Drag NHRA, IDRC, IHRA, NDRA
The clutch pedal fix results are in.....
Old Aug 20, 2007 | 05:45 AM
JG 350Z's Avatar
JG 350Z
You know your problem sounds like something I've experienced, but all my stuff is aftermarket and I'm in an 05. I put in a JWT clutch/flywheel and my clutch would stick at around the half way point at high rpms after sitting in traffic. I bled it a few times before getting a new slave cylinder and braided line. I thought it had gone away but I still get a little sponginess.
Not as bad as before as before it would stick about half way up, I could even pull it back up with my foot. now it just feels a little spongy. Almost like there is air in the system, again I only get this feeling when its hot. I've been meaning to replace the fluid with some high-temp high performance stuff and re-bleed the whole thing. I've even got a little vacuum pump tool this time, hoping this works better than having someone pump it over and over again, just haven't got around to it. I might also try some insulating wrap all the way to the reservoir.
Its worth a shot to replace the fluid as that is the only thing I have not done. I've got some prestone brake fluid in it now.
Old Aug 20, 2007 | 01:21 PM
Pikespeak350Z's Avatar
Pikespeak350Z
i think its just me or the track i ran in was very badly prepped. Im running on street tires but my 60' times where no better than 2.2 and i tried slipping the clutch at 3.5k rpm's, tried 2.7k rpm's all sorts of things, i haven't dragged the car in a years but damn.
Old Aug 20, 2007 | 01:51 PM
Armitage's Avatar
Armitage
Originally Posted by ajcool2
Well he always seems to run faster than everybody else so I guess I'll say 13.4 is the average time for 07's. lol
No I'm willing to bet the average time is more like a 13.8 with the new VQ's. The average time I'd say with the older motors was around a 14.2. Warren is usually a good .4-.5 seconds ahead of the curve.
Old Aug 20, 2007 | 01:54 PM
blasian's Avatar
blasian
It isn't THAT bad. There were others who ran 13.7-13.8 with the previous VQ. Most of the stock Z's I've seen run here ran 13s but they're not on the site.
But I can't argue with VeeTec being one of the best drivers here.
Old Aug 20, 2007 | 09:00 PM
bacalhau16's Avatar
bacalhau16
Anyone with clutch issues, but still manages 1.9 60's on street tires, can not be consider an average driver, thats for sure.
Old Aug 20, 2007 | 09:17 PM
warmmilk's Avatar
warmmilk
+1
i couldn't even manage a 1.9 when my clutch was working fine, the best i could manage was a 2.0, then when the slave cylinder went all retarded and my clutch started slipping, i couldn't get better than a 2.1
Uriyo_
Sep 8, 2021 08:46 AM
07ZEKE
Aug 23, 2021 09:15 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
