Stillen stage 3 1/4 mile time slips
http://home.comcast.net/~imspud/13_sec_run.mpg
an email quality video from our sony cybershot. Not the best video, but you can hear the sound of the stillen pretty well.
I'm estimating 340 at the wheels. I dynod before the intercooler was hooked up at 305. The sportz test dynod 338 on 91 octane, so I should be at least there with 93
Not a whole lot of wheelspin. Best 60' times were dropping the clutch between 5 and 6000 rpm. I started out at 3000 rpm, but was getting 2.3 60' times. boy, when launched from 5000, those e.t. streets really hook!
#1 GREAT 60 ft times...
#2 what size ET's you running
#3 what air pressure?
#4 did you feel alot of SWAY going down the track??I almost hit a wall, but it was windy and I was running 13lbs...
26x9.50 or 10.50, cant recall right now. 12secZ would know, I got them from him. started out at 17psi, then went down to 15 then 13. This was the second time I used the tires, first time they were unbalanced and felt really floaty. I got them balanced and today they felt great. The real difference though, I think, is my data systems spoiler. I think it creates more downforce than the stock one, because after I installed it, the ride on the highway got a lot bumpier in the rear.
Nice times, and 60ft's. I am surprised with an estimated 340 @ wheels you are not trapping higher though....I'm only 1 mph down on your 12.87 run...makes me wonder what I could do with some e.t. streets. And yes I know that these tires will affect your traps, but I would have still thought you'd be around 107-109 mph.
Originally posted by SKiDaZZLe
mike:
first off, good runs!
second, what does the stage3 come with over the stage 2 (which i believe is 7lbs, i/c'd..).
m
mike:
m
I hear they are also working on a stage 4 with 8lb pulley and new injectors
Its quite possible that I may have been letting up before the finish line. It wasn't well marked and the light at the end was burned out on one side. I think I went to the end, but aside from the race against mjedens, I was always first. His trap was 115, but I think they had about 430 to the wheels, or so someone told me.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
