Drag NHRA, IDRC, IHRA, NDRA
Want to run 295/35/18 DR's - what rims??
Old Oct 29, 2008 | 01:33 PM
brady's Avatar
brady
Default Want to run 295/35/18 DR's - what rims??
I know I'll need a 10" - 12" rim, but what offset? I have the stock brembo's if that matters?
Thanks
Brady
Old Oct 29, 2008 | 02:01 PM
M3ANMACHINE's Avatar
M3ANMACHINE
+22 offset I believe would work. I'd say an 11"-12" rim
Old Oct 29, 2008 | 02:09 PM
scotts300's Avatar
scotts300
I run an 18x10.5" +43 with a 15mm spacer. You could go with or without the spacer. Do you need tires? I was looking to sell my 295/35/18 BFG DRs, as I bought a set of MT ET Streets.
Old Oct 29, 2008 | 02:16 PM
brady's Avatar
brady
Yes, but shipping will kill me (Ontario, Canada)
Old Oct 29, 2008 | 04:00 PM
blktrack350's Avatar
blktrack350
no need for 295's on a n/a just extra weight. some 265 m/t et street will hook great for you
Old Oct 29, 2008 | 04:41 PM
That a pretty big wheel. Do you intend to do any competition racing? Have you looked at wheel restrictions?
Old Oct 29, 2008 | 07:31 PM
bacalhau16's Avatar
bacalhau16
Yea, thats a really big tire. If you only intention is drag racing, and your gonna stay N/A for a while, 295 is overkill. You could fix your camber a little more, and bring it closer to 0, not at 0 but closer to 0. With that, even a 245/45 DR will do just fine. We arent talking about mass amounts of power. Your just adding weight and at 295/35 I believe your adding a little diameter as well which will slow gearing.
Old Oct 29, 2008 | 09:21 PM
scotts300's Avatar
scotts300
Actually, a car set-up more for drag racing would have a tad of positive camber. When the car launches and squats, the tires go inward. This way you can end up dialing in nearly 0 camber to maximize the contact patch for going straight.
295 is not overkill. The BFG DRs are more of a street radial. They are not as sticky as a Mickey Thompson tire, which would be overkill with an 11" tread width. The MTs have a huge sidewall to provide squat and stick, so you need less rubber. The BFG DRs don't have nearly the same sidewall.
Old Oct 30, 2008 | 09:19 AM
Nealoc187's Avatar
Nealoc187
BriGuyMax runs that size on his 18x9.5" 5Zigen FN01RCs. Used to have them on his 10.5" Volk SF-Winnings. I think that tire is probably overkill for your power level, but they definitely look cool having huge steamrollers out back.
Old Oct 30, 2008 | 02:50 PM
98intrigue's Avatar
98intrigue
Scotts300, where are located?
Old Oct 30, 2008 | 09:23 PM
scotts300's Avatar
scotts300
Northern Cali. Cross-country shipping is about $50 if you're interested, and if so, let's take it to PM.
ablaine
Nov 29, 2016 10:13 AM
