Iridium Plug check
Old Jan 23, 2005 | 02:26 PM
RedondoG's Avatar
RedondoG
Default Iridium Plug check
My Iridium plugs (which are 1 step colder) look as though the engine is running lean (even though I just had this dyno'ed and the air/fuel curves look great.
The standard NGK plugs had a nice coffee with cream color but these Iridium plugs look white with a hint of gray. Have any of you ever pulled your plugs to check their color as an indicator of how your engine is running?
Old Jan 23, 2005 | 04:06 PM
done12many2's Avatar
done12many2
Default Re: Iridium Plug check
Sorry to go off topic, but how do you like your Venom kit?
Old Jan 23, 2005 | 04:57 PM
RedondoG's Avatar
RedondoG
so far, The Venom kit kicks ***.
I dyno'ed with a 100 shot at 321 HP, and the tuner says it was misfiring due to having to wide a gap on the plugs. He thinks if I close up the gap it'll run 325 to 330 HP.
Old Jan 23, 2005 | 05:33 PM
nuttyprof's Avatar
nuttyprof
why are you running iridium plugs? do they actually do anything for you? ive heard they are actually bad for our cars.
Old Jan 23, 2005 | 05:38 PM
RedondoG's Avatar
RedondoG
They were suggested by the tech at Venom (and by several other people on this forum)
Old Jan 23, 2005 | 07:41 PM
uplz4588's Avatar
uplz4588
ive never herd of them being bad for our car...... links to where it says that??
Old Jan 23, 2005 | 07:51 PM
Lawn Dart's Avatar
Lawn Dart
Absolutley! I really can't tell though by your description. After all, a picture is worth a thousand words. Go to Pep Boys and look on the inside back cover of a Hayne's manual. They have about 10 pictures of different fouled spark plugs and a picture of a normal one.
Old Jan 23, 2005 | 08:44 PM
scz's Avatar
scz
Iridium plugs allow for a greater spark but dont last as long due to the fact that iridium is more brittle than platinum. Platinum plugs are fine for N/A cars, but if your running FI or nitrous you are safer with iridium.
Old Jan 23, 2005 | 08:49 PM
dynamic6er's Avatar
dynamic6er
Plug color is only an indication of whether or not you are using the correct heat range for any given application (IE NA, FI, etc.). Carbon deposits appear as a different color based on how hot the plug gets. When you are on nirtous most likely it is the correct heat range, but since you are not using this all the time it makes the plug the wrong heat range for normal conditions.
Old Jan 24, 2005 | 05:38 AM
Daniel G's Avatar
Daniel G
Actually, Iridium is the least affected by heat and so lasts much longer than the other two metals(copper and platinum) while still being a good conductor of electricity.
Melting point temperatures of the three main electrode metals:
Copper = 1981.4 degrees F
Platinum = 3221.6 degrees F
Iridium = 4370 degrees F !!!
Old Jan 24, 2005 | 06:32 AM
RedondoG's Avatar
RedondoG
worth a thousand words...
where's the picture?
Sleeper_Z
Sep 30, 2015 10:25 AM
