Less weight = more power; Have you lightened your Z?
Old Jan 10, 2007 | 07:48 AM
  #401
creationv2's Avatar
creationv2
where else is sound deadener found other than the trunk area? jw if rickdogg or someone would know, i dont realy want to strip my car to no avail.....thanks
Old Feb 1, 2007 | 08:59 PM
  #402
dave3529's Avatar
dave3529
how much does the big chunck of sheet metal behind the seats, with the rear speakers and glove box weight? i've seen a few take it out but never any info about it.
Attached Thumbnails Less weight = more power; Have you lightened your Z?-watermark0.jpg
Old Feb 6, 2007 | 12:38 PM
  #403
Rickdogg's Avatar
Rickdogg
Out of hiatus
There is a lot underneath your seats, under the center console, and also under the portion where your feet rest
Old Feb 6, 2007 | 01:56 PM
  #404
creationv2's Avatar
creationv2
yay! you answered, thanks....i assumed there would be some there, but i didnt want to take everythign out and be sad that i was wrong...and when ppl said there was around 10lbs of it i was doubtfull that the rear was 10lbs alone since i only got a few pounds if even
Old Feb 6, 2007 | 02:53 PM
  #405
kwiker's Avatar
kwiker
Shift_Dorifto
I heard about a weight that can just be removed somewhere around the engine or in the front of the car, it is about 20kg or something like that, anyone know what i am talking about, i forgot but i would like to pull it out.
Old Feb 6, 2007 | 05:15 PM
  #406
creationv2's Avatar
creationv2
^^ the i forgot what its called but maybe its it...the front bumper brace thing? or replacing the battery? 20 kg is alot pf weight...
Old Feb 6, 2007 | 05:40 PM
  #407
350Zenophile's Avatar
350Zenophile
I know it's been mentioned before, but there really is a pretty big difference in tire weights out there. I was just checking specs on Tirerack and for the same 265/35/18 tire, there was a 5 pound difference between Goodyear (30lb) and Michelin(25lb)!
Bet many give up the search for lowering unsprung weight after they buy their forged wheels. The tires are even more important since they are furthest away from the hub.
Old Feb 7, 2007 | 05:53 AM
  #408
kwiker's Avatar
kwiker
Shift_Dorifto
no, it is some sort of weight. I was looking around yesterday and i think i know what it was, there is a weight on roadsters up front on the drivers side that is there to balance the car i guess...i'm not sure. I am going to get under my car tonight probably and have a look around.
Old Feb 7, 2007 | 07:08 AM
  #409
Quamen's Avatar
Quamen
+1 on removing the metal box behind the seats? I wonder how hard it is to remove.
Remove your A/C for some nice front end savings along with relocating the battery.
Old Feb 7, 2007 | 07:13 AM
  #410
350Zenophile
I wouldn't do that unless you plan to install a cage. Looks to be a structural element tying the center of the car together.
Old Feb 7, 2007 | 07:15 AM
  #411
03Z33's Avatar
03Z33
It's easy, just a little bit of cutting.
These guys do custom plexiglass windows including windshield, I'm about to order the sides and quarter (already have the hatch done).
http://cs21.simplehost.com/~percyshp...d=32&Itemid=57
Old Feb 7, 2007 | 07:17 AM
  #412
03Z33's Avatar
03Z33
Huh? since when is a little bit of paper thin sheet metal "a structural element" ?
Old Feb 7, 2007 | 07:19 AM
  #413
kwiker's Avatar
kwiker
Shift_Dorifto
hmmmmm, very interesting....i wonder what the cons are of having the thinnest plexi all around.
Old Feb 7, 2007 | 07:41 AM
  #414
350Zenophile
When it's boxed. Take a look at the construction of the rear strut "bar" it's built the same way.
I've seen this same technique used to strengthen verts since there is nothing else to tie the b-pillars together. You'd be hard pressed to tell, I'm sure, since the coupe has a roof.
Let us know how much it weighs when you remove.
Old Feb 7, 2007 | 09:29 PM
  #415
03Z33's Avatar
03Z33
I wouldn't run the 1/8" it's a little too flimsy for my taste. I ordered the 3/16" which is the minimum requirement for SCCA. Weight difference is actually minimal, most of the savings on mine will come from the carbon doors without window motors, locks, door panel, etc..
I've already removed the rear "speaker box" and I guarantee you on the coupe it is nothing like the rear strut brace. You actually don't save much weight by removing it though, it's mostly just to clean up the look of the car and to make more room for a better roll hoop mounting location.
Old Feb 16, 2007 | 07:14 AM
  #416
kwiker's Avatar
kwiker
Shift_Dorifto
^^^^^There is a vid of a d1 supra going down a back straight and the front lexan window is caving in....i'll find it.
here ya go... http://www.youtube.com/watch?v=S_S5qIdP6qw
Old Feb 16, 2007 | 07:27 AM
  #417
craigo'sznprgrs's Avatar
craigo'sznprgrs
That video was hilarious.
Old Feb 18, 2007 | 06:23 AM
  #418
03Z33's Avatar
03Z33
If anyone's looking for Lexan rear window for your stock or carbon hatch, Kevin at LS-Auto stocks them and has great prices!
350Z stock glass weight - 14.5lbs
350Z lexan weight - 7lbs
$200 plus $60 shipping and handling
www.lsauto.com
Old Feb 18, 2007 | 12:44 PM
  #419
ke0ki2k's Avatar
ke0ki2k
Originally Posted by Ricky
Dry Carbon Fiber hood, Remove Spare, run on 1/4 tank gas, titanium coilovers, carbon fiber hatch, carbon fiber doors.. with all that, over 10,000, you'd save around 125-150lbs - my guess..
Not really worth it IMO.
the carbon fiber doors save like 60 pounds a piece...hatch saves 45 pounds-ish..havent heard anything on the hoods...with all the stuff you said id be more like 250 pounds...& gas? we're talking curb weight here right?
Old Feb 20, 2007 | 11:20 AM
  #420
ANXIOUZ's Avatar
ANXIOUZ
Has anyone put in a carbon hatch but kept the rear wiper? Or do most of the cf hatches not accomodate the wiper mechanics?
I think that's a compromise I'm going to have to strike with my wife if it's possible.
