift. For the 2-3 shift and the 3-4 shift, the cars momentum is greater and will not be as noticeable. The 1-2 shift though, the cars momentum will be noticed will a slower shift.
Old May 20, 2007 | 01:01 PM
diwun67's Avatar
diwun67
Keep practicing bro Damn those pics make me miss moroso
Old May 20, 2007 | 02:08 PM
ct350z's Avatar
ct350z
thanks dude, yeah moroso is a lot of fun but it seems that everytime i come out here it freaking rains . Im sure that the 2hr drive is killing my times cause of heat soak but i'll definitely keep practicing till it get some better times and satify myself .
Old May 20, 2007 | 02:44 PM
HDPDZO6's Avatar
HDPDZO6
A 2 hour drive won't cause heat soak, unless you are wot most of the drive.
Old May 20, 2007 | 02:50 PM
diwun67's Avatar
diwun67
+1, it's mostly highway driving, you're actually running pretty cool most of the way, unless you get stuck in stop and go traffic, then you're screwed. When you get to the staging lanes just pop your hood and let it cool down
Old May 20, 2007 | 04:37 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
yo man, you need to launch way way higher.
i launch around 6000 to 7000 all the time. nitrous. turbo , motor all of it.
heat them up good and launch like you are trying to break it...
Old May 20, 2007 | 06:08 PM
ct350z's Avatar
ct350z
thanks for the advice audible!!! i was planing on launching at 6k on my 3rd run but it started rainging .
HDPD350Z, I did catch massive traffic on the way there. When i popped my hood at moroso and touched the intake it was steaming hot aswell as the filter, the plenum was boiling hot
Old May 21, 2007 | 05:15 AM
drap660's Avatar
drap660
Not bad Tany... Just redline the facker out the box... Also I think 15psi could have been killing your top end... Next time try 20 psi first and work your way down 1 psi at a time...
Old May 21, 2007 | 05:29 AM
clipso 01's Avatar
clipso 01
nice 13.7, your in the top 25 i think
Old May 21, 2007 | 06:41 AM
ct350z's Avatar
ct350z
yeah i should have launched to break it like audible mayhem said. It was my first time on slicks so i wanted to take it easy. Next time i wont be so nice to my car...lol. My buddy dropped my psi down to 15 and i thought that might have been a bit to low but it was hooking like a **** . I went to countyline dragway on sunday but they were closed, do you know why?
Old May 21, 2007 | 06:42 AM
ct350z's Avatar
ct350z
yeah i know but its a pitiful time on slicks, i've done better on my 19's.
Old May 21, 2007 | 06:55 AM
ct350z's Avatar
ct350z
I also forgot to mention that there was 4 other z's out there and they all were running mid to low 14's. So i guess i shouldnt feel that bad!!! lol
