Less weight = more power; Have you lightened your Z?
Old Mar 26, 2006 | 04:01 PM
  #361
Rickdogg's Avatar
Rickdogg
Out of hiatus
Originally Posted by phile
rockdogg, so you're at -400lbs now? How much did this all cost you?
Some of the lightening mods double as HP mods as well Also keep in mind that I had to add weight with the roll bar and 14" rotors since performance enhancements also add weight sometimes, but in the right places
CF doors - Free
Removal Of Interior - Free
Seibon Hatch and Custom Lexan window - $
ARC Titanium Strut Bar - $
Braille Race Battery - $
C-west Full Body Kit - Free
Crawford Headers -$
Test Pipes - $
Jic Full Ti Exhaust - $
JWT Flywheel - $
350evo Dry Carbon Headlights - $
Bride Seats - $
About $4200 for the mods with dollar signs next to them. Not bad ehhh?
Old Mar 26, 2006 | 10:05 PM
  #362
phile's Avatar
phile
CF doors - Free
Crawford Headers -$
Test Pipes - $
JWT Flywheel - $
Bride Seats - $
crazy. You got lucky on the CF doors and Cwest bodykit though. So although I know you track the car probably, what kind f 1/4mile times do you think you'd get with all that weight loss?
Old Mar 26, 2006 | 10:19 PM
  #363
Rickdogg's Avatar
Rickdogg
Out of hiatus
With the right camber, rim/tire combo, and a good driver probably mid to high 12's on sea level elevation
Old Mar 26, 2006 | 10:53 PM
  #364
Havok_RLS2's Avatar
Havok_RLS2
Naw, I weigh about 160 at the moment. Slowly becoming a fat boy
Got my issue today!
Old Mar 27, 2006 | 12:24 AM
  #365
Rickdogg's Avatar
Rickdogg
Out of hiatus
Originally Posted by Havok_RLS2
Got my issue today!
Nice! Thanks for supporting Dsport Magazine!
Old Mar 27, 2006 | 05:43 AM
  #366
phile's Avatar
phile
all for roughly 4200 bucks. not bad. Plus it's probably awesome on the track. Since the bodykit isn't necessary, the cf doors are the only addition that may add to that cost.
Old Mar 27, 2006 | 06:04 AM
  #367
phile's Avatar
phile
What brand are those CF doors?
Old Mar 27, 2006 | 06:57 AM
  #368
cms-35z's Avatar
cms-35z
Originally Posted by Drag Limited
I wouldent be so sure of that, they put a toyo 4 banger in a supra in Top Speed's car if I remember correctly and it was faster and less powerful than the I6 2jz thats cause its lighter and lower center of gravity helped it acheive a higher top speed than the extra power of the heavier and less centerd I6 could achieve.
The GTC car also uses the 3sgte.
The engine is also used in the famous Team TOM'S Supra that competes in the All Japan Touring Car Championship . It uses standard stroke and bore to a 2.0L displacement , and makes "over" 480hp (357kw) with a 43.0 mm restrictor ! ! ! . Not bad considering the Supra is home to a inline 6 cylinder 2JZ-GTE originally from the factory . There are a few reasons why they run the 3S , and some are , a) They can make the hp goal with the 3S , b) The 3S is lighter than the 2JZ , c) they can sit the 3S all the way to the firewall and safeguard the radiator and intercooler , d) the lower torque of the 3S makes it far more driveable , e) they can run more boost , if running less displacement .
The car below is a monster , pure and simple . It has a Garage Fukui 2.2L stroker crank with matching rods and pistons , HKS metal head gasket with HKS 272º cams and HKS cam gears . Oil is cooled via a TRUST 16 row oil cooler and intake charge is cooled via a 600x300x100mm TRUST intercooler . Fuelling is taken care of 10 Bosch Motorsport fuel pumps [yes ten] feeding the primary fuel rail with 4x 540cc injectors and another secondary rail with 4 more 540cc Denso injectors , that is all controlled thru the HKS FCON-V PRO ECU . Boost is controlled thru a GReddy PRofec B and fed into the engine thru a massive TRUST T-88 34D turbo through a OS Giken triple plate clutch and onto the stock Getrag 6sp gearbox , into the TRD diff and out the wheels to make a damn fine 720hp @ 8500rpm and 637nm of torque at 7800rpm at 1.8bar [26.1psi] ! ! .
http://kaferjca0.tripod.com/3sgteinfo.htm
I almost did this swap myself, but I already have a 3sgte powered toyota.
I do not think the rb would be a very good swap. For the cost to swap, build and I wonder if the weight savings would be much over a very well built N/A motor. I used to think it sounded like a good idea but I have heard so many complaints about the actualy cost vs power made from that engine, seems a waste.
We have quite a few ideas on dropping weight on the gtfour forum. Might want to concider everything from the mirrors to dropping the stereo and A/C.
Check out project double down. He completely stripped his Z for race. Might give some of you some ideas.
It just boils down to comfort vs performance. I guess when the cost and comfort begins to outweight the cost of a a built tt engine and an A/C in the summer, a pure race car might not seem so "worth it".
Old Mar 30, 2006 | 03:22 AM
  #369
03Z33's Avatar
03Z33
www.aitracing.com for the doors
Old May 26, 2006 | 07:46 PM
  #370
lex350's Avatar
lex350
up for all the good info, Thanks.
Edit: This should be a sticky. I have had to search for the thread many times for information.
Vote: Sticky
Old May 26, 2006 | 09:47 PM
  #371
lex350's Avatar
lex350
One more thing. No one said anything about the antenna? A few ounces there
Old May 26, 2006 | 09:51 PM
  #372
03Z33's Avatar
03Z33
I'm shaving mine when I get the car re-painted. I already have the shortest one, 2" long, hahaha
speaking of paint, anyone know if any particular brand or style of paint is lighter? I'm planning on stripping off all of the current paint down to bare metal/carbon and use thin coats when re-painting... supposedely it's good for 20+ lbs of savings!
Old Jun 2, 2006 | 08:02 PM
  #373
lex350's Avatar
lex350
Sub.
Someone sticky this
Old Jun 3, 2006 | 04:07 PM
  #374
G350ZTT's Avatar
G350ZTT
I felt the difference once i took the spare/jak all the plastic, passinger seat out, switched to lightweigh fly wheel, battery is in the trunk no carpet or mats, exhaust is custom made and no strut bar, no plastic on the engine bay no winshield wiper tank, and light weigh racing rims (17). But the only bad thing about it was traction.
Old Jun 10, 2006 | 11:01 AM
  #375
MoodDude's Avatar
MoodDude
Read this post from front to back, for those of us who still want the radio in the car, is there a lighter radio to replace the stock one with?
Old Jun 10, 2006 | 11:49 AM
  #376
03Z33's Avatar
03Z33
ipod
Old Jun 10, 2006 | 01:06 PM
  #377
Quamen's Avatar
Quamen
better yet ipod nano
Old Jun 10, 2006 | 01:32 PM
  #378
6swhite350z's Avatar
6swhite350z
some guy on this forum doesnt want to put a clear bra on his car b/c it will add weight
Old Jun 10, 2006 | 01:55 PM
  #379
normantrack's Avatar
normantrack
maybe just turbo your car and forget about the weight.
Old Jun 10, 2006 | 01:59 PM
  #380
Acree's Avatar
Acree
Pshhhh.... screw that man. Hum.
-Acree
