Drag NHRA, IDRC, IHRA, NDRA
Mickey Thomson, Radial or Not
Old Apr 4, 2011 | 09:19 PM
OldManZ350's Avatar
OldManZ350
Originally Posted by krazy4
If you are gonna run a specific track tire, there is no reason to use a drag radial/bias et street. If you are going to drive to the track and not want to swap tires, then a drag radial/bias et street is the way to go.
There is at lease 1
Running in a Class that only allows a DOT Tire, That is the reason these tires were made it the first place.
If you are going Bracket Racing or just test and tune, then you're right.
Old Apr 4, 2011 | 09:30 PM
OldManZ350's Avatar
OldManZ350
DR's love heavy preload....
And DR's Do Not like a Shock Load, thats when they break loose and spin.
The ET Street has a much softer side wall and works better with a stick car.
Another advantage of the ET Street VS the Street Radial on a 350Z with IRS, is that you will get Full Contact of the Tire, with the Radial you will get 75% at best, unless you adjust out your camber
Old Apr 4, 2011 | 09:32 PM
03threefiftyz's Avatar
03threefiftyz
I think 75% is a bit low, but the IRS is always going to be an issue. DR's are not as easy on driveline parts as slicks, though, that much I agree with you on.
Old Apr 4, 2011 | 10:11 PM
OldManZ350's Avatar
OldManZ350
Well with my car I have -3/4* camber.
275/60/15 DR's have a 9.50" tread, only making contact on 7.50" max
9.50 x 79%= 7.50 max.
Ya, you're right a little low
Old Apr 5, 2011 | 08:05 AM
str8dum1's Avatar
str8dum1
ya, in the heavy g35.
it takes 10 mins to swap tires at the track. my little trailer was 160$, hitch mount was like $150. hoosier has a nice DOT cheater slick that would be another option to the MT
Originally Posted by Alberto
Was that in your G?
Old Apr 5, 2011 | 09:23 AM
krazy4's Avatar
krazy4
Originally Posted by OldManZ350
There is at lease 1
Pretty sure he isn't running in a drag radial class. I could be wrong though. lol
Preloading the car does not shock the tires as much as just dumping the clutch.
Old Apr 6, 2011 | 11:15 AM
tylerxfire's Avatar
tylerxfire
the et streets will be much more forgiving for the stick car and will be easier on driveline parts and will outperform the old tire..get ur *** to the track
Old Apr 19, 2011 | 04:51 AM
ffwturboZ's Avatar
ffwturboZ
I can wait to see those kinda 60' times on my timeslips...I'll be happy with 2.0' for now....good info guys!!
Old May 31, 2011 | 06:22 PM
djamps's Avatar
djamps
Good info guys.
Old Nov 14, 2011 | 09:15 AM
djamps's Avatar
djamps
Loving my E/T streets. No more wheel hop or spin.
booger
Drag
Jul 1, 2004 02:28 PM
Melissa
Drag
Apr 23, 2004 05:47 PM
daking350
North East
54
Mar 30, 2004 11:20 AM
daking350
Drag
23
Mar 19, 2004 07:56 PM
