Less weight = more power; Have you lightened your Z?
Old Jun 10, 2006 | 02:02 PM
  #381
cruddydude's Avatar
cruddydude
Originally Posted by 03Z33
I already have the shortest one, 2" long, hahaha
Hmmm... not something most brag about...
Old Jun 10, 2006 | 04:30 PM
  #382
MoodDude's Avatar
MoodDude
Frustrating -
look, a turbo does nothing for cornering or braking. If you lighten up the car it help cornering, braking and acceleration.
Ipod is a good idea yet don't want to wear headphones in the car and a FM modulator will still need a radio.
At one of the AutoX's I went to one of the Z guys said he replaced the stock radio with something else (I can't remember now) and he saved a lot of weight. And I still want to listen to tunes in my car (and I don't want to hum).
Old Jun 10, 2006 | 06:03 PM
  #383
6swhite350z's Avatar
6swhite350z
gut out the car.. use lighter rims.. take off the rear window whiper/motor.. take off your AC unit, remove your window washer fluid canister (or drain the water at least), dont keep extra crap in the compartments
Old Jun 12, 2006 | 02:30 PM
  #384
MoodDude's Avatar
MoodDude
Yes - like I said I have read all of that in this forum, and have done most of it already. And it does make a huge difference.
Yet, I still want my XM and no one has mentioned replacing the Radio with something lighter. My stock Z has a 6 disc changer and a tape deck that I never use. So, I believe if I just install a radio that can take my XM, it should weigh a lot less, just want to know if someone already has the specs on this.
Old Jul 26, 2006 | 08:18 PM
  #385
NA350Z's Avatar
NA350Z
Originally Posted by S12 driver
Didn't someone swapped a SR20DET in their Z, and it weighs only 2700lbs? If you're serious about weight reduction, that may be a good choice.
Is that an ARC strut bar, if not what kind is it?
Old Jul 26, 2006 | 09:52 PM
  #386
dkmesa350z's Avatar
dkmesa350z
the best weight reduction for my Z would be me losing about 30 pounds, lol
When I race I remove subs (75 lbs), spare tire, and rear mat.
Old Aug 12, 2006 | 04:16 AM
  #387
SmoothZ's Avatar
SmoothZ
Senior Super Moderator
Well, I took my Z to a National Guard base where they have a digital scale. With a full tank of gas (or close to it), I weighed in at 3300 lbs. Nissan claims my 03 Touring weighs 3247. I'm sure that's w/o any fluids in the car. If I had an empty tank, that's at least another 120 lbs off.
Then I took the rear trunk mats out, along with the spare tire, tools, and the floor mats. Got it down to 3250. Not bad.
I don't have the stock cats on anymore. They've been replaced with Helix straight pipes. I also have the Hotchkis swaybars and springs. Don't know how much of a difference that makes, but I'm sure it's only a couple of pounds, at least.
I don't know what else to take out of the car w/o compromising some comfort and amenities that I enjoy (at least that's what I tell myself with those monthly payments to justify my need for the Z).
I suppose a dry cell battery, no windshield washer fluid, and completely removing the AC system could get me close to 3000 lbs (with no gas).
Next step is to get those new wheels and tires on and try again, this time with barely any gas in the car.
Old Aug 12, 2006 | 04:56 AM
  #388
350Zenophile's Avatar
350Zenophile
For those of you who missed it, Brock started a group buy on the 11lb Braille auto battery with custom mounting bracket:
https://my350z.com/forum/showthread....hlight=braille
Saves something like 32lbs!
Old Aug 12, 2006 | 08:21 AM
  #389
spf4000's Avatar
spf4000
[QUOTE=SmoothZ]Well, I took my Z to a National Guard base where they have a digital scale. With a full tank of gas (or close to it), I weighed in at 3300 lbs. Nissan claims my 03 Touring weighs 3247. I'm sure that's w/o any fluids in the car. If I had an empty tank, that's at least another 120 lbs off.
