Drag NHRA, IDRC, IHRA, NDRA
Need advice on what kind of helmet to get.
Old Dec 10, 2007 | 03:38 PM
Hexxum001's Avatar
Hexxum001
Default Need advice on what kind of helmet to get.
I already ordered a fire retatardant racing jacket and now I need a helmet per NHRA rules for Cali Speedway. I don't know how strict they are or how well they enforce the rules but I would rather be safe than sorry. I have my old helmet from back in the day when I used to drag my Civic (mid 13's was fast for a Civic 10 years ago ). But it has a M90 rating which is way old and expired. Does anyone have any suggestions on a good helmet that isn't too expensive? Please post pix if possible along with the make and model. Thanks!
Old Dec 10, 2007 | 03:39 PM
iStan's Avatar
iStan
ZR
Checkout HelmetCity.com Any SA2005 should be good to go. I'm sure David will respond soon.
Old Dec 10, 2007 | 03:52 PM
Hexxum001's Avatar
Hexxum001
Thanks bro, I will check that out. SA2005 are definitely good to go but those seem to be really pricey. I know that any M2005 or dot-218 helmets are also acceptable. Those seem to be more reasonably priced. There are so many to chose from though. I just wanted to get a feel for what people on the forum here get/prefer.
Old Dec 10, 2007 | 03:53 PM
iStan's Avatar
iStan
ZR
Eh, Pryotech $250, Zamp $200, Bells $350-$1000
Old Dec 10, 2007 | 05:25 PM
drsifu's Avatar
drsifu
i got my pyrotect helmet locally. i think it was under $150 with helmet bag.
you don't need anything fancy. most tracks still accept SA2000 helmets, but if you want to future proof yourself, get an SA2005 approved helmet.
didn't realize cali speedway required a fire retardant suit. i know your car is boosted, but didn't realize it was fast enough to need a suit.
Old Dec 10, 2007 | 05:29 PM
Sean's Avatar
Sean
No one said "Nut" , I am surprised.
Old Dec 10, 2007 | 06:25 PM
Hexxum001's Avatar
Hexxum001
I don't need a suit but because I have a SC on a car that didn't come with it OEM, they require just the jacket not the whole suit. The helmet is required for running faster than 13.99 on any vehicle.
Old Dec 10, 2007 | 08:36 PM
I wear a open-face Bell Mag-4. This is dual use: drag racing and autocross. For autocross I think it provides better visibility than a closed-face helmet. About $280.
I have been buying helmets for 30 years and would only trust my brain to Bell or Simpson.
Old Dec 10, 2007 | 10:05 PM
iStan's Avatar
iStan
ZR
^See, there's David.
Old Dec 10, 2007 | 10:56 PM
Hexxum001's Avatar
Hexxum001
Thanks for the info David. Do you have any hookups on helmets?? I need to buy really soon. The street legal drags are coming up at Cali Speedway at the beginning of Jan. and I need a helmet.
Old Dec 11, 2007 | 12:41 AM
Hoooper's Avatar
Hoooper
check jegs.com, they usually have good prices
Old Dec 11, 2007 | 07:07 AM
scotts300's Avatar
scotts300
SA2000 helmets are good for the rest of the year, but come 1/1/08 they are not.
Old Dec 11, 2007 | 07:10 AM
scotts300's Avatar
scotts300
Two things.
1) Someone mentioned using an "M" helmet, maybe it was you - check with the track you plan to run with, because some don't accept the "M" helmets.
2) If you need a jacket, then you also need a 5-point harness, NHRA roll bar, and driver's side door bar. The jacket is required for runs of less than 11.5s, which also brings the requirements I listed above. If you are between 11.5 and 13.99, you only need the helmet, not these other items.
The fire-retardant jacket is not a bad idea anyway.
Old Dec 11, 2007 | 07:11 AM
scotts300's Avatar
scotts300
Jegs, in my experience, is overpriced by 20% on most products across the board. *shrug*
Old Dec 11, 2007 | 07:26 AM
dkmura's Avatar
dkmura
General & DIY Moderator
I'd also mention that an open-faced SA-05 helmet is the way to go with a car that still has airbags. SCCA has found that airbag deployment with a closed face helmet has a higher risk of chin and jaw injuries. Not that you'll be road racing your Z, but the risks remain the same.
I'd also suggest you look at Impact racing helmets.
David Muramoto
Editor-in-chief
Nissan Sport Magazine
Old Dec 11, 2007 | 07:39 AM
I believe these expiration dates are valid:
NHRA Helmet Expiration Dates
-Snell 90.....Expired
-Snell 95.....Expired
-Snell K98.....1/1/2009
-Snell 2000.....1/1/2012
-Snell 2005.....1/1/2017
Reference: http://www.tmccc.org/rules2.html
Would someone verify? Thanks.
Old Dec 11, 2007 | 07:50 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
not 100% true. The single layer fire jacket rule was enacted last year. Its for all non-oem forced induction cars. So if you have an after market blower, then you are required to have a single layer fire jacket with a SFI 3.2A/1 rating. This rule is independent of ET or Trap.
Old Dec 11, 2007 | 08:45 AM
iStan's Avatar
iStan
ZR
That's what I was told at the track.
Old Dec 11, 2007 | 11:35 AM
Hexxum001's Avatar
Hexxum001
This is true. I confirmed it with Cali Speedway and it is also in the NHRA rulebook. So I need a helmet with a minimum M2005 rating and at minimum a fire retardant single layer jacket with a SFI 3.2A/1 rating. The helmet is for any vehicle going faster than 13.99 and the jacket for having an aftermarket SC on my car.
Old Dec 11, 2007 | 11:42 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
I know he needs the fire jacket. scott300 was saying he would need 5 point roll bar, door bar and harness which wasnt true.
The jacket rule is a new rule for after market FI that was put in place last yr.
