Complete ECU reset
Old Dec 31, 2004 | 09:40 AM
thrifiddytt's Avatar
thrifiddytt
Default Complete ECU reset
Just disconnect the negative battery terminal for 24 hours? Will this work on 2004 models? Are there any CEL or airbag, etc lights that come on after the complete reset of the ecu?
Old Dec 31, 2004 | 05:15 PM
xsmallpaulx's Avatar
xsmallpaulx
bump for info
Old Dec 31, 2004 | 06:00 PM
___DJK___'s Avatar
___DJK___
http://www.technosquareinc.com/350reset.htm
Old Jan 20, 2005 | 06:32 AM
Billyz 212's Avatar
Billyz 212
What will resetting your ecu do. Will it harm anything if you have some mods? I have an injen cai, borla tru dual, ur pulleys and hyper grounding wires.
Old Jan 20, 2005 | 07:27 AM
xsmallpaulx
man i tried to reset my ecu like 10 times now using technosquare's info . and i cant get it to work. has anybody else sucessufully reseted their ecu?
Old Jan 20, 2005 | 04:17 PM
nuff's Avatar
nuff
You have to do it with a stop watch, timing is critical.
Old Jan 20, 2005 | 04:22 PM
ZBoater's Avatar
ZBoater
I got it to work. The instructions are fairly straightforward, but for some reason I was sitting there and freaking out I would forget something or do it wrong. A stop watch is helpful if you can't consistently count the times you hit the pedal.
Old Jan 21, 2005 | 08:47 AM
Billyz 212's Avatar
Billyz 212
What does resetting the ecu do? My VDC, trac, and brake line come on all at the same time now and was wondering if resetting the ecu would fix this.
Old Jan 30, 2005 | 10:19 AM
mrZ's Avatar
mrZ
reseting the ecu will clear the CEL light and get back power gains from mods that the ecu slowly adjusts for (in my opinion). I do it once a week and i do feel the difference.
Old Jan 30, 2005 | 07:19 PM
wa350z's Avatar
wa350z
So is there a big difference when you reset the ecu
Old Jan 31, 2005 | 06:52 AM
thawk408's Avatar
thawk408
That doesnt make any sense. Once you reset the ecu and it adjust and learns it settings...thats it. Resetting it once a week is not going to make it learn extra information that will lead to more power.
Old Jan 31, 2005 | 07:51 AM
Billyz 212's Avatar
Billyz 212
??? That sound a little strange to me too. Any how so doing this wont cause any problem? to my car
Old Jan 31, 2005 | 08:18 AM
thrifiddytt
Careful on doing this. It works on some cars, but not all. My production date is 7/04. People say that resetting the ecu by disconnecting the negative terminal will reset, or rather, put the car into a self-learning mode. But you have to also set the throttle, idle, etc for it. If you don't you could have serious problems. Technosquare couldn't help me when this happened:
My buddy has an 03, he reset and everythign went great (he was idling high and running too rich, etc.)
I reset mine and idled low, stalling on warm startups occasionally chugging. This was due to the ecu reset. Nissan set the idle air volume learning, etc for the car and now everything's fine. I also waited for a month for the Z to supposedly learn on its own, but the car still seemed "sick".
Old Jan 31, 2005 | 08:22 AM
Billyz 212's Avatar
Billyz 212
So should i do the Technosquare ecu reset then. Looks like disconnecting the batt will cause more problems than help.
Old Jan 31, 2005 | 10:05 AM
thawk408's Avatar
thawk408
If I was you I would contact nissan and see if they will tell you how.
Old Jan 31, 2005 | 02:04 PM
teh215's Avatar
teh215
I have done it successfully several times using "one one-thousand, two one-thousand ...". It takes several tries the first few times until you learn the timing. After that, it is fairly easy.
Old Feb 11, 2005 | 11:07 AM
Gman2004's Avatar
Gman2004
I wonder who was the idiot that came up with this method to reset the ECU. Why not put a reset button somewhere in a hidden location?
Old Mar 28, 2005 | 07:18 PM
GQ 350z's Avatar
GQ 350z
When resetting the ecu, it says to stomp on the accellerator 5 times and then depress within 5 seconds. Does this have to be done at exactly one time per second?
I was in my car for like 10 minutes and gave up. I used a watch and counted the seconds, but no matter how hard I tried it felt like I paniced and was off by a half a second.
Any help? I'd like to see if this makes any difference on my z.
ravi
Old Mar 28, 2005 | 08:12 PM
copba1t's Avatar
copba1t
Disconnect battery for 13 hrs, or try the Technosquare "easy" way but it's a b1tch to nail it just right...
Old Mar 28, 2005 | 10:19 PM
redline350ZZ's Avatar
redline350ZZ
so disconnecing for 13Hours will do the same thing as going through all the steps listed on the web site????
What us the benefit or reason one would want to do the other steps... listed below....
1. Accelerator Pedal Release Position Learning
2. Throttle Valve Closed Position Learning
3. Idle Air Volume Learning (Throttle Position Learning)
