Drift SCCA Formula Drift, Drift Showoff, Drift Session, Drift Day, D1 Grand Prix, Drift Nation
Hydro ebrake writeup
Old Dec 22, 2012 | 07:42 AM
  #61
zach711f's Avatar
zach711f
^ lmao this was the problem... I'm a dumbass
Old Nov 11, 2013 | 10:09 AM
  #62
05350ZR's Avatar
05350ZR
Where are you guys unplugging the ABS block? I unplugged the harness that runs to the side of the ABS block, but now my speedo doesn't work. Can I just pull the ABS fuse in the fuse block to disconnect it?
Old Dec 5, 2013 | 04:09 AM
  #63
boltup89's Avatar
boltup89
Anyone picked up on a decent dual caliper setup,
Without blowing a hole through your wallet. Seen this one..
http://www.maverick-motorsports.com/...aliper-bracket
+ the asd pullback already purchased me doing my own labor and lines. Already ordered 2 rear brake calipers $40each used. Ain't too bad..
Old Feb 20, 2014 | 02:38 PM
  #64
Andrew321's Avatar
Andrew321
Does anyone know the length of the lines for this set up?
Old Sep 27, 2014 | 11:12 AM
  #65
350Z Project X's Avatar
350Z Project X
Im going with this kit in a couple months time. How is yours working? Found it online about 6months ago and was curious about it. Ill be doing full separate master cylinder though.
Old May 8, 2015 | 01:19 AM
  #66
boltup89's Avatar
boltup89
Project X, been out the drift game so long ... dropped the inline idea and going separate master as well, I purchased the asd 3an kit pre installed to the master to not worry about the fittings and finding sizes, now just waiting on my lines I'll be doing this summer. As far as the maverick bracket fairly simple just a bolt-on.
Old May 11, 2015 | 01:39 PM
  #67
Royal_T's Avatar
Royal_T
Yup I have the kit.. Worked with George on developing the kit.. Works perfect on any caliper setup.. I am using the 06 Iron calipers on mine..
I show case the build in my Build thread.. (please note tho that this kit does eliminate the factory E-Brake)
Old May 20, 2015 | 09:50 PM
  #68
2005bluesti's Avatar
2005bluesti
Hey guys, I used this method to install my ASD e brake and routed it into the ABS block. I have the harness completely disconnected and can only lock the brakes a slower entry speeds. When coming in to a turn at lets say 50 mph, it is not engaging. All I do is slow down. Any advise on the problem? I am running new rotors and hps pads so I don't think its the brakes. At this point in thinking of running a secondary caliper.
gt3
Aug 15, 2006 04:57 PM
Jes-Z
Jul 30, 2006 09:38 PM
gt3
Jun 2, 2006 03:08 PM
92hatchattack
Jan 15, 2005 01:29 PM
AREITU
Aug 23, 2004 09:47 AM
