NA Or Forced induction which one should we build?
Old Jan 6, 2005 | 12:14 PM
  #101
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
yes you can increase CR without changing pistons...we are doing just that on my heads
Old Jan 6, 2005 | 01:33 PM
  #102
03BlkSETE's Avatar
03BlkSETE
I definitely want to hear about this. Any chance doing this doesn't require huge sums of money?
Old Jan 6, 2005 | 01:44 PM
  #103
Z1 Performance
Former Sponsor
lots of labor time
Old Jan 6, 2005 | 03:15 PM
  #104
GregGSC's Avatar
GregGSC
We are shooting for 5k with out labor but I think with labor it will be around 7k, so about the same as a turbo kit with less headache
Old Jan 6, 2005 | 03:53 PM
  #105
Acree's Avatar
Acree
this will be VERY interesting. most def keep us posted!
Old Jan 7, 2005 | 09:07 PM
  #106
ChromiumBlue's Avatar
ChromiumBlue
how much power can be gained with lets say the 2nd version of the NISMO Competition Heads and the reccommended parts from NISMO? Lets say we did decide to throw in a set of S1 Cams, would the car still be streetable/daily driver?
Old Jan 8, 2005 | 05:17 PM
  #107
Orange Peel's Avatar
Orange Peel
at least 300-350 rwhp would be awesome. That combined with shorter gearing and a low inertia flywheel would be a blast. Gt3 porshe racer. But the problem is expenses, and installation.
The installation would have to be outstanding and so would the tuning. Those two things are very important.
Make this the high quality, safe and reliable avenue for fun power and people will gladly pay 7 grand. But 7 grand for three to five months of headaches engine poblems is bad.
By what i'm reading it seems like you guys know what you're doing but will the installer of my kit when Ii buy it be the same.
I'd rather have you guys install the kit as well. and do the tuning. where are you located?
Old Jan 8, 2005 | 05:20 PM
  #108
Orange Peel
good you're in Southern California, me too. My 350 just might be visiting you're shop.
Old Jan 8, 2005 | 05:25 PM
  #109
uro279's Avatar
uro279
There actually in South Carolina. Too bad for us. But I'm sure we can find a good installer in So. CA!
Old Jan 10, 2005 | 08:42 AM
  #110
GregGSC's Avatar
GregGSC
The plan is to have our tuner set up the ECU for tuning and all you would need is to have a compatant installer put the new heads and cams on the intake and plug the new ecu in. anyone will be able to do it.
Old Jan 10, 2005 | 06:44 PM
  #111
ChromiumBlue
Engine Package
1.) Nismo Competition Stage 2 Heads 32mm Valve Seat
$2,499.00
2.) Nismo Titanium Valve Set
$799.00
3.) Nismo R-Tune Cams
$1,321.00
4.) Crawford Plenum
$395.00
5.) Crawford Headers
$1,195.00
6.) Crawford High Flow Cats
$500.00
7.) Technosquare ECU Reflash
$595.00
TOTAL: $7,304.00
This is the most logical Package I could come up with to hit the 300-350whp mark N/A. These items should still enable daily driving but I'm not sure about the higher pc and camshafts and how they'll affect the quality.
Old Jan 10, 2005 | 06:59 PM
  #112
nuff's Avatar
nuff
I don't think that you'll be able to hit that mark with Nismo R-Tune Cams. It seems that they are only good enough for around 270hp. You migt have to go for Spec-1 cams.
Old Jan 10, 2005 | 07:39 PM
  #113
sentry65's Avatar
sentry65
the burninator
Originally posted by ChromiumBlue
Engine Package
$2,499.00
$799.00
$1,321.00
4.) Crawford Plenum
$395.00
$1,195.00
$500.00
$595.00
TOTAL: $7,304.00
you're forgetting nismo headgaskets, valvesprings, and install fees. Probably adds another 2-3k
Old Jan 11, 2005 | 07:18 AM
  #114
southern_info's Avatar
southern_info
Go F/I with internals being reinforced for serious hp. It seems the peeps that went N/A are very disappointed with their results and also feels as though they wasted their money. I say if your going to do anything, go all out base on your budget! 15 grand for internals, twin turbo kit, dyno tuned and installed in the car around 600+hp. Damn I don't think that is too bad for a car 30k and invest probably 20k more in it including F/I done right the first time plus few more goodies. On top of that whooping on majority of the cars on the road I say GO FOR IT!
Old Jan 11, 2005 | 07:19 AM
  #115
GregGSC's Avatar
GregGSC
I think the nismo heads are shaved factory heads giving them the 12.6 to 1 compretion. Those heads on the VQ will make it impossible for people in cali to use with 91 octain.
Old Jan 11, 2005 | 07:43 AM
  #116
sentry65's Avatar
sentry65
the burninator
would it be much trouble for someone to explain how those heads raise the compression ratio with stock pistons? Would it mean if you used 8.5 pistons that you'd be around the same compression ratio as stock? Isn't it a bigger chamber? Wouldn't that be like lowering the compression?
Old Jan 11, 2005 | 12:36 PM
  #117
Acree's Avatar
Acree
i believe that the heads raise the compression because the distance from the piston at TDC and the actual valve wall is decreased from the stock distance. just like people use thicker head gaskets if they want to lower the compression. thicker meas the distance is increased.
Old Jan 11, 2005 | 12:55 PM
  #118
GregGSC's Avatar
GregGSC
I am going to find out how many cc's the stock one is when we pull the head. I have afeeling all they do is cut it 350ztwinturbo has it right to increase compresion.
Old Jan 11, 2005 | 02:52 PM
  #119
pimp1911's Avatar
pimp1911
Yeahhhhhhhhhhh!!!.
Old Jan 11, 2005 | 04:41 PM
  #120
GregGSC's Avatar
GregGSC
New wheels for the car. the hotchkis springs are not on the car yet but over all they look awesome IMO.
