tpms????????????????
Old May 17, 2008 | 07:02 PM
350zsilverstone's Avatar
350zsilverstone
Default tpms????????????????
hi guys i just order work cr kai 18 8.5 and 18 9.5 20 offset all arounds with kumho and now im curious about the tpms sensor??
do i have to buy a tpms for new wheel??? or possible to use stock tpms?
thank you!!!!
Old May 17, 2008 | 07:25 PM
noodleman's Avatar
noodleman
you can reuse the stock one, but they're mounted INSIDE the stock wheels, so you'd have to unmount the tires on your stock rims, take the tpms out, then mount them onto the work cr's, then mount & balance the tires.
alternatively, you can buy new ones from nissan ($$$), mount them onto your new rims, mount the tires, and get nissan to reprogram your car to read the new sensors instead.
Old May 17, 2008 | 07:49 PM
rzua5's Avatar
rzua5
Yes you can reuse stock one...
and nice Emotions CR Kai...make me miss my old wheels.
Old May 18, 2008 | 02:50 AM
vqz's Avatar
vqz
Hasun
did you order the rims???
Old May 18, 2008 | 06:07 AM
350zsilverstone
yeah man hahahahahaha.....
guys i have a another question...
if i do not set up the tpms sensor, the tire pressure sign will not come up????
thanx guys....!
Old May 18, 2008 | 07:44 AM
Mapleleaf's Avatar
Mapleleaf
Usually after a half hour of driving the Wheel Pressure light will come on
Old May 18, 2008 | 11:27 AM
XERMAN2001's Avatar
XERMAN2001
how much does it cost to get nissan to reprogram the tpms. can they be in the rim allready or do the tires have to come off to do so?
Old May 19, 2008 | 04:48 AM
optimumarc's Avatar
optimumarc
I went to Sherway Nissan. They are super nice and did it for around $60 taxes in. Cheapest dealer I could find. Most wanted $100.
No, the tires do not have to come off. They use the Consult via ODBI port to program them. It takes about 20min.
The sensors only sense the tire pressure when wheel is rotating.
When I did not have them in my car, the light would function intermittently.
Old May 21, 2008 | 06:33 PM
blazz's Avatar
blazz
ok so you mean I have to reprogram the tpms only if I change for news tpms ?
Old May 22, 2008 | 07:37 PM
optimumarc's Avatar
optimumarc
Yup, that is all you have to do. They (the dealership) will just program each sensor since it has a different code for each location. This is so the computer knows which sensor code is associated with each individual tire (i.e. RF, LF, RR, LR). The computer display has to distinguish between these sensors so that it (the tire pressure) can be displayed on your information cluster.
Old Jun 1, 2008 | 06:54 AM
blazz's Avatar
blazz
eheh some update
I put my old tpms on my news rims and every things work fine without going to the dealer
just want you to know
kyin
Oct 15, 2015 05:54 AM
abarclay
South East Marketplace
Sep 21, 2015 01:55 PM
tschangrx7
Nov 26, 2006 09:39 PM
