Drag NHRA, IDRC, IHRA, NDRA
Wheel hop at the drag strip?
Old Oct 22, 2007 | 09:28 AM
350Z400rwhp's Avatar
350Z400rwhp
Default Wheel hop at the drag strip?
So I took my car to see what it would do in the 1/4 yesterday. I have the 18" stock rims with street tires on it. The car seemed to hook up really well at first but then just as it would gain full traction I got a fair amount of "wheel hop". I was still getting 2.08-2.1 60ft times but this wheel hop was pretty annoying. Is there any way to stop this from happening? Thanks
Old Oct 22, 2007 | 09:30 AM
zinctokki2love's Avatar
zinctokki2love
so what did you run??
Old Oct 22, 2007 | 09:35 AM
350Z400rwhp
14.2 @ 98 was my best. Never really had a "perfect run" though and it was about 80 degrees out. I did run a 14.3 @ 99 with a horrible launch (Dropped it way too high, got way too much wheel spin and bounced off the rev limiter that 60ft time was like 2.3). All I wanted was to break 100mph!
Old Oct 22, 2007 | 09:44 AM
itsjiggajames's Avatar
itsjiggajames
Those times are ok for having a crap launch... even the 60 fts are alright.. haha. but try preloading the clutch and feathering the throttle at the launch... preloading as in keeping the clutch right before the engagement point instead of all the way down and dropping the clutch causing shock. you obviously can shift, so with a good launch i'm sure you could be in the 14.0 or high 13s at 100mph.
Old Oct 22, 2007 | 09:48 AM
6ix's Avatar
6ix
just please tell me that you are not hitting the burn out box befor doing ur runs.......losers heat up street tires it dose nothing for traction......
Old Oct 22, 2007 | 09:51 AM
350Z400rwhp
Thanks James, that makes total sense. It did seem to be tough to control between too much spin and bogging it, your idea would at least allow me to engage the clutch exactly when I wanted to rather that at some point in the clutch travel. The hopping did seem to happen long after the initial launch and when the tires finally gained a lot of traction at the end of first gear. I just didn't have that slingshot feeling like I have had with my old RX-7.
Old Oct 22, 2007 | 09:52 AM
350Z400rwhp
Of course I drive around the water box lol
Old Oct 22, 2007 | 09:53 AM
350Z400rwhp
I just spin the tires enough to clean the surface off.
Old Oct 22, 2007 | 10:12 AM
Wheel hop has been addressed a dozen times in the drag racing forum, but thanks for asking.
Old Oct 22, 2007 | 01:36 PM
350Z400rwhp
I have tried searching for wheel hop in all of the forums but so far I haven't found a remedy for it. Is this just something that I will have to live with?
Old Oct 22, 2007 | 01:46 PM
See: https://my350z.com/forum/brakes-and-suspension/289718-wheel-hop-how-to-eliminate.html
Old Oct 22, 2007 | 03:17 PM
350Z400rwhp
Thanks David!
Old Oct 22, 2007 | 04:11 PM
Peak350's Avatar
Peak350
You just have to give the tires less power and a bit more clutch slip. If you get a balanced launch between perfect RPM/clutch slip levels you won't have issues, but it aint easy to nail every time.
Obadabot
Jun 18, 2023 11:31 PM
