Drift SCCA Formula Drift, Drift Showoff, Drift Session, Drift Day, D1 Grand Prix, Drift Nation
B-ver's Build Thread
Old May 6, 2009 | 08:54 PM
  #101
AlexPfeiffer's Avatar
AlexPfeiffer
Thanks Jonathan
Worked on the motor, pretty much done with the dvd other then maybe getting a dyno shot when its finally running.
Old May 12, 2009 | 08:14 AM
  #102
Royal_T's Avatar
Royal_T
**Bump**
For update
Old May 12, 2009 | 08:17 AM
  #103
ATX350's Avatar
ATX350
Originally Posted by Royal_T
**Bump**
For update
+1
Old May 13, 2009 | 09:25 PM
  #104
AlexPfeiffer
Sorry, just been really busy. Had a few customer cars that needed some work done. Did a cage on a friends car over the weekend and thats almost done. I did put the motor in the car but still need to make the trans mount. I'll take some pics tomorrow.
Old May 13, 2009 | 09:26 PM
  #105
AlexPfeiffer
I did go to the track last week thursday for some fun and got to watch an s14 run over an arieo atom. That was cool.
Old May 16, 2009 | 07:25 AM
  #106
AlexPfeiffer
Last week went out to streets of willow. Lots of cool cars and cool people. I did get to watch an s14 kinda run over an atom. It was pretty interesting to say the least but I still cant find video of it.
Sorry I havent updated in a little bit. Been getting home real late and been spending more time on customer stuff then my own laitly. I did however get the motor in.
The famous Andy Yen ladies and gentlemen helping out with the turbo.
Wicked 1 on clublexus saw that I needed the stock guage cluster and sent me one. Thank You Wicked 1!! Pulled the insides of it out and made a backing plate out of carbon sheet, then had this tach from one of my old cars and figured why not have the most famous a biggest tach you can get in there. Took a little bit of work triming it out and I still feel fiberglass in my arms. More guages will be added but this is just a taste.
Picked up a new steering wheel from Sparco, and some seat brackets. Mounted the drivers seat and took it back out cause I dont want it to get too dirty just yet. Goes back to K&W Autobody in a couple days. Should have the paint finished and start working on the graphics soon.
Old May 21, 2009 | 08:11 PM
  #107
AlexPfeiffer
In the booth, spraying the frost.
Then clearing the front.
Got the car back in the shop
The frost that they used on the car is kinda like a metalic that you only see in certain light. You get that glittery look, just dont see the glitter. Here is a closer pic of the hood after and you cant even see it in the pictures but in real life it has a sparkle to it.
Also Casper was kind enough to kick down some of his coopers so I mounted those things up, threw the brakes on the car, and took off the shocks to check wheel fitment and such. Turns out these +1 offsets may be too aggressive for not having a widebody. It really stressed me out when I put the car down. Got a few options right now like change the wheels, run smaller tires, make all new control arms or mod the original ones. Only time will tell whats going to happen next.
Old May 21, 2009 | 08:46 PM
  #108
Royal_T's Avatar
Royal_T
Nice Alex, the car is really coming along. Can't wait to see what you have up your sleeves for graphics.
Oh and go smaller tires, with those aggressive wheels. You will have a little poke going on,which would look nice
Old May 23, 2009 | 09:20 AM
  #109
Nackers's Avatar
Nackers
What are you doing about steering angle?
I'm wondering cause my buddy has a SC and since the Z also has a simular setup, I was hoping we both could benifit from it. And since some company I spoke with said 3k for a setup on a Z, I'd kinda like to check my options.
Thanks.
Old May 23, 2009 | 10:48 AM
  #110
Royal_T's Avatar
Royal_T
+1 I also would like to know. I asked shop MAX if they had any Parts shop MAX Super Angle Steering knuckle for the Z33. And they said no. He said try tie rod angle spacers and cutting the bump stop.
Old May 25, 2009 | 08:51 AM
  #111
AlexPfeiffer
Parts Shop Max is right. Get the tein inner tie rods, cut the bump stops, and your going to have as much angle as you will get without coverting your lower control arms to something alot more expencive.
Old May 25, 2009 | 09:11 AM
  #112
Royal_T's Avatar
Royal_T
I thought that the tein inner tie rods are the same length as factory. And when you say cut the bump stops do you mean remove them or cut them down?
Old May 25, 2009 | 09:27 AM
  #113
03Z33's Avatar
03Z33
The long threaded portion of the inner tie rod that threads into the knuckle is same as stock.
The inner portion of the inner tire rod that threads into the steering rack is longer (more threads) with a spacer. This is what allows for more travel in the rack.
Safest thing on the bump stop is to grind down material as necessary. You can remove it to use a belt sander, then re-install.
Here's an old thread with more info:
https://my350z.com/forum/drift/13963...ter-pics.htmla
NOW BACK ON TOPIC! Let's see more pics
Old May 27, 2009 | 10:05 PM
  #114
AlexPfeiffer
More pics it is...
Working on the suspension, here is the angle with the spindles cut about an inch.
Worked on getting the front end together, I kinda want to run some zuse fasteners or something so I can take off the bumper faster, but those high beams are held in on the same bolts as the top of the bumper.
Went out to G&J and picked up all the fuel line fittings and such. Mr. Yen has some time laitly and is helping me with the build so we started on the fuel stuff. Ran the hard lines under the car.
We decided the best place to put the fuel pressure reg would be to kinda hide it pretty much under the intake mani. One word of advice if you ever work with Andy, keep him away from teflon tape!
Fuel pump and cell in the trunk. Not many other places to stick it.
Old Jun 2, 2009 | 08:56 PM
  #115
AlexPfeiffer
Sorry for the lack of updates. Without a working Tig, there wasnt much to do. Now that I can get back to welding, things should be going a bit faster. Finished up the intercooler and mounted it.
Here is a pic from last week when Andy and I were playing with the suspension. At this point the body kit would be on the ground.
Old Jun 2, 2009 | 09:19 PM
  #116
Royal_T's Avatar
Royal_T
Yea that is the perfect hight right there...I just love your whole color scheme..The wheels look really good
Old Jun 2, 2009 | 10:23 PM
  #117
SlideFox's Avatar
SlideFox
Nice!! Do you plan on running a surge tank setup??
Old Jun 3, 2009 | 11:27 AM
  #118
ATX350's Avatar
ATX350
Things are coming along nicely Alex! Looking forward to seeing this beast on the track.
Old Jun 3, 2009 | 09:24 PM
  #119
AlexPfeiffer
Thanks Guys!
Naw, no surge tank, just going to try to keep it topped off.
Started on the exhaust. Wasnt exactly sure how I should run it. The outlet on the turbo is 3.5" and the wheel is kinda tight in there. So was thinking of going 3.5 vband and up it to a 4" down pipe, then spit it to twin 3". Reason being is with the tight radius bends on the down pipe, it kinda needs larger OD to keep the flow. Then running twin 3", its just cheeper and easier to get 3" tubing and gives me more ground clearance.
Also started on the hot pipe. For more room I cut the outlet on the turbo and welded on a new end.
Old Jun 4, 2009 | 11:11 PM
  #120
AlexPfeiffer
Picked up some tubing this morning and got to work again. Made the intake pipes and had the windows put back in. The windshield was cracked before we took it out so needed a new one.
Then got to work on the hot side. Starts off as 2.75" and switches by the sway bar to 3" and goes into the intercooler.
Comes out the intercooler as 3.5" and then goes to 4" at the TB.
And from my friends at club4ag...
