Drag NHRA, IDRC, IHRA, NDRA
what's the best tire setup with brembos
Old Mar 6, 2009 | 04:12 AM
marra23's Avatar
marra23
Default what's the best tire setup with brembos
hallo mates, help needed. i am currently installing a gt37r kit with occasional drag racing in mind. given my location i am limited in choice and wanna be 100% sure before buying. in what i gather 16' min for clearing the brembo's but which rims and tires would be best. i can get 300zx 16 but what tires. planing on switching my 19's at the track so just as well go full slicks but what will fit.... don't wanna roll fenders.
Old Mar 6, 2009 | 04:49 AM
16 inch wheel with an offset similar to what you are running now should be OK. But why risk a poor fit. Why not 17 inch wheels to clear oversized rotors?
Members who appreciate replacing rear axles run 9.0 inch slicks.
Old Mar 6, 2009 | 09:10 AM
marra23's Avatar
marra23
so if i go with 17, what tires would you suggest?
Old Mar 6, 2009 | 09:46 AM
A drag radial.
Old Mar 6, 2009 | 10:16 AM
marra23's Avatar
marra23
A drag radial.
thanx, I'll check what's available locally.
Old Mar 8, 2009 | 06:02 PM
txshldm's Avatar
txshldm
B8BB8B88
I am making 444whp with my 35r and have no problem with my Mickey thompson et street 2's. They even make them in 18's. Look on vette or supra forums for good reviews on drag radials, I have found that most use these.
Old Mar 9, 2009 | 12:01 AM
marra23's Avatar
marra23
i am currently looking for rx7 rims or 17's, but so scearce around here.... and then fit some of these http://www.mickeythompsontires.com/s...ETStreetRadial
Old Mar 9, 2009 | 10:48 AM
scotts300's Avatar
scotts300
I have two of those for sale, but they are 295/35/18.
Just FYI - the 300ZX TT rear wheels (16x8.5") are an excellent selection for drag wheels; however, they will not fit over the stock rear Brembos without notching the splines on the wheel.
Old Mar 9, 2009 | 02:37 PM
txshldm's Avatar
txshldm
B8BB8B88
This is the tire you want. The plus side on these as a drag setup is that you can drive them to the track.
Old Mar 10, 2009 | 01:19 AM
marra23's Avatar
marra23
300zx i could probably get, just curious what the use of those splines. how much do you notch away. does this make the rim weaker?
Old Mar 10, 2009 | 08:18 AM
scotts300's Avatar
scotts300
Not really notch "away" but more of a rounding in the contact area. A little dremel and you're set to go.
Old Mar 11, 2009 | 04:27 AM
marra23's Avatar
marra23
thanx, i assumed tires would be available locally but no. i can get the rims but the tire is a big headache now....just can't find anything suitable locally. closet i got was mt 225 16's and at $400 a tire. crazy
350Z_Al
Oct 29, 2020 07:44 PM
