Drag NHRA, IDRC, IHRA, NDRA
11.6@121 et streets
Old Sep 8, 2004 | 09:30 PM
03_ppw350z's Avatar
03_ppw350z
Default 11.6@121 et streets
well i went back to the track and ran the car only change were the e.t streets i have the same boost setting as when i ran my 12.5@121 on stock tires i thought i was gonna loose mph but i did not loose any. heres how it went
0.8457 reaction
1.8471 60ft
5.0315 330ft
7.5951 1.8
96.11 1.8mph
9.7840 1000et
11.6364 1/4et
121.82 1/4 mph
Old Sep 9, 2004 | 05:40 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Congrats, thats sick well into the 11's. Now work on getting that 60ft down a little bit, with all the power you have you should be low 1.7's maybe high 1.6's....arent you on a stock clutch still? Awesome that you didnt lose any trap...
Old Sep 9, 2004 | 05:58 AM
rednezz's Avatar
rednezz
Default Re: 11.6@121 et streets
0.8457 reaction
1.8471 60ft
5.0315 330ft
7.5951 1.8
96.11 1.8mph
9.7840 1000et
11.6364 1/4et
121.82 1/4 mph
That is an awesome time and trap! Are you running at Rivercity?
Old Sep 9, 2004 | 10:05 AM
03_ppw350z's Avatar
03_ppw350z
i ran at rivercity. alamo is already being shut down. im am on a star spec clutch. stage 3 i believe
Old Sep 9, 2004 | 10:24 AM
rednezz's Avatar
rednezz
How much boost are you running? How high can you boost your engine since you have low compression pistons? I wasn't aware they were closing down Alamo. I always prefered Rivercity over Alamo. I haven't been to the drags in a long while, but next time I go maybe we will run into each other.
Old Sep 9, 2004 | 10:39 AM
03_ppw350z's Avatar
03_ppw350z
10psi on these runs i will go up to 17 when i get my fuel injectors and 22 on race gas
Old Sep 9, 2004 | 11:18 AM
ravaz's Avatar
ravaz
Good times. congrats!
Old Sep 9, 2004 | 01:11 PM
redline350ZZ's Avatar
redline350ZZ
U going for the 10 sec?????
Old Sep 9, 2004 | 01:41 PM
jackie chan's Avatar
jackie chan
i want your z....
that is all
Old Sep 9, 2004 | 06:39 PM
basam350z's Avatar
basam350z
Nice times. Are you still using the emanage?
Old Sep 10, 2004 | 12:23 AM
03_ppw350z's Avatar
03_ppw350z
still using emange and get this with the stck greddy map lol. it does not lean out i guess since my compression is so low??? im not going to get the car tuned until i get the injectors. and yes im going for 10's car has an 11.4 the way it sits but once i put more boost i know it will go tens!
Old Sep 10, 2004 | 02:02 AM
mjedens's Avatar
mjedens
Good run!!! Would you mind sharing what type of fuel (return) system you're using. I noticed you have the pump and regulator.
Old Sep 10, 2004 | 10:02 AM
03_ppw350z's Avatar
03_ppw350z
im using the same regulator pump and regulator everyone on the site is using its mounted on top of the tank
Old Sep 10, 2004 | 10:39 AM
redline350ZZ
How is the rear of your Z holding up?????
Old Sep 10, 2004 | 12:51 PM
03_ppw350z's Avatar
03_ppw350z
just fine no problems at all
Old Sep 10, 2004 | 01:09 PM
bluefish's Avatar
bluefish
Congrats, nice time and trap speed...
keep up the good work....
EnjukuRacing
Sep 30, 2015 06:55 AM
codek
Sep 28, 2015 03:03 AM
