In the midst of Purchasing a Z just a couple of questions
Old Oct 28, 2008 | 02:24 PM
IVRY PRL's Avatar
IVRY PRL
Originally Posted by noodleman
i get about 500+ if i let it dip down to empty. i normally fill up at 450 and fill in about 55L.
That explains a lot, I usually throw in about 62-64L, full tank is 74.
Old Oct 28, 2008 | 03:00 PM
StraySheep's Avatar
StraySheep
I get about 500 to 550 km per tank, mostly city driving.
If you plan to drive th Z in the winter, ie. like me, make sure you get a Z with VDC. It will help in winter because you know when the car is skidding during acceleration.
Also get a set of good winter tires (Bridgestone LM22, LM25, Dunlop M3, Michellin Pilot Alpin) on a separate set of rims. Please get some rims, don't put them on steelies, it makes the Z look really cheap.
Last but not least a set of winter mats. Then you are all set for winter and some snow drifting.
If you are buying a used Z, do some research in the forums about tire feathering (03-05 model years) and oil consumption (on 06 model year).
Good luck.
Old Oct 28, 2008 | 03:12 PM
Markus9's Avatar
Markus9
Hey thanks alot for the informations guys, I appreciate the suggestions. Im going to search a couple more questions see what I can come up with. Thanks again looking forward to becoming 350 owner.
Old Oct 29, 2008 | 05:30 AM
xdragus's Avatar
xdragus
remember the thing about driving a RWD...be easy on the throttle. You'd be surprised how easy it is to make your tail swing in winter
Old Oct 29, 2008 | 05:34 AM
2TH PWR's Avatar
2TH PWR
74 L X 7.9 L/ 100 km = theorhetical top distance of 936 km.
We should attempt this cruise! I've actually averaged lower than 7.9L/100 km on long trips so who knows how far we could push the envelope?
In the spring lets have a 1000 km challenge!
Old Oct 29, 2008 | 06:05 AM
goneinsixtyseconds's Avatar
goneinsixtyseconds
how'd you get 7.9 L / 100 km's? i remember when i had my stock z, the average highway consumption i got was 9.5-10.
Old Oct 29, 2008 | 06:37 AM
IVRY PRL's Avatar
IVRY PRL
It depends on what speed you cruise at on the highway, I cruise at 105-110, and am likely getting 7.9 or better. In the past, I used to cruise at 140-150 and probably did not get anywhere near 7.9
Old Oct 29, 2008 | 07:47 AM
2TH PWR's Avatar
2TH PWR
Yeah, cruising just under 110. Also, on the roads from Petawawa to london, many of the roads have an 80km/ h limit. So I would just set cruise to 95 and would get massive fuel economy.
So to recap. Petawawa to London was about 630 km. 360 km of this on the 401. I'd cruise at 95 on the back raods, and at 110 on the 401. I would use about 2/3 or 3/4 of a tank. Once to see how far I could get I began cruising back the other way without filling up on a Sunday. Once I got back to Toronto (roughly 140km) I had to fill up again out of fear that I would be stuck in traffic. But I easily topped 850 km on that round trip without filling up.
416blueZ
Jun 11, 2024 10:56 AM
issyz
Jul 2, 2017 03:04 PM
codek
Sep 28, 2015 03:03 AM
416blueZ
Sep 24, 2015 02:11 PM
torchkc
Sep 11, 2015 08:26 PM
