Drag NHRA, IDRC, IHRA, NDRA
First time at the track with my '03 Touring Z
Old Oct 24, 2008 | 06:17 AM
kleefton's Avatar
kleefton
Once you start making a lot of power the Z is not exactly a drag queen. Look around, I mean all the Twin turbo guys are still running 13s on street tires even with 400wp
Old Oct 24, 2008 | 08:56 AM
tylerxfire's Avatar
tylerxfire
right, don't pay any attention to all the other ones who have drivers who can drive that are running 12's and 11's all day, there are many z's just supercharged bolt on in mid 12's, so i don't know what you are saying. It doesn't counts when someone can't put the power down. tellin you now once i am vortech 400whp after this winter i will def. be in 12's easily. i have no doubt about it no matter what anyone says.
Old Sep 21, 2009 | 09:37 AM
t0mills's Avatar
t0mills
Just went to the strip in Tulsa yesterday for the Import Faceoff.
I only got to run twice though, so I was a little disappointed. My first run was a test to see how it would hook. Armed the nitrous for third gear, then shut it off.
13.03 @ 106mph
Next run, I dropped the pressure in the slicks down to 16psi.
Full nitrous off the line and through all gears. Let off around the 1000' mark because my bottle pressure was low... No heater unfortunately...
I coasted through to a 12.1 @ 108mph.
My 60' time was a 1.64, which felt really nice coming out of the hole.
I was planning to run 1 more time with 1000psi bottle pressure, but it never happened... I ended up waiting too long.
I know i will be breaking 11s next time. I will post up the slips and videos later on.
My setup is:
03 350z
Popcharger
ACT Clutch and Flywheel
26x9-15 Hoosiers
104 octane
NX Nitrous kit - 62n jet and a 35f jet
-Tim
Old Sep 21, 2009 | 09:40 AM
t0mills's Avatar
t0mills
Forgot to mention that as long as it's not raining tomorrow, I will be dynoing with my setup.
-Tim
Old Sep 21, 2009 | 09:44 AM
03threefiftyz's Avatar
03threefiftyz
That's a big shot on a stock block z.......good luck on 11's. Doesn't seem like it will be too tough if you are coasting to a 12.1.
Old Sep 22, 2009 | 11:56 AM
t0mills's Avatar
t0mills
Did the dyno run today.
Off the bottle I put down 247hp at the wheels.
On the bottle I put down 360whp and 418wtq.
Not quite what I was looking for on the HP side, but more torque than I thought.
My air/fuel ratio was 11.0 - 11.2 across the board. I think i'm going to step the nitrous jet up a little bit to lean it out and make more power.
-Tim
Old Sep 22, 2009 | 12:16 PM
03threefiftyz
What type of dyno?
Old Sep 22, 2009 | 01:09 PM
ajcool2's Avatar
ajcool2
Interesting I've noticed alot of people running 100 shot untuned. Are you planning on tuning it anytime soon? Makes me want to get my nitrous installed. Also what type of gas were you using when you dynoed?
Old Sep 22, 2009 | 01:19 PM
t0mills's Avatar
t0mills
That was on a dynojet.
I was running 104 Sunoco unleaded. I'm going to be stepping the nitrous jet up a little bit, and getting a bottle warmer. My next trip to the track is planned for Oct. 9th.
I'll post up vids of Sundays races, as well as the dyno pulls as soon as I get a chance to transfer them to my computer.
-Tim
Old Sep 22, 2009 | 01:31 PM
03threefiftyz
Just FYI.......looking at his jet sizes it is more along the lines of a 150shot.
I have also been contemplating a 100 shot or just biting the bullet on a FI set-up.
Old Sep 22, 2009 | 01:47 PM
ajcool2's Avatar
ajcool2
Oh ok now the coasting through with a 12.1 makes sence. Ive had my kit for years and havent installed it yet. Ive seen Z's run 100 shot with no issues but I'd be really scared about 150 shot.
Old Sep 22, 2009 | 01:50 PM
03threefiftyz
Me too (in terms of being nervous about a 150 shot).......it crosses that 400 wtq barrier that is in my mind a no-no on stock DE. That is not too say it will instantly blow up, but it is beyond my comfort level.
Old Sep 23, 2009 | 05:02 PM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
I ran high 11s on 18in DOT tires with my APS kit on the stock motor.
"ALL THE TWIN TURBO GUYS ARE STILL RUNNING 13's" ....this guy cracks me up.
Old Sep 23, 2009 | 05:14 PM
03threefiftyz
Old Sep 23, 2009 | 05:21 PM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
-Tim
Is this on stock ignition timing? If so, I'd be very wary of leaning it out much past about 11.5:1.
Old Sep 23, 2009 | 06:32 PM
tylerxfire's Avatar
tylerxfire
i too ....11's on 17" DOT tires
liqalu04
Jan 2, 2022 12:58 PM
Dsowe
Feb 17, 2021 10:38 AM
Jambo016
Sep 16, 2016 01:08 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
