Drag NHRA, IDRC, IHRA, NDRA
Please enter your quarter mile times here!
Old Aug 8, 2005 | 09:42 AM
  #321
fowlman01's Avatar
fowlman01
Originally Posted by mrtomcat
he used a gtech that always takes about 2 seconds off...
They are pretty accurate, but that is on the street and not on a track and I don't believe any of it anyway.
Old Aug 8, 2005 | 09:57 AM
  #322
mrtomcat's Avatar
mrtomcat
there are too many variables on a 1/4 track to allow for accuracy with the Gtech.
I used to record my runs all the time to analyze my shifting and based on the gtech compared to timeslips I was always almost 2 seconds faster...
Old Aug 8, 2005 | 09:36 PM
  #323
kcauto03's Avatar
kcauto03
Originally Posted by Integrity
Care to join the Columbia Z's at Capitol this Friday?
138mph! Wow. Can you give us details on your build?
so let me answer ur q first...'
nismo cam...
3 angle valve job...
dual valve spring custom...
aebs custom kit:
ross 8:1 piston...
puater rods custom...
crank...
Bore: 96.5mm
Stroke: 86mm
greddy tt w/fmic
678hp w/16.8psi
Old Aug 8, 2005 | 09:39 PM
  #324
kcauto03's Avatar
kcauto03
w/ drag tire size 17x 13
w/o drag tire size 275/30/19
Old Aug 8, 2005 | 09:40 PM
  #325
kcauto03's Avatar
kcauto03
at final drive
Old Aug 9, 2005 | 04:30 AM
  #326
Alberto's Avatar
Alberto
Cranky FI Owner
Dude just stop your still full of $hit. You dont lose 20mph in trap speed because you ran on street tires, GTECH or track. And who the hell made you custom valve springs? Why do that when there are companies such as JWT and Ferrea that already make great set-ups for our cars? And the AEBS stroker kit is its own kit, you are saying they opted to use Ross Pistons and Pauter rods for your set-up? What offsets do you run on your 17X13 " wheels to not rub? Look Ill make you look dumber, what fuel system did you decide to go with to support all your power? Go do some more research on the Z and post your response
Old Aug 9, 2005 | 08:28 AM
  #327
VeeTec's Avatar
VeeTec
Originally Posted by kcauto03
fully build vq,
greddy tt kit,
w/ drag tire 10.9 @138
w/o drag 12.6 @109
test by g-tech
0-60 3.2
I about fell out of my chair laughing.
Go to the track and provide some real times.
Old Aug 9, 2005 | 02:39 PM
  #328
kcauto03's Avatar
kcauto03
1) i do my engine before aebs have the kit.... that is why is custom
2)all the spring shop will make custom spring....
3) if u dont belive me then u can race me any time u want (pm me if u want)
one thing ... i know g-tech is off a little, but if u are on the nice road, u will have very close time
Old Aug 9, 2005 | 04:23 PM
  #329
mrtomcat's Avatar
mrtomcat
go to a NHRA sanctioned track, run and post the timeslips and no one will laugh at you until then you're on your own...
Old Aug 10, 2005 | 03:47 AM
  #330
blubyu's Avatar
blubyu
I'll repeat myself, you do not lose 29mph just from switching rubber.
Old Aug 11, 2005 | 01:10 PM
  #331
Miraclekidjr's Avatar
Miraclekidjr
14.35 @ 99.1
9.37@78.0
2.28 60'
92 Degrees
38 PSI .....I need some advice
Old Aug 11, 2005 | 01:27 PM
  #332
fowlman01's Avatar
fowlman01
Originally Posted by Miraclekidjr
14.35 @ 99.1
9.37@78.0
2.28 60'
92 Degrees
That is pretty normal for a stock Z...........lower your tire pressure and work on your launches.
Old Aug 11, 2005 | 01:39 PM
  #333
Miraclekidjr
Do you think I can get close to 13's with lower temp and tire pressure?
Old Aug 11, 2005 | 01:59 PM
  #334
raptorbh12's Avatar
raptorbh12
definitely. also try to put a bag of ice on your plenum between runs. It gets scorching hot and with ice you can lower your intake temps alot and it really helps. youd be suprised.
Old Aug 11, 2005 | 02:04 PM
  #335
fowlman01's Avatar
fowlman01
I did with a heavy touring model and a 5AT.
Old Aug 11, 2005 | 02:10 PM
  #336
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
You can get into the 13s with good weather and some good driving without lowering your tire pressure at all.
I ran 13.92@101mph with a 2.04 60' stock in 95 degree heat.
In nice cool 55 degree weather I ran 13.68@103mph with a 2.09 60' also stock.
Old Aug 11, 2005 | 02:14 PM
  #337
Miraclekidjr
thanks for the input...ill see what happens tomorrow when I go and I'll post
Old Aug 12, 2005 | 06:58 AM
  #338
Miraclekidjr
Ok... It's a mixed emotion day, lowered the PSI to 31
1/4 - 14.2 @ 95.5
1000' - 11.9
1/8 - 9.2 @ 78.6
60' - 2.2
I had a 2.1 60' but I mashed 2nd gear like some homestyle potatoes. I decided to take her in after that
Old Aug 12, 2005 | 07:12 AM
  #339
fowlman01's Avatar
fowlman01
1/4 - 14.2 @ 95.5
1000' - 11.9
1/8 - 9.2 @ 78.6
60' - 2.2
You are getting better. I run 25# HOT.
Old Aug 12, 2005 | 07:18 AM
  #340
Miraclekidjr
Ya, I was just testing how much PSI would do difference..Next week I'll go out and see what 25 can do me
