Drag NHRA, IDRC, IHRA, NDRA
My 1/4 Times
Old Jul 17, 2004 | 06:43 PM
zachcrosen's Avatar
zachcrosen
Default My 1/4 Times
About a month ago, I made my 1st trip to the strip. I have a 5AT. At that time, I had a Popcharger, test pipes and a grounding kit. My best time was as follows:
R/T 1.282
60 2.322
330 6.256
1/8 9.469
MPH 77.33
1/4 14.542
MPH 96.67
Last night, I went out again. This time I had the Popcharger, grounding kit, Test Pipes Kinetix plenum and Injen true dual exhaust. My best times were worse this time. My best time is as follows:
R/T 1.068
60 2.308
330 6.389
1/8 9.686
MPH 74.26
1/4 14.848
MPH 95.75
I am also running on stock tires. Could someone give advice as to why I ran worse times. I ran 6 runs last night and I only had 1 R/T over 1.0 and this was with my best run. My 1st time to the strip, I had 4 runs and my R/T's were all over 1.00. I have roughly 15k miles on the car, if that matters. I realize that elevation, air temp, etc makes a difference, but damn my times suck a$$!!
Zach
Zach
Old Jul 17, 2004 | 06:46 PM
JonsilvZ's Avatar
JonsilvZ
Put it all back to stock. I run in the 13s stock.
Old Jul 17, 2004 | 07:49 PM
zzzya's Avatar
zzzya
My guess is that your ECU is not adjusting properly to your mods. If you look at your numbers you are loosing mid to high rpm power. The ECU could be over compensating, making the car run rich or it may be too lean. Are your tailpipes black or fairly clean? Also, as you mentioned there are many other variables including temp, humidity, how much gas you have in your tank etc..... One thing to try is to go out again, make a couple runs, reset the ECU and make as many more runs as possible to see if the ECU might be causing the issue. Of course going to a dyno shop with A/F plotting is the best way to see if you need tuning.
Old Jul 18, 2004 | 10:52 AM
menace_z's Avatar
menace_z
i have the same mod you got and i do
R/T .243
60 2.235
330 6.038
1/8 9.134
MPH 80.58
1/4 14.013
MPH 102.33
put down ur tire psi to about 27,take out ur spare and jack,hold on ur brake to about 1800 and launch it
Old Jul 18, 2004 | 09:49 PM
Kuzmeista's Avatar
Kuzmeista
a/t is the problem
Old Jul 18, 2004 | 10:13 PM
shimz350z's Avatar
shimz350z
a/t is not the problem.
remove the poppycharger listen to jonsilvz lol....i had some problems..i feel my car breath better now.
Old Jul 19, 2004 | 05:30 PM
JonsilvZ's Avatar
JonsilvZ
Originally posted by Kuzmeista
a/t is the problem
Ignorant remark from a guy who drives a celica. I know this guy with a auto 350Z who had just an intake and exhaust. Running mid 13s. Anyway I hit the fuel cutoff when I got 13.9 cost me .1sec
Old Jul 19, 2004 | 06:06 PM
Street Visionz, Inc.'s Avatar
I'll be going to the dragstrip on this coming Saturday. Hopefully I'll nail some mid 13s. zachcrossen- you should be hitting 14 flat stock at sea level. Try running it in manual mode and lauching a lil below 2K. Torque brake it.
Old Jul 19, 2004 | 07:36 PM
Kuzmeista's Avatar
Kuzmeista
Not ignorant... shifting fast and clean will definitely get better times than an auto on the same day at the same track with same mods... and im in the market for a z.... i know my car isnt fast just adding my .02... i will definitely get my hands on a 6spd...
Old Jul 20, 2004 | 05:40 PM
JonsilvZ's Avatar
JonsilvZ
What does a AT got to do with his times that are slow? He is not comparing it to a manual. Anyway I know this guy with a 6spd 350Z who cant drive for ****. He made a ignorant remark "I could take you because I have an auto". Good thing we didnt bet any $. I smoked him many times. It wasnt even close.
BTW manual mode is definitely quicker then full auto. About .2 sec in the 1/4 mile. Because it shifts quicker and has a higher rev limiter(6900rpm). 6600 is the actual redline.
Old Jul 21, 2004 | 12:26 PM
Kuzmeista's Avatar
Kuzmeista
That was pretty much my point... didn't say anything about the type of driver behind the wheel of a m/t
Old Sep 9, 2004 | 11:25 PM
mbonanni1856's Avatar
mbonanni1856
Just so you know, your reaction time does not affect your 1/4 mile time. It just means you waited a little longer to start the clocks, thats why you can have a little quicker ET than your opponent and still lose because he left before you.
Old Sep 10, 2004 | 05:30 AM
KY350's Avatar
KY350
Default Re: My 1/4 Times
Sounds like you may be loosing a lot of time at the launch. Your new mods may be giving you more power / torque at your launch revs now that before the mods, causing excessive wheelspin. May be worth considering lower your launch rpms by 100 at a time until you get a reasonable start.
Zach
Zach
Obadabot
Jun 18, 2023 11:31 PM
SharX59
Sep 27, 2015 09:23 AM
