Drift SCCA Formula Drift, Drift Showoff, Drift Session, Drift Day, D1 Grand Prix, Drift Nation
KPRace Steering angle kit!!! SWEEEeet!!
Old Feb 13, 2010 | 08:36 AM
JasonZ-YA's Avatar
JasonZ-YA
Nackers:
ya i agree.........I too have looked for steering knuckles at junk yards.....except every fool in DFW likes to front end wreck their Z...its nuts......i can never find good front pieces...
I found one, one time, but the yard wanted a rediculous price, cause they wanted it sold with all arms with it...
-J
Old Feb 13, 2010 | 09:15 AM
Royal_T's Avatar
Royal_T
Originally Posted by JasonZ-YA
??? You completely removed your steering stops?? do you make any inner wheel lip to compression arm contact???
check your compression arm for inner wheel contact...gouges!
-J
To my knowledge I am not hitting any thing. I will double check for you though.
Originally Posted by Nackers
I'm pretty sure that the spindle/knuckle will break before anything else in this kit will.
I've had some rough contact and haven't had any issues with anything but the front knuckle/spindle breaking. It's crappy cast aluminum and the ball joint mounting locations are pretty thin. Also, the upper section that connects to the A-arm is super weak as well.
But, they are only like $100 from a junk yard. I'm pretty sure with this kit that will be your only real concern. Everything else is just nit picking imo. Their kit looks beefy enough to overpower that knuckle. But, I would also try to stock up on knuckles like I am. Sucks breaking one of those at the track... trust me.
Yea I agree with Nackers,,, I think our weakest link is the spindle/knuckles. I plan on buying spares as well.
Old Feb 13, 2010 | 09:53 AM
JasonZ-YA's Avatar
JasonZ-YA
Unhappy
yeah, you haven't been to many drift events right??, so hopefully it isn't bad....but im guessing it is making contact....
Pics of mine: circled in red! blue arrow is my steering stop to show reference location.
I combat this with the use of spacers and alternating wheel sizes to keep my widest ones out back.
This is an old pic, but i have since smoothed it out and given it a generous radius transition. I constantly clean it and inspect for cracks........
I have spare compression arms as back ups...
-J
Old Feb 13, 2010 | 04:15 PM
MPD47's Avatar
MPD47
Jason, I had the exact same thing going on when I was first playing with angle mods. If you are running any kind of a decent sized wheel up front with steering mods you will be rubbing the compression arm!
Old Feb 13, 2010 | 08:29 PM
Royal_T's Avatar
Royal_T
Well ****, I'm going to check out tomorrow cause I most likely run the most aggressive fronts on here for drifting 18x11-2 or 18x10-8. But I never feel any thing at full lock..
Going to take pics tomorrow..
Old Feb 14, 2010 | 12:05 PM
JasonZ-YA's Avatar
JasonZ-YA
yeah, i have been dealing with it since day one..
-J
Old Feb 15, 2010 | 07:22 AM
MPD47's Avatar
MPD47
Haha, I meant that as a cautionary tale for others, not you
Old Feb 15, 2010 | 07:24 AM
JasonZ-YA's Avatar
JasonZ-YA
^ ya i got that.......
its the one real scary thing i worry about breaking...
-J
Old Feb 15, 2010 | 07:42 AM
MPD47's Avatar
MPD47
I'm way more worried about the knuckle breaking than the compression rod. Sure you'd got some odd play in the LCA, but if the knuckle breaks at speed you are DONE.
Old Apr 15, 2010 | 10:13 AM
Zorgazm's Avatar
Zorgazm
Im looking to purchase one of those kits, anybody else ready to pull the trigger so we can get that 20% off?
Old Apr 15, 2010 | 10:27 AM
aloh's Avatar
aloh
damn those look expensive...
Old Apr 18, 2010 | 05:28 PM
Nackers's Avatar
Nackers
I talked to them a while back and they said that their kit wasn't ready because some manufacturing issues. IDK if anything ever evolved from that.
Old Apr 18, 2010 | 07:23 PM
Zorgazm's Avatar
Zorgazm
The kits are ready, I just ordered one. Cant wait for it to arrive
Old Apr 18, 2010 | 08:48 PM
Royal_T's Avatar
Royal_T
^^ please take pics when they come and please give us a review on them... Thank
Old Apr 18, 2010 | 09:23 PM
theianmcdougall's Avatar
theianmcdougall
yea id like to see a pic of these installed and in action
Old Apr 18, 2010 | 09:31 PM
240tog35's Avatar
240tog35
X2 I'm with you on this
Old Aug 17, 2010 | 07:30 PM
genkilabs's Avatar
genkilabs
I have been searching around for info on DIY angle mods or a tutorial on cutting the steering stop. No luck so thought I'd bump this up rather than start a new thread.
I'm sick of getting to lock so quick when drifting and need to solve this, but I have some questions for you guys.
What was the end result of taking out the steering stop entirely, did you scrape? Also, if I cut them, how much should I cut off? Anyone have any pics of a nicely cut one? Finally, do I need to replace anything other then the inner tie rods? outers? Can I just put a 5mm spacer on the end of the stock inner, since it's basically the same thing?
Old Aug 17, 2010 | 07:57 PM
  #38
JasonZ-YA's Avatar
JasonZ-YA
You can get way better angle with what I mention in the drifting 101 sticky thread:
https://my350z.com/forum/drift/39963...ing-the-z.html
I answer everything your asking there with pics of steering stops cut as well...Read post 1 and 2.
J
Old Nov 11, 2010 | 11:39 AM
  #39
Twenty4's Avatar
Twenty4
sooo has anyone reviewed this or bought this? will wide low offset wheels be an issue with this kit like it can be with cut stops and tie rods? Im running wide low offset fronts and i have an 06, soo tie rods and cut stops wont really help me.....
Old Nov 11, 2010 | 11:45 AM
  #40
JasonZ-YA's Avatar
JasonZ-YA
^ I dont have it, but from those I have talked to, along with even looking at the pics on their site you can see that the wheels they use up front are not wide at all...
your best bet is to combat your issue with long studs and slip on style spacers up front....
I have multiple spacers for whatever wheels im running at the time...
If you want mad angle, this is your kit, but it doesnt seem to solve all the wide wheel issue.........
anyone else that actually have one comments? in for replies...
-J
