Drag NHRA, IDRC, IHRA, NDRA
Advice on preloading a Manual...
Old Apr 7, 2010 | 05:38 AM
jblz's Avatar
jblz
Default Advice on preloading a Manual...
as the title says...does anyone have some good advice for preloading a manual transmission at the drag strip.
From what I know, its just depressing the clutch just a slight bit while staged. Is there a better way?
thanks
Old Apr 7, 2010 | 06:55 PM
jblz's Avatar
jblz
none huh
Old Apr 8, 2010 | 06:57 AM
scotts300's Avatar
scotts300
Approach the lights and deep stage as much as you can (i.e. just barely move up enough to light the second set of lights). Pull the e-brake and then inch forward - that loads the drive train. You can do what you want from there, but I hold the e-brake up until the green light illuminates.
Old Apr 8, 2010 | 07:04 AM
jblz's Avatar
jblz
Thanks man, I'll try it out. I appreciate it
Old Apr 8, 2010 | 09:17 AM
scotts300's Avatar
scotts300
No problem. I made 5 passes last night doing it this way.
Old Apr 8, 2010 | 02:08 PM
bluezee's Avatar
bluezee
I do the exact same thing. As you bring the revs up be careful not to roll through the lights.
Old Apr 8, 2010 | 03:06 PM
scotts300's Avatar
scotts300
Precisely why I had to start holding the e-brake until I gave 'er gas.
Old Apr 8, 2010 | 04:54 PM
jblz's Avatar
jblz
Thanks guys.
Old Apr 8, 2010 | 06:50 PM
209Z33's Avatar
209Z33
so that your secret
Old Apr 8, 2010 | 10:05 PM
scotts300's Avatar
scotts300
Originally Posted by 209Z33
so that your secret
Haha. Just to keep the car from moving after preloading the drivetrain so that I don't bust anything!
Old Apr 19, 2010 | 05:21 PM
rrmedicx's Avatar
rrmedicx
Do you also use a 2-step feature? If so does that play into your loading up at the line at all? My 2-step is activated when either the clutch is depressed or the brake pedal. I do however have a brake cut-off (Pin 101) switch in place, but my 2-step cuts the power, even when ONLY the clutch depressed. It holds the power down until the clutch is fully released. Then after releasing the clutch completely it allows me to boost as high as I want (based on adjustable boost setting).
I guess its a ProEFI fail safe.
Old Apr 19, 2010 | 10:47 PM
fowlman01's Avatar
fowlman01
Didn't you move anyway?
Old Apr 20, 2010 | 08:07 AM
scotts300's Avatar
scotts300
On my friggin' last run, yes, I did move and red lit by -0.081s. Why can't there be a small channel to hold one of the tires staged there to keep one from rolling? Stupid inclined track (or stupid front-heavy car or stupid wind). Shall I go on? I have 1000 excuses queued up.
Old Apr 20, 2010 | 08:27 AM
bigslim350Z's Avatar
bigslim350Z
don't burn up the clutch when preloading.......
Old Apr 20, 2010 | 10:02 AM
fowlman01's Avatar
fowlman01
How about stupid driver?? I thought you were one of those heel and toe experts. I think it was the wind that night.
Old Jun 22, 2010 | 09:42 AM
350z-bra's Avatar
350z-bra
what RPM do you hold it at when you let go of the ebrake?
Old Jun 24, 2010 | 05:44 PM
Mike@Blackline's Avatar
Mike@Blackline
this
Old Jun 25, 2010 | 09:45 AM
350z-bra's Avatar
350z-bra
Originally Posted by Mike@Blackline
this
this?
Old Jul 1, 2010 | 02:31 PM
spnall4's Avatar
spnall4
Y so SrS!
^^^ I believe he has the same question as you.....
Old Jul 1, 2010 | 02:39 PM
ajcool2's Avatar
ajcool2
That
norrix420
350Z Roadster
May 23, 2022 05:11 PM
liqalu04
Jan 2, 2022 12:58 PM
user 62082028
Southern California
Jul 28, 2017 11:47 AM
BumbleZee
OZOC (Orlando Z Owners Club)
Sep 26, 2015 01:00 AM
