infamous 3rd gear grind
Old Jan 18, 2008 | 04:52 AM
bender's Avatar
bender
Sorry to bring this topic back up again. Incase some Nissan dealership pulls the same ******** on you like they did to me, follow these steps:
1) Get them to admit why the clutch and flywheel need to be replaced. They will tell you because the new tranny will cause chatter with the old clutch and flywheel.
If they still don't budge and give you that crap about it wear items not being covered:
2) Show them the section of the warranty which states:
The following items are covered under warranty if replacement is required due to a warrantable defect...Clutch Components.
If they still don't budge:
3) Contact Nissan on their warranty complains number
If that doesn't work:
4) There is another Nissan number for people who aren't satisfied with the last step. Nissan will bring in an arbitrator to settle the issue.
Had I gone through these steps before I had the tranny replaced, I probably would have had a new clutch and flywheel courtesy of Nissan. Im out of gas now and not really interested in pursuing this any further, but I hope this ends up helping someone else.
Old Jan 18, 2008 | 05:19 AM
Reality350's Avatar
Reality350
Hey thanks for the info bender.
Sorry to hear about the BS they put you through. It can be quite frustrating dealing with stealerships.
Old Jan 23, 2008 | 08:41 AM
kingrukus's Avatar
kingrukus
thanks for the info bender. my tranny seems to be grinding into 3rd on my '03 g35 coupe (same tranny as the Z). i am going to try and deal with 401 dixie nissan as i know peter geer (service manager there). were there any other issues in trying to get the work done by 401 dixie? i think now is the time for me to look into getting an OEM nissan clutch shipped to me from one of the nissan dealerships in the states before I go-ahead with this job.
Old Jan 23, 2008 | 08:50 AM
Reality350's Avatar
Reality350
OEM clutch???... why not go aftermarket?
With the price your going to pay for OEM, you may as well upgrade.
I recently went with the Clutchmasters Stage 3 clutch kit and Flywheel.. I love it so far.
Old Jan 25, 2008 | 01:27 PM
kingrukus's Avatar
kingrukus
The reason for the OEM clutch is because I am trying to go for one with the smoothest engagement, and longest life. One would figure that the OEM one would fit these requirements? I am not planning on modifying the car much in terms of power, so the OEM one grabs just fine...
Old Jan 31, 2008 | 10:38 AM
kingrukus's Avatar
kingrukus
so what is the general consensus on the best place to get this tranny replacement done within the GTA? 401 Dixie Nissan? I have a strong feeling Ill need to get my tranny replaced, as 3rd has been grinding on engagement a lot lately, even though the clutch is fully pressed in.
Old Jan 31, 2008 | 12:54 PM
Reality350's Avatar
Reality350
St Clair nissan?...
Actually when I called Nissan Canada with regard to my oil consumption, they recommended that I take my car to agincourt nissan.. I have not had any work done there so I would not be able to provide any insight..
With regard to the clutch setup. The clutchmasters stage3 setup I have has 100000x smoother engagement when compared to OEM, and for a 10.5lb flywheel, its really very quiet..
Good luck man..
Old Feb 1, 2008 | 04:55 AM
ryan350zpower's Avatar
ryan350zpower
My car has been doing this 3rd gear grind forever now>>> I just called up my local nissan dealership and inquired about it and the guy says he knows nothing of an issue with this.... :isses me off:: Is this like a recall issue that there replacing for all 2003 350z with this grinding issue? I got about 67k miles on my car now and i was sondering if they would take care of this for me.... Nissan does anything to save a dollar...
Old Feb 1, 2008 | 08:39 AM
SuperBlack350z's Avatar
SuperBlack350z
It's not a recall because i don't see any safety issue but if you still have a powertrain (most likely don't with 67k) warranty, then they will fix it without you paying anything.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
sherm
Apr 11, 2020 05:21 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
Ace2347
Sep 22, 2015 03:12 AM
Bodyboarder81
Sep 21, 2015 06:23 AM
