Drag NHRA, IDRC, IHRA, NDRA
First Time on 1/8...Decent?
Old Apr 19, 2014 | 04:54 AM
waldo36's Avatar
waldo36
Default First Time on 1/8...Decent?
So last night was pretty awesome. First time going to a strip, and I was more excited about the seeing the other cars than focusing on my launches, haha. So the weird thing about last night was my very first pass ever was my fastest of the night. I ran an 8.99 @ 80.03mph. The closest I got to that was a 9.0061 @ 79.63mph, on my 2nd run. I had one more run that was 9.08 @ 79.39mph, but all other 6 runs were between 9.23 (slowest) - 9.05 (4th fastest) with all of those times running between 79.24-79.63mph.
I only have the 60ft time from my 1st run, because before my 2nd run the 60ft timer got taken out. My 1st run 60ft time was 2.11. This wicked old school stingray with ITBs launched hard sideways, took out the 60ft while still sideways, brought it back, hammered it again, and still ran a 7.80 @ 108mph....Fing nuts.
I know it's my launches that are killing me. I was only staging it around 1700-2000rpm, and then just easing into it by about the 60ft, then mashing it once I knew I wouldn't spin the tires. Do I need to stage a little higher, or learn to ease into the throttle faster w/out breaking traction?
Old Apr 19, 2014 | 03:51 PM
Toneloc's Avatar
Toneloc
whats your 60ft times? you have vlsd?
Old Apr 19, 2014 | 04:21 PM
herrschaft's Avatar
herrschaft
Fix the traction issue then work on consistency.
Old Apr 19, 2014 | 06:02 PM
Bmurray350z's Avatar
Bmurray350z
Is the car stock? If not, what are your mods? and what tires? etc etc
Old Apr 19, 2014 | 06:54 PM
waldo36's Avatar
waldo36
If you were there, you would know...hahaha. But naw, since I only got the one run in before the 60ft timer got taken out, my 60ft was 2.11.
Full bolt-ons, tuned by Jon @ Z1, transgo valve body, factory vlsd, V1 track wheels 18x8.5 running 235 Bf Goodrich sport comp-2. I didn't mess with tire pressure, because I didn't want to let too much out. First run, didn't do a burn out. Every subsequent run I did a little burn out, just enough to clean the tires off. But I agree with the guy I was talking with, that sometimes street tires don't respond well to several runs because they'll gradually pick up more oil from the track.
Old Apr 19, 2014 | 07:05 PM
npr350z's Avatar
npr350z
Do you have the 3.3 or 3.5 vlsd?
Old Apr 19, 2014 | 07:11 PM
waldo36's Avatar
waldo36
5ATs have 3.3
Old Apr 19, 2014 | 07:50 PM
npr350z's Avatar
npr350z
Well I didn't know if you swapped it in or not, what's the auto shift at?
Old Apr 19, 2014 | 08:28 PM
waldo36's Avatar
waldo36
What do you mean shift at, redline or top speed per gear? Redline is the same at MT, and I'll have to dig to find top mph per gear for AT.
Old Apr 20, 2014 | 06:18 AM
Bmurray350z
My old 04 z was auto and had similar mods and ran 8.8 @ 81.4 mph for reference
Old Apr 20, 2014 | 06:46 AM
waldo36's Avatar
waldo36
So then it sounds like my launch and 60ft needs some work.
I found this and plugged all the info in...but it just doesn't seem correct.
http://www.dragtimes.com/gear-ratio-...tton=Calculate
Obadabot
Jun 18, 2023 11:31 PM
SharX59
Sep 27, 2015 09:23 AM