I suppose a dry cell battery, no windshield washer fluid, and completely removing the AC system could get me close to 3000 lbs (with no gas). QUOTE]
I don't think the AC system, battery, and washer fluid will save you 130 lbs. Plus, that's a huge compromise you're going to have to make if you take out the AC.
Old Aug 12, 2006 | 08:30 AM
  #390
charlie_rdstr_Z's Avatar
charlie_rdstr_Z
Remove the engine cover 1 lb
Old Aug 12, 2006 | 11:49 AM
  #391
roast's Avatar
roast
Curb weights are generally assumed wet(full of fluids), else gross weight wouldn't mean anything to anyone.(not that it does anyway, lol)
Old Sep 16, 2006 | 08:27 AM
  #392
slinksZ's Avatar
slinksZ
The website for the CF doors states for track use only. That is understable ecause all the safty features are removed for weight savings. My question is if someone has the ball to run a CF door on the street can you put the glass window motor and alll the acessories from your stock door on the CF door. It was just suck etting caught in the rain with no glass.
Old Sep 16, 2006 | 10:59 AM
  #393
slinksZ's Avatar
slinksZ
Thats the way to step in there! I read the thread and the only thing I see your car does not have glass and so forth, but you car is pretty much a track car.and bad a$$ at that. So for sure there is a company that would make CF doors with the daily driver in mind. Its like high performance parts tha say for track only, knowing good and well in the states that do not have to deal with emissions and so forth we are going to buy the parts.
Old Sep 16, 2006 | 12:13 PM
  #394
ALong's Avatar
ALong
The A/C doesnt weight anything, I think it was about 30-30lbs in my car, the compressor weighted the most, the condesor didnt weight anything, same with the lines
Old Sep 16, 2006 | 03:35 PM
  #395
03Z33's Avatar
03Z33
You can fit the OEM stock glass in the carbon doors and the stock door panel, you can even paint them to look like stock
A lot of the weight savings is in the door glass, window motor, stock mirrors, door crash bar, etc.. You can also fit a lexan/plexiglass window which can still be rolled down, or rivet one on race-car style.
Old Sep 16, 2006 | 04:05 PM
  #396
21112's Avatar
21112
For those who want to get rid of their glass:
Sumopower.com can special order pre-cut lexan windows from Japan. They run these on their drift car. (I ordered the driver and passenger side, however they won't be here for a while yet, so I can't comment on them.)
If interested you'd only need the front windshield, driver's side, and passenger's side windows special ordered due to the curves.
The rear quarter windows and the rear hatch can be cut out of straight sheets and bolted on.
Old Nov 22, 2006 | 03:17 PM
  #397
shinkuu's Avatar
shinkuu
reading this thread, people are concerned with removing weight from the rear. under track conditions, adding a rear spoiler will help push a light rear end down. i'm trying to get my car <3000lbs for track too.
Old Nov 23, 2006 | 06:38 PM
  #398
knight_white99's Avatar
knight_white99
I added a single pipe JIC titanium exhaust and a Stillen Y-pipe; must have saved at least 50 pounds over my full dual Stillen exhaust.
I also removed the rear hanger that was now not being used any longer on the passenger side of the car and the rubber bit from the one just forward of that one. Not much - might be worth a pound or so total. (Every little bit counts!).
Also changed to some ultra-lightweight forged lugnuts. They weigh just 0.6 oz. (17g) each!
Old Dec 29, 2006 | 11:43 PM
  #399
mthreat's Avatar
mthreat
When they corner balance a car, is it done with the driver in the driver's seat?
Old Dec 29, 2006 | 11:46 PM
  #400
03Z33's Avatar
03Z33
Yes, you should do this. Or you can place some weight equal to the drive in the seat to simulate the drivers weight. You should also try to have all the loose items taken out and gas tank filled to where you normally run it when you're at the track (usually 1/2 tank).
