Drag NHRA, IDRC, IHRA, NDRA
the Z's first time at the track.
Old Dec 2, 2004 | 12:46 PM
zpeed350's Avatar
zpeed350
Originally posted by ForceFed
Reason I ask is because I'm looking for a quiet exhaust ( I hate the way a 2 rotor sounds with a opened up exhaust) for my FD RX-7 and RS*R advertises that they have a very quiet exhaust.
Personally, I love the RS-R exhaust! What I really like about it was the design, it's basically as straight through as you are going to get. With the canister disign there are no baffles or anything, you see straigh through the exhaus can into the pipes.
But the exhaust is anything but quiet. If you run the exhaust with the silencers, it is a little be louder than stock. It sounds nice, and little throatier than stock.
With the silencers removed the exhaust really roars. I mean it's one of the loudest you can by. But it sounds nothing like the weed wacker sound you are talking about. It just really screams. It never rasps or breaks up at all, all the way to red line.
To give you idea:
stock exhuast = ~ 80 - 85 decibals (Sport Z magazine)
RSR w/ silencers = ~ 90 (from 50 ft away)
RSR w/o silncers = 115 decibals (from 50 ft. away)
Old Dec 2, 2004 | 01:02 PM
ForceFed's Avatar
ForceFed
Zspeed, thanks for the info. I guess I was thinking of the other RS*R exh, the EXmag for the FD. Its advertised as one of the quietest exh notes according to several places. More info here:
http://www.rx7store.net/index.asp?Pa...ROD&ProdID=772
Anyways, thanks for the input!
Old Dec 2, 2004 | 02:25 PM
VeeTec's Avatar
VeeTec
I had a 3" Greddy DP off of my T78, with a 3" Bonez MP, and a Gran Muffler custom mandrel bent 3" exhaust, that exited out of an Apex N1 canister.
Yep, it was loud, REALLY loud!
Old Dec 2, 2004 | 02:27 PM
zpeed350's Avatar
zpeed350
Yea exhaust for the Z is the ExMag GT II series muffler system. Which is the racing muffler setup. Alot more agressive.
Old Dec 5, 2004 | 09:21 PM
RedShft's Avatar
RedShft
Darril, i think youll be happy with the RSR Exmag for your car. when i was working on Erika's car i was thinking about this exhaust and heard sound clips of it, i loved it. actually i shouldve gotten it for her b/c the Greddy Evo 2 is TOOOOOOOOO quiet. but i didnt go with it because of the black muffler and i figured she wouldnt like it. but anywho, like zspeed says, the RSR exhaust for the Z is the GT 2 series which isnt the same as what you're looking for.
Old Dec 5, 2004 | 09:23 PM
RedShft's Avatar
RedShft
try a straight 4'' exhaust right out of a T78 on a 2JZ...that sounds pretty ****ing SICK! no muffler, no resonator, no cats....nothing. sounded like a camming 8 cylinder at idle, and like the gates of hell opened up at full throtlle
Old Dec 17, 2004 | 09:23 PM
southern_info's Avatar
southern_info
Today was my first time taking my Touring Z to the track after 3 wks and i still have the dealer tags on it...lol I ran some track that was shorter than a quarter mile and these are my times. Can you tell me what my quarter mile might would have been ? TIA
Reaction - .681
60- 2.471
594- 9.044
MPH- 76.32
660- 9.633
Old Dec 17, 2004 | 10:15 PM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Reaction - .681
60- 2.471
594- 9.044
MPH- 76.32
660- 9.633
something around 14.6-14.8....work on your 60ft time...
Old Dec 17, 2004 | 11:11 PM
ForceFed's Avatar
ForceFed
Reaction - .681
60- 2.471
594- 9.044
MPH- 76.32
660- 9.633
Generic formula for 1/8th to 1/4mi conversion, assuming perfect conditions and driving ability, you can estimate by pluggin your 1/8th into this equation:
(1/8th mi + .22) / .665
9.633 + .22 / .665 = 14.81 or thereabouts.
