Drag NHRA, IDRC, IHRA, NDRA
Need tips on using Drag Radials
Old Nov 8, 2004 | 03:10 AM
Bahraini350Z's Avatar
Bahraini350Z
Question Need tips on using Drag Radials
I'm going to the strip soon and I have bought myself a couple of Nittos 555R (street slicks) 245/50/16.
What is the best way to use them and get a good grip without killing my RPM?
Old Nov 8, 2004 | 06:35 AM
Bahraini350Z
Oh yeah.... I'm running stock clutch and flywheel.
Old Nov 9, 2004 | 01:27 PM
Bahraini350Z
Come on guys, I need the info!!!
Old Nov 9, 2004 | 02:07 PM
jackie chan's Avatar
jackie chan
i would read briguys post in this forum. he explains his launch on drs
Old Nov 11, 2004 | 03:11 AM
j's350z's Avatar
j's350z
First off I would see those tires and get a better size... A 245/50/16 is almost an inch lower than stock... You are going to have a hard time launching no matter how sticky they are... I honestly believe that your would probably net the sames times as your stock tires.... IMHO..... I am not a professional racer but I have a decent track record to my credit.. I probably have about 50 passes down the track on my 350....
Jason
MRC Mototrsports
Old Nov 11, 2004 | 04:16 AM
RD99SS's Avatar
RD99SS
With those smaller DR's you will be shifting sooner than usual, which is actually a good thing, the Nittos need to be heated up pretty good in order for them to stick good, I would do a 2nd gear burn in the water box and roll out after a decent amount of smoke and then play with tire pressure a little until you know what is best for your driving
Old Nov 11, 2004 | 08:01 AM
Bahraini350Z
Thanks guys.
But, what do recon the tire pressure be?
Old Nov 11, 2004 | 11:52 AM
RD99SS's Avatar
RD99SS
A good rule of thumb when playing with pressures is get it low to the point where you start to bog and then bring up the pressure until you get a very slight spin...I would start probably around 20PSI and just use that rule of thumb until you find what is right for you
Old Nov 12, 2004 | 04:06 AM
Bahraini350Z
Thanks.... I'll try that.
Old Nov 30, 2004 | 08:07 PM
raptorbh12's Avatar
raptorbh12
ok now heres a topic i can give some good advice on. I own some Nitto 555R extreme drags and i have 275/45/17 on the stock rims. they are sweet for the track. I do a short 1st gear burnout to get em wet in the water area and then do a raging 2nd gear burnout til i reach the line and hit the brakes at the staging lights. AT this point your nittos should have some sweet grip. Do not drop the clutch because the hard gripping nittos will bog you down no matter how hard you drop. Let the clutch slowly out and then drop it, as you in an awd car. I dropped .5 in my 1/4 mile jusy by using those tires. Also keep your tire PSI around 15, it gives you maximum area without getting unstable at high speeds.
Old Dec 1, 2004 | 10:06 PM
Bahraini350Z
Sounds right to me, thanks
I used 15 psi and launched at 4000k
Old Dec 4, 2004 | 12:41 PM
Nastyboy's Avatar
Nastyboy
I too have the same tires on my 17's.
I run them at 15psi and launch at 3K rpm.
The tires gave me a night and day difference. And on the street, well, let's just say you'll know why they call them "cheaters".
Old Dec 9, 2004 | 08:46 AM
350_Z's Avatar
350_Z
Do you all heat them first? If so do you have to pull the brake fuse?
Old Dec 9, 2004 | 12:42 PM
Bahraini350Z
u need a good b-out with the fuse pulled
Old Dec 9, 2004 | 02:46 PM
raptorbh12's Avatar
raptorbh12
actually, i do 1st gear in water and then do a 2nd gear burnout til i reach the line and that heats em up just enough. i never pulled the brake fuse or never power braked. As long as you rev high enough in 2nd gear to make a nice clean burnout it should all be good.
Old Dec 14, 2004 | 01:23 AM
nastyZ's Avatar
nastyZ
I heat them "slightly". I remember even with the BF tires, the manufactures always recommend not to over do it.
So far so good. My tires, however, have gotten more street than track use. So I haven't been able to play with the pressure at the track or "warm" my tires differently to see a difference.
Old Dec 18, 2004 | 05:40 PM
JamRWS6's Avatar
JamRWS6
You just want a quick spin in the burnout box.....if you spin them too long you will kick water all up in the wheel well and it will drip down on the tires.
Old Dec 19, 2004 | 12:15 PM
simpley amaZing's Avatar
simpley amaZing
would that be with stock tires as well? or do I leave them at 35psi?
sales@czp
Sep 23, 2019 03:30 PM
nanotech
Oct 2, 2015 05:02 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
