Drag NHRA, IDRC, IHRA, NDRA
Heading out to the track tomorrow.
Old Apr 6, 2009 | 08:11 PM
*Boose*'s Avatar
*Boose*
Default Heading out to the track tomorrow.
Been trying to run my 06 since the day I bought it and finally have the opportunity tomorrow. I've raced at the track many many times so no noob here but never with a RWD.
Any advice on the launch? From what I've practiced I've seen pretty minimum wheel spin launching from 4-4500 rpm and side stepping the clutch. Would that be correct for the track? Also powershifting, how much of a beating can this trans take? Assuming every powershift engagement is smooth as butter?
I've done searching but not many true answers came up from my experience at the track.
Old Apr 6, 2009 | 09:05 PM
03threefiftyz's Avatar
03threefiftyz
You guys must have great track prep.....I tend to launch at about 2800-3000 and I try to be pretty easy on the trans. I say just go out there and give it hell to see what it likes and doesn't like. It will tell you what it likes and reward you with solid times. Good luck....Be safe.
Old Apr 7, 2009 | 04:46 AM
You will figure out the difference between front and rear wheel drive right away. As soon as the tires "bite," weight will shift from the front over the rear tires. That’s the time to hit the gas.
Old Apr 7, 2009 | 07:45 AM
*Boose*'s Avatar
*Boose*
Yea our track prep is ridiculously good. But they say that Atco is one of the fastest tracks in the country so we will see. But thanks for the replies.
Old Apr 7, 2009 | 08:13 AM
S8ER95Z's Avatar
S8ER95Z
Atco has many records ... sea level and great prep..you should see some pretty good times. Best of luck!
Old Apr 7, 2009 | 04:04 PM
*Boose*'s Avatar
*Boose*
So I just got back. Ran with alittle above 1/4 tank with no spare and carpet. I could do alot better out there. Pretty much runs went like this:
1st run: Sucked because off the line I spun and the clutch stuck to the floor typical in the 350Z's, but basically that's it.
Tire Pressure 40 both sides
Launch 4k Slipping the clutch
60' 2.306
1/8th 9.830
MPH 77.64
1/4 14.776 (haha, didn't mean to make 350Z owners look so bad)
98.54 mph
2nd run: Launched at 2500 dumping the clutch. Clutch once again stayed on the floor.
60' 2.703
1/8th 9.687
79.88
1/4 14.554
101.42 mph
3rd Run: Dialed in Tire Pressure to 20 psi and launched at 3500 rpm slipping the clutch.
60' 2.336
1/8th 9.306
79.55 mph
1/4 14.191
101.01 mph
4th run I had the same setup as the 3rd run but dumped/slipped the clutch at 2500 rpm. Hooked really good.
60' 2.157
1/8th 9.066
79.85 mph
1/4 13.948
100.85 mph
After the 13.9 run started to rain a bit so I left. Given the same track conditions as today, better clutch, and tire setup I believe I could do a 13.4-13.5 pass. Just need to slip the clutch a little more for that 1.9 60'. I'm still trying to improve the run though. My mph seems slow should be able to pull off a 101-102. Might try and play with shift points was shifting at 6900 almost 7k.
Old Apr 7, 2009 | 04:16 PM
0jiggy0's Avatar
0jiggy0
why were you running such high pressure at first? Good progress.
Old Apr 7, 2009 | 04:36 PM
tylerxfire's Avatar
tylerxfire
launching at 4 grand is way to high on street tires....i launched at the track at like 2800-3000 depending on the track hooking, and feather it out but im dumpin it pretty quick and all into it and power shifting from 2nd to 3rd and 4th...went 2.1 60ft. with a 13.7 at 101 (03z just intake)...work on the shifting and launching
Old Apr 7, 2009 | 04:43 PM
*Boose*'s Avatar
*Boose*
Reason for the high tire pressure was I wanted a quick baseline run and actually forgot to dial it down. Not much in the shifting department to improve on since I'm powershifting. I figured it's all in my launch. Need some better tread and a better clutch. If I can't slip the clutch then a 2.1 60' is the best I can do unless I get a magical run in there.
Tylerx: on that 13.7 run what was your 330', 1/8 time and mph? Let's see where my car is slowing down at.
Old Apr 7, 2009 | 04:46 PM
tylerxfire's Avatar
tylerxfire
ill check the slip one sec....
Old Apr 7, 2009 | 04:50 PM
03threefiftyz
Nowin-what are your mod(s)? If any.
Old Apr 7, 2009 | 04:53 PM
tylerxfire's Avatar
tylerxfire
i guess it was a 2.097 60ft.
2.097 60ft. street tires on my 19's 03 DE z with just intake 6spd.
5.830 330ft.
8.913 1/8th mile
80.35 mph 1/8
11.564 1000 ft. mark
13.798 1/4 mile
101.22 mph
Old Apr 7, 2009 | 04:56 PM
tylerxfire's Avatar
tylerxfire
highest mph i pulled with that setup was 102 one time and the eighth mile mph was 81 mph usually it was 101 with 80mph eighth...im boosted now and going to the track saturday the 18th of this month with the mickey thompson et streets on as long as its nice out...can't wait
Old Apr 7, 2009 | 05:01 PM
*Boose*'s Avatar
*Boose*
Just a pop charger with no heat shield. Got lazy didn't want feel like making holes.
Yea that extra .1 60' helps the ET a lot. But good luck at the track.
Old Apr 7, 2009 | 05:58 PM
Good work. You will get the first 60 feet figured out.
Old Apr 8, 2009 | 04:32 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Nice improvement, at least you hit 13's the first time out, better than most can say.
Old Apr 8, 2009 | 05:16 AM
S8ER95Z's Avatar
S8ER95Z
x2 to Alberto...
Not bad for a first time out... the clutch slip is key... I have a bit more torque on hand but I've had really good luck around 2200 rpm and a long slow release off the clutch. Of course I also don't have to fight my pedal sticking to the floor so that definately sucks.
Get out there again man and I think you can hit those mid 13s.
Old Apr 8, 2009 | 08:32 AM
ajcool2's Avatar
ajcool2
Good job man.
Old Apr 8, 2009 | 09:34 AM
Brrcats's Avatar
Brrcats
good job, 40 psi is kinda high isnt it? I keep mine around 32-35 typically for daily driving
apex locator
Jul 23, 2021 02:27 AM
