Drift SCCA Formula Drift, Drift Showoff, Drift Session, Drift Day, D1 Grand Prix, Drift Nation
Need a tie rod replacement "how to"
Old Apr 18, 2008 | 05:35 PM
12AutoX's Avatar
12AutoX
Default Need a tie rod replacement "how to"
I just saw a DIY for Tein inner tie rods the other day, and now I can't find it to save my life. Anyone have a link?
Old Apr 18, 2008 | 05:37 PM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
its a rather large undertaking are you a somewhat experenced mechanic?
Old Apr 18, 2008 | 09:58 PM
12AutoX's Avatar
12AutoX
I've done suspension and BBK installs, among other things. Someone posted that it takes about 20 minutes per side, and you just need to get an alignment when it's done. I should have bookmarked it.
Old May 13, 2008 | 11:08 AM
JasonZ-YA's Avatar
JasonZ-YA
Its not hard...
jack up car....
get to wrenching...
install tein's.
grind off half of the steering stop...
Done..
- J
Old May 13, 2008 | 02:17 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
pretty much it..
Old May 28, 2008 | 10:23 PM
zeer0's Avatar
zeer0
Just got a pair of inner rods that i need to install soon. Going to be using stock outers. Do I need some special tool to get the outer tie rod off the steering knuckle? If so, can they be removed without damaging the outer boot?
Old May 28, 2008 | 10:47 PM
12AutoX's Avatar
12AutoX
I couldn't separate it. Fortunately, I was able to remove the inner tie rod from the rack, then just spin it off of the outer rod. Worked for me. I didn't need to cut the bumpstop, either. One note, when you are measuring the length of the new tie rod for alignment purposes, add the length of the "increased steering angle spacer" to your measurement. Otherwise, you end up with a lot of toe in.
aboodi
Oct 28, 2015 02:07 PM
350z82
Oct 1, 2015 06:25 PM
pr_350z
Oct 1, 2015 05:03 PM
