Drag NHRA, IDRC, IHRA, NDRA
How to shave .3 or .4 off your 1/4 time
Old Apr 13, 2004 | 01:43 PM
blubyu's Avatar
blubyu
Originally posted by zillinois
I'm pretty sure a 1.8* - 60' would be out of reach for my Toyo's. My best is 2.06 with the factory setup. So if I add the NISMO lsd, 3.9 final drive and wider, stickier tires I think 1.9*'s are a reasonable expectation. I think that would put me in the low 13's. I don't know, but I'll find out in the next few weeks. ;-)
I appreciate all of your input greatly. It helps moderate my expectations. I'm putting $4,000 bucks into the car, so it better hook!
If it doesn't spend about $300 more and get some stickies
Old May 7, 2004 | 11:22 AM
03redlineZ's Avatar
03redlineZ
I ran a 13.8 @104 with injn intake and stillen exhaust with bald tires and a 2.2 60' which is terrible im wondering how i am trapping so high i raced another Z with an intake and he got a 13.9 @100 even stock my car was trapping at 101mph cant explain it i even started from an idle because i was doing bracket racing and my tires were bald again my toyos are on there way but i thinki should be able to pull into 13.6 no prob with a much bette launch what do you guys think I am a crazy power shifter and i know how to launch my car so it shouldnt be a problem
Old May 15, 2004 | 06:36 PM
zillinois's Avatar
zillinois
Outlook on the Toyos looks pretty good. Today, in 58 degree weather, I got a 1.96-60' and an et of 13.64. I was having a hard time getting the tires warm today. Had about 5 runs at 13.75 with 2.0*-60'. Worst of the day was 13.91. Once the temps get over 68, I think it will be a different story. Maybe the Toyos will be capable of high 1.8*'s. 13.4 seems pretty doable if so.
Old May 15, 2004 | 09:19 PM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
WOW...that's awesome! What were your traps??
Old May 16, 2004 | 02:54 AM
zillinois's Avatar
zillinois
Thanks Brian. Unfortunately, I'm still trapping low. Trap was 101.43 on the 13.64 run. And my best trap was 101.52/13.74. Must find more speed. I'm just not sure where though. I wound all the gears out to redline.
I was satisfied with my 60' times though. I think the Toyo's will be a good tire because I was not able to consistently heat them up and I still pulled 2.09-1.96. I was doing a burn out and holding it as long as possible, but sometimes they just wouldn't get sticky.
Did you ever take your bike out there?
Old May 16, 2004 | 06:47 AM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
I'm really confused by your traps....your car should at least be trapping where I do.
I took the bike out there that one HOT weekend in the middle of april. Everyone was running REALLY REALLY slow....ran an 11.39@122mph with a 1.96 60' not bad...but not great...
Old May 16, 2004 | 07:58 AM
zillinois's Avatar
zillinois
You have an R6, right? That 60' could be a little lower, but that's a solid run. That was a crazy weekend, 88 degrees and 90 percent humidity. Ah, spring in Chicago.
I'm not sure what's up with my traps. I'm thinking about putting the factory ecu back in a seeing what happens. That's all I can think of. I'm sure the pulley is a plus and that only leaves the y-pipe?
Old May 16, 2004 | 08:46 AM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
I pulled a 1.90 60' on one of my runs...but I was short shifting (hadn't figured out perfect shift points yet) so I ran an 11.4@119mph...
The factory ECU sounds like a good idea. Have you weighed your rim/tire combo??? The one I was running at the track was 43lbs for the rim and tire. My summers are near 60lbs.
Old Jun 20, 2004 | 07:56 PM
rucorey's Avatar
rucorey
Default Watch Out - Falling Times!
Zillinois - Those times are really looking great! When is the next Byron run? I want to see the red monster with the new rubber.
I missed the Z day two weekends ago, I guess no one went?
Old Jun 21, 2004 | 02:52 AM
zillinois's Avatar
zillinois
rucorey,
Thanks, I'm getting the itch to go again soon. Next weekend is about the last weekend to go until the end of July. Have you been to autocross lately?
Obadabot
Jun 18, 2023 11:31 PM
SharX59
Sep 27, 2015 09:23 AM
