Clutch Sticking Problem during Hot Weather
Old Apr 18, 2009 | 05:39 PM
StraySheep's Avatar
StraySheep
Question Clutch Sticking Problem (Stuck half way) during Hot Weather
I was wondering if any other Z driver is starting to or have experienced this clutch sticking problem. Applies to Manual transmission only.
It only happens when the weather is hot or when you are in slow traffic clutching often. I started to have this problem late last summer and it disappeared during the winter months and today with the 20C temp, the problem comes back again.
When you press on the clutch, the 1st half of the travel will feel loose (like there's no spring), then the 2nd half of the travel is the same. Then when you release the clutch after shifting, it will only release half way and stays there, but the clutch seems fully engaged. To bring the clutch all the way back up, I have to use my toe to lift the clutch pedal from the back and it will "POP" back up.
https://my350z.com/forum/engine-and-...-position.html
People say it has to do with the slave cylinder and maybe clutch fluid.
Anyone took their Z or G to the dealership to get it fixed? I plan to call the dealership Monday.
My 06 Z has 62,000km, anyone know if this will still be under warranty? If it's not under warranty, any suggestion which shop can fix this problem?
Thanks.
Old Apr 18, 2009 | 08:20 PM
Kiriller's Avatar
Kiriller
People say it has to do with the slave cylinder and may clutch fluid.
Thanks.
I believe the slave cylinder is for 07+, didnt apply to mine, checked up with local nissan as well as nissan usa. Good luck on getting that fixed, you dont want that clutch dropping.
Old Apr 18, 2009 | 10:43 PM
bender's Avatar
bender
Thanks.
i believe the warranty ends at 60k
Old Apr 18, 2009 | 11:14 PM
lbz's Avatar
lbz
I had the same problem in my 05. Was the clutch slave cylinder. Dealer replaced it under extended warranty. First they quoted me something like $450... then I reminded them to look up my ext warranty.
They found it but then recommended I have them replace the clutch as that would be the best thing to do under the circumstances. Their quote $1100.
I said I would check things out first. They did the slave cylinder and the problem went away. I bought an OEM clutch kit on line for $275 and local shop quoted me $350 labor.
That was almost a year ago and my clutch is still just fine. The kit I bought, still sitting in my closet, un-touched.
The dealer tanked when they lost their Nissan financing... LOL
You can probably get a replacement, and the seals, at courtesynissan.com. Then find a reputable shop that will do it for alot less than the dealer or even find a procedure in a forum (possibly 350ztech.com) and do it yourself.
Old Apr 19, 2009 | 07:16 AM
XuperXero's Avatar
XuperXero
I had the same problem.
I readjusted the pedal height back to OEM spec as per FSM which you can find here: http://www.*********.com/zwiki/Service:Index
If that doesn't work, then I'd recommend changing the fluid... if that doesn't work, then you know it's slave for sure.
Old Apr 19, 2009 | 08:00 AM
AVmagneticZ's Avatar
AVmagneticZ
i just had this problem changed the fluid and it was fine. ur clutch line probably has some air in it. but im no expert talk to ed@aph he fixed my problem.
Old Apr 19, 2009 | 09:11 AM
StraySheep's Avatar
StraySheep
I will get the clutch fluid changed if I can't get the dealer to change the slave cylinder under warranty.
By the way, can you gave me Ed's contact?
Thank you
Old Apr 19, 2009 | 06:26 PM
Reality350's Avatar
Reality350
Thank you
APH
Address:
1217A, Lawrence Avenue West,
Toronto, Ontario M6A 1E2
Tel: 416-781-8671
Email: info@advancepowerhouse.com
Old Apr 20, 2009 | 12:43 PM
SC350ZR's Avatar
SC350ZR
I had a similar problem when driving in traffic and warm weather, clutch would only come up about half way.
The fix was to replace the clutch line to a braided hose and DOT4 oil.
I got the Forged Performance line and problem gone
http://www.forgedperformance.com/store/home.php?cat=329
The line is only $50 right now
Old Apr 20, 2009 | 08:26 PM
StraySheep's Avatar
StraySheep
Then it sounds like this clutch sticking problem has to do with too much heat in the clutch fluid.
I just got my clutch fluid flushed and changed with Motul DOT 5.1 clutch fluid. This weekend will be the perfect weather to test it out. I hope I won't have to go as far as changing the clutch line.
Old Apr 21, 2009 | 06:02 AM
SC350ZR's Avatar
SC350ZR
The problem seems to be that with the heat the OEM rubber hose expands from the pressure giving the pedal a soft feel. The braided line doesn't expand so the volume of oil moved doesn't change.
You can really feel the difference so it is one of the best $50 i spent on my Z.
Old Apr 21, 2009 | 09:36 AM
maroli's Avatar
maroli
I have the same problem. The clutch gets stuck above the biting point so it doesn't affect driving. Annoying tho
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