Old Dec 18, 2004 | 05:23 PM
southern_info
Yesterday i was launching at about 22-2600 rpm by dumping the clutch. I wouldn't give it no more gas until i knew that the tires were grabbing the road, then i would punch it. If you could give me any advice in to better my launch and lowering my 60 i surely would appreciate it. I really don't like the idea of the feathering the clutch thing i've been hearing because that will tear up the transmission. I need Help so i can beat this S2000 at the track that's been running 9.4 in the 1/8. TIA
Old Dec 18, 2004 | 05:42 PM
ForceFed's Avatar
ForceFed
If you are on the factory tires I would recommend slipping the clutch when you launch. Don't do a burnout, go around the waterbox, cut sharp back onto the track immediately after the waterbox to maximize the room you have between the waterbox and the staging beams then rev the car up, drop the clutch and spin the tires atleast 1 full revolution to scrub the pebbles and debris off.
Then stage the car. When you are ready just release the clutch a tiny bit until you feel it start to grab. DO NOT roll the car through the beams as you will redlight. Just hold the clutch at the exact position where its about to grab and then bring your revs up to where they should be. If this just test and tune its probably a .500 tree so leave when the second yellow bulb lights up. At this point don't drop the clutch. Just release it so the car starts moving but don't release the pedal completely, instead, give yourself some pedal room so that you are slipping the clutch out of the hole and also don't go wide open throttle. Practice this until you can leave the line without hardly spinning your tires. Practice practice practice! Rome wasn't built in a day.
Slipping the clutch is not going to hurt anything in your tranny. Clutch slip launches are actually easier on your tranny. The question is can your stock clutch disc take the repeated clutch slip launches.
Old Dec 18, 2004 | 05:50 PM
southern_info
WOW man that is crazy...thanks for the help
Old Dec 19, 2004 | 05:57 AM
VeeTec's Avatar
VeeTec
I wouldn't slip the clutch too much. A quick release is better. Too much will do your clutch in.
Old Dec 19, 2004 | 06:08 AM
ForceFed's Avatar
ForceFed
Vee Tec, glad you stepped in and said that. Thats why I said I wasn't sure if the stock clutch would handle alot of clutch slips. Some stock clutches are engineered to take alot of slippage abuse and others aren't. For example I know EVO clutches can only withstand a handful of clutch slip launches while my girlfriend's 04 Miata has survived countless 6000 RPM clutch slip launches. She literally has a stack of about 35-38 timeslips all via 6K clutch slip launches and the clutch is still like brand new. It's amazing.
Either way, good info. Southern, do what Vee Tec said and just keep practicing your launch. You should be able to get down into the 9.0s or high 8's in the 1/8th which I don't think the S2K will be able to do without some mods. Most importantly, have fun!
Old Dec 19, 2004 | 09:17 AM
southern_info
THANKS AGAIN MAN, those are the numbers i'm looking for. Imma be hitting a quarter mile track this week coming up. I've been practicing around here a little bit by doing this. I come to a complete stop, let off the clutch a little and holding the brake watching my rpm drop just a little to know i have a grip on the gear. Then i jump off the brake hitting the gas and release the clutch taking off alot quicker now. Thanks for all the tips man, imma post my quarter mile time to let yall know how i did this go around. I'm looking for that high 13sec quarter mile (stock)..i'm soo like determine...grrrrrrrr...lmao peace out til lata
Old Dec 22, 2004 | 10:53 AM
blubyu2k2's Avatar
blubyu2k2
Old Dec 22, 2004 | 10:54 AM
blubyu's Avatar
blubyu
350z's don't scare me . Let me know when you guys plan to go to the track again. I should have my $hit together by mid January and I'll be ready to roll.
Old Jan 7, 2005 | 10:31 PM
  #38
southern_info
Here's my update for my second time at the track with the Z. My best times tonight is as follows:
Tree 0.500
R/T 0.600
60' 2.220
590' 8.598
MPH 78.99
660' 9.168
Where do you think my quarter mile time would be now? I need help with my launch! I've been running 9.4 constantly. What are RPM are you lauching at and tell me how do you do it?
Old Jan 8, 2005 | 05:21 AM
  #39
ForceFed's Avatar
ForceFed
Tree 0.500
R/T 0.600
60' 2.220
590' 8.598
MPH 78.99
660' 9.168
That run would have been around a 14.11 at somewhere probably around 100-101.
Just use this formula. It gives you a good estimate for 1/8th to 1/4 mi conversions:
(1/8th mi ET + .22) / .665
Hope that helps.
Obadabot
Jun 18, 2023 11:31 PM
SharX59
Sep 27, 2015 09:23 AM
