UR Crank pulley installation question with pics
Old Feb 11, 2005 | 11:26 AM
koolzero's Avatar
koolzero
Default UR Crank pulley installation question with pics
OK I got my UR pulley on but I'm trying to find out if it's going on far enough. Compared to the OEM it's not going on flush with the motor. In the pictures you can see about 1/4 of an inch of the sleeve exposed.
I'm wondering if anyone has any pics of their installed from the top down and whether or not their pulley went on completely flush like the oem?
Attached Thumbnails UR Crank pulley installation question with pics-dsc00133.jpg
Old Feb 11, 2005 | 11:30 AM
koolzero's Avatar
koolzero
Default Re: UR Crank pulley installation question with pics
Picture 2
Attached Thumbnails UR Crank pulley installation question with pics-dsc00136.jpg
Old Feb 11, 2005 | 11:54 AM
Nano's Avatar
Nano
It's supposed to be like that. It doesn't have to go all the way in.
Put the belts on, if the belts are lined up properly, install is good.
Old Feb 11, 2005 | 12:00 PM
JisNis's Avatar
JisNis
Was the install pretty easy? I just bought one and I'm still debating if I should just pay someone.
Old Feb 11, 2005 | 12:01 PM
Zivman's Avatar
Zivman
Default Re: Re: UR Crank pulley installation question with pics
Originally posted by koolzero
Picture 2
Just make sure the belts line up and you should be good to go;
Old Feb 11, 2005 | 12:02 PM
Zivman's Avatar
Zivman
It can easliy be done with jack stands and a breaker bar.
Old Feb 11, 2005 | 05:16 PM
koolzero's Avatar
koolzero
Can someone explain to me the part about the degrees of rotation?
Old Feb 11, 2005 | 05:36 PM
Zivman's Avatar
Zivman
What are you talking about? Degrees? in terms of install?
Old Feb 11, 2005 | 07:39 PM
koolzero's Avatar
koolzero
Here is a thread that sort of explained it but I'm still confused. https://my350z.com/forum/showthread....t+crank+pulley
Old Feb 11, 2005 | 07:46 PM
koolzero's Avatar
koolzero
"Crankshaft Pulley Bolt Torque Specifications
• First Step: 29 – 36 ft-lbs. / 348 – 432 in-lbs. / 39 – 49 NM.
• Second Step: The head of the pulley bolt has 6 lines, each representing 60-66 degrees of rotation. Choose one of the lines after completing step 1 then
make a mark on the pulley at that line then turn the the bolt until the line before the original line reaches the mark on the pulley."
So this means there is a mark on the pulley??
edit: duh i have to mark the pulley..
Old Feb 11, 2005 | 08:09 PM
Zivman's Avatar
Zivman
Mark the pully when you get to around 35 ft/lbs of torque- from that point, you want to to torque to the the next mark.
My take, torque the b*tch to about 50 ft/lbs and call it a day!
BEBO'S ZEE
Jun 7, 2016 07:48 AM
reno56
Cooling System
Sep 19, 2015 11:34 AM
Shane86
Sep 17, 2015 05:33 PM
EnjukuRacing
Sep 11, 2015 08:34 AM
EnjukuRacing
Sep 11, 2015 08:30 AM
