dynoed my car and i feel ive wasted my money on mods
Old Jan 9, 2005 | 11:52 AM
350zbiturbo's Avatar
350zbiturbo
Default dynoed my car and i feel ive wasted my money on mods
i went to the dyno this weekend and i got 254 whp and 240 tq, i honestly think their is something wrong with the dyno or my car b/c my car doesnt feel that slow but those are the numbers coming out , look at my sig and tell me what you guys think is wrong
Old Jan 9, 2005 | 12:01 PM
TheBigShow's Avatar
TheBigShow
that's about what i got.
Old Jan 9, 2005 | 12:13 PM
westpak's Avatar
westpak
SFZCC
Did you do a before dyno to compare?
You will find out all Z's are different, plus that pop charge when you are running in the dyno with the hood up will suck in some hot air as opposed to when the hood is closed.
But one one dyno day we have a lot of variations in Z's go here for results of that day http://www.sfzcc.com/Events/2004/dynoday03/
If you want to double check we will be having a club dyno day where you will be able to check against other Z and see what you get go here for more info http://www.sfzcc.com/forum/viewtopic.php?t=716
Old Jan 9, 2005 | 12:26 PM
350zbiturbo
yea westpak ill be there for sure, im the one that was asking to see if my brother can bring his lotus to the dyno day, im just a little frustrated that my numbers are so low for the mods that i have and my car does not feel as slow as the numbers would predict
Old Jan 9, 2005 | 12:28 PM
TurK's Avatar
TurK
its gotta be the blue bats overlays...
Old Jan 9, 2005 | 12:52 PM
waijai's Avatar
waijai
Probably need an ECU reflash
Old Jan 9, 2005 | 12:54 PM
Methane's Avatar
Methane
Yes you need a ecu reflash, a proper tune is needed to make hp.
Old Jan 9, 2005 | 01:34 PM
deviant1's Avatar
deviant1
I agree. From my research here on the forums, mods like testpipes/hi flow cats, and plenums will lean out the A/F ratio significantly.
Also, is your car a 6MT or 5AT trans? That will make a difference since the autos will dyno a bit lower than a 6MT.
Is there any chance you could post the dyno plots?
Old Jan 9, 2005 | 01:38 PM
sentry65's Avatar
sentry65
the burninator
look at my mods and someone explain why I'm getting 257rhp on the dyno
this car is making me feel horrible. I've spent around $14000 modding it and I have a car that puts down 257rwhp, have a check engine light on all the time saying i'm misfiring, it's harder to drive because the throw out bearing on the tilton just sucks and sounds horrible.
I thought my car would be awesome with my mods, but it's just a headache
Old Jan 9, 2005 | 01:49 PM
Rickdogg's Avatar
Rickdogg
Out of hiatus
I was disappointed with my N/A run w/o my No2, but I am hoping that a reflash will do the trick along with some cams. If not, it is time to get some F/I with NO2
Old Jan 9, 2005 | 02:40 PM
southern_info's Avatar
southern_info
let me ask all this since there is disappointment going N/A. Would yall have invested that money into reinforcement of the motor and going F/I would yall been happy then going that route?
Old Jan 9, 2005 | 02:48 PM
Jaki's Avatar
Jaki
I was lil disappointed too, when I dynoed by car stock... so I'm going F/I in fall.
Old Jan 9, 2005 | 02:53 PM
teh215's Avatar
teh215
I realized very early on that the NA modifications were not going to yield any big improvements. The engine just seems to be just about maxed out from the factory. That is the reason that I went FI. This really is the "bang for the buck" modification for this car IMO.
Old Jan 9, 2005 | 03:07 PM
xjerseyzfinestx's Avatar
xjerseyzfinestx
Default ...
i personally dont give a s*** about dyno numbers or wutever.. if the car feels faster than stock and feels faster when you do more mods thats good enough.. dyno;s are a bunch of bs!
zzzya's Avatar
zzzya
Well for one you have some big heavy wheels on the car which will affect your Dyno numbers, but I also agree that an ECU flash could make a big difference on your car.
Old Jan 9, 2005 | 03:22 PM
Rickdogg's Avatar
Rickdogg
Out of hiatus
I would do it all over again! I'm thining of a supercharger, so my N/a mods should be okay
Old Jan 9, 2005 | 03:41 PM
TheBigShow's Avatar
TheBigShow
shoot some juice into the ****, and u'll b happy.
Old Jan 9, 2005 | 03:43 PM
zpeed350's Avatar
zpeed350
Yup, the 19's are def sucking away some of the hp...
Old Jan 9, 2005 | 03:44 PM
westpak's Avatar
westpak
SFZCC
You are not too far off I had 265 RWHP with an AF of around 13 so not lean with the following:
Injen Intake
Kinetix Plenum
Kinetix Test Pipes
Japtrix Y-pipe
Fujitsubo Exhaust
Grounding kit
What was your AF ratio? Plus as mentioned your wheels will rob you some HP, I have the light weight Track Rays so they help.
The most I have heard of was a 285 RWHP around here that had Headers and CAMS on top of what I had.
After going through it for a couple of years, if I knew then what I know now I would have insalled FI first and then work on the rest. But that is spending all money up front as oppossed to a little here and alittle there.
Old Jan 9, 2005 | 03:46 PM
kzshin's Avatar
kzshin
N/A tuned is not like Forc-induction tuned, it's not best bang for the buck. 2ndly maybe those part you chose didn't work well togther. That happens when you mix parts for different brands, a
